Title: AGX Orin R36.4.4: confirming a minimal PKC + OEM_K1 fuse set, staged burn (SecurityMode last), and LUKS (luks-srv) / fTPM behavior after fusing
Setup: Jetson AGX Orin module on a third-party carrier, JetPack 6.2.1 (L4T R36.4.4), flashed with l4t_initrd_flash.sh, rootfs on NVMe with dm-verity, UEFI Secure Boot with our own PK/KEK/db, LUKS2 data partitions opened with nvluks-srv-app, fTPM used with tpm2-tools. Boards are currently unfused
Planned fuse set, RSA-3072 PKC, no SBK, one PKC key only: PublicKeyHash, OemK1 (32 random bytes, per device), BootSecurityInfo, and SecurityMode last. No Kdk0, no PkcPubkeyHash1/2.
Questions
BootSecurityInfo value - An unfused board reads 0x1E0. For RSA-3K (bits [2:0] = 001b), no SBK, OEM_K1 used for the EKB and RPMB, is the value 0x201 (read back as 0x3E1 with the factory reserved bits) correct? Is bit 9 required for OEM_K1 to take effect? Are bits 11 and 13 needed if we do not provision the fTPM EK certificates/KDK0? Where is the authoritative bit table (Orin Fuse Specification)?
Staged burn - Is it supported to burn PublicKeyHash, OemK1 and BootSecurityInfo first (with SecurityMode = 0) and burn SecurityMode alone in a second, later operation, so that we can verify boot, EKB and LUKS in between? Any dependency or known failure of burning only SecurityMode afterwards with odmfuse.sh or FSKP on R36.4.4? (We read that SecurityMode blocks all later fuse writes.)
Tooling - odmfuse.sh is marked deprecated in 36.4.4 in favour of FSKP. Is odmfuse.sh -X … -i 0x23 with locally generated keys still supported on R36.4.4? Does FSKP require NVIDIA-issued Results.zip keys, and is there a way to use FSKP without onboarding?
EKB and LUKS. After burning OEM_K1 with SecurityMode still 0, a full flash with an EKB generated by gen_ekb.py using the real OEM_K1, the same disk key (-in_sym_key2), same ECID and PARTUUID: should the luks-srv unique passphrase stay identical, so existing LUKS volumes still open? Does -reuse_fv matter? Is B_eks also used?
fTPM - We use the fTPM without KDK0 and without EK certificates in the EKB. What happens to fTPM behavior and to persistent handles created before fusing if OEM_K1 and bit 9 are burned (RPMB key derivation)? Does the fTPM NV storage move to RPMB? Is KDK0 required for the fTPM at all?
Verification - What does nv_fuse_read.sh print on a fused unit (PublicKeyHash, SecurityMode, OEM_K1)? Beyond tegrasign_v3.py --pubkeyhash, is there an official way to confirm that the signed MB1/UEFI images match the PublicKeyHash before burning?
Recovery - If the images were signed with a key that does not match the burned hash after SecurityMode, is there any documented recovery? (We saw reports of timeout in USB write at MB1 and Busy Spin after power cycle.)
We will share the final working fuse XML structure (with placeholder values) and results.
hello itay3,
let me reply your questions as below, hope I cover all your inquiries.
>> Q1.
please refer to Jetson Orin Series Modules Fuse Update Field Services Bulletin,
you should do bitwise logically OR your desired value with 0x1E0 in fuse programming flow.
for your scenario, please set BootSecurityInfo as 0x3E1.
>> Q2.
as mentioned by developer guide, Burn Fuses with the Fuse Configuration file.
NVIDIA recommends programming all required fuses in one operation, also, you cannot use FSKP for staged burning.
>> Q3.
you may still using odmfuse.sh for burning fuse variables.
>> Q4.
please refer to developer guide, Firmware TPM.
fTPM flow with hardware Silicon ID requires per-device KDK0 and BootSecurityInfo bits 9, 11, and 13.
it can operate without KDK0.
>> Q5.
please execute nv_fuse_read.sh to examine your fuse process.
note, all those keys (such as SBK, KEK…etc) will shown as 0xff... in fuse_info once SecurityMode has burned to 0x1.
that is expected due to security concern. for instance, if these fuses can be read out after burning, that will be a huge security vulnerability.
