I borrowed a JMicron JMB321evaluation card to test with a TK1. 4x512GB m.2 SSDs were attached. One of the SSD held the boot partition. I wrote a simple test script which read the 4 SSDs from beginning to end in parallel and at the same time wrote 4GB to each of the SSDs sequentially. The host controller/PM locked up twice over 36 hours. Sometimes it seem to be able to recover partially but other times not. Reboot does not solve the problem. I have to power off the card.
I discussed this with a friend who wrote SATA and NIC drivers. He is of the opinion that either the host controller or the JMB321 SATA PM has gotten into some weird internal state which can only be cleared by power cycling as reboot doesn’t always clear the internal chip states.
Some log entries that might be of interest to the NVidia SATA driver maintainer.
At this point, I will move on and try some other SATA PM chipset since the JMB321 doesn’t seem to interact well with the K-1 and 3.10.40.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Initializing cgroup subsys cpu
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Initializing cgroup subsys cpuacct
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Linux version 3.10.40-XFS-RPS-XPS (root@tegra-ubuntu) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04) ) #6 SMP PREEMPT Thu Aug 13 02:32:27 UTC 2015
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Found tsec, start=0xf4900000 size=2000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Tegra reserved memory:
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] LP0: f46ff000 - f46ff80f
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Bootloader framebuffer: 00000000 - 00000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Framebuffer: f8500000 - f96fffff
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] 2nd Framebuffer: f9700000 - fdefffff
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Carveout: 00000000 - 00000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Vpr: 00000000 - 00000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Tsec: f4900000 - f68fffff
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] cma: CMA: reserved 16 MiB at ae800000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Memory policy: ECC disabled, Data cache writealloc
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] On node 0 totalpages: 492288
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0cbbb00, node_mem_map c0e09000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Normal zone: 1520 pages used for memmap
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Normal zone: 0 pages reserved
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Normal zone: 194560 pages, LIFO batch:31
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] HighMem zone: 2510 pages used for memmap
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] HighMem zone: 297728 pages, LIFO batch:31
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm/boot/dts/tegra124-jetson_tk1-pm375-000-c00-00.dts
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Tegra12: CPU Speedo value 2309, Soc Speedo value 2257, Gpu Speedo value 2098
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Tegra12: CPU Speedo ID 1, Soc Speedo ID 1, Gpu Speedo ID 1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Tegra12: CPU Process ID 1,Soc Process ID 1,Gpu Process ID 1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Tegra Revision: A01 SKU: 0x81 CPU Process: 1 Core Process: 1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] tegra: PLLP fixed rate: 408000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1092000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering sbus maximum rate from 420000000 to 384000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering vic03 maximum rate from 900000000 to 828000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering tsec maximum rate from 900000000 to 828000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering msenc maximum rate from 600000000 to 528000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering se maximum rate from 600000000 to 528000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering vde maximum rate from 600000000 to 528000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering host1x maximum rate from 500000000 to 444000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2320500000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Switching to timer-based delay loop
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] tegra_powergate_init: DONE
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df3000 s15488 r8192 d13184 u36864
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] pcpu-alloc: s15488 r8192 d13184 u36864 alloc=9*4096
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 490768
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 root=/dev/sda1 rw rootwait tegraboot=sdmmc gpt
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Memory: 1923MB = 1923MB total
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Memory: 1920996k/1920996k available, 142364k reserved, 1190908K highmem
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Virtual kernel memory layout:
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] .text : 0xc0008000 - 0xc0afa9cc (11211 kB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] .init : 0xc0afb000 - 0xc0b7ac80 ( 512 kB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] .data : 0xc0b7c000 - 0xc0cd4398 (1377 kB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] .bss : 0xc0cd4398 - 0xc0d5f20c ( 556 kB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] NR_IRQS:960
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] the number of interrupt controllers found is 5
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Architected local timer running at 12.00MHz (phys).
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] Console: colour dummy device 80x30
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.000000] console [tty1] enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.002851] Calibrating delay loop (skipped), value calculated using timer frequency… lpj=12000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.002905] pid_max: default: 32768 minimum: 301
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.003188] Mount-cache hash table entries: 512
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.025374] Initializing cgroup subsys debug
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.025411] Initializing cgroup subsys freezer
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.025508] CPU: Testing write buffer coherency: ok
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.025569] ftrace: allocating 30378 entries in 60 pages
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.064354] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.064395] Setting up static identity map for 0xc07e5138 - 0xc07e51d4
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.068366] ftrace: Allocated trace_printk buffers
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.076011] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.079024] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.082055] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.082255] Brought up 4 CPUs
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.082313] SMP: Total of 4 processors activated.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.082329] CPU: All CPU(s) started in SVC mode.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.083302] devtmpfs: initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.091938] pinctrl core: initialized pinctrl subsystem
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.092270] regulator-dummy: no parameters
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.092983] NET: Registered protocol family 16
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.095345] DMA: preallocated 256 KiB pool for atomic coherent allocations
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.096595] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.097609] console [pstore-1] enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.097646] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.098000] cpuidle: using governor ladder
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.098022] cpuidle: using governor menu
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.101694] ardbeg_camera_auxdata: update camera lookup table.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.106708] pinmux core: 70000868.pinmux does not support function dsi_b
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.106738] tegra124-pinctrl 70000868.pinmux: invalid function dsi_b in map table
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.110453] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.110869] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.117584] Wake16 for irq=34
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.119974] Wake58 for irq=81
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.120021] Wake41 for irq=129
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.120039] Wake43 for irq=129
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.120083] Wake40 for irq=53
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.120099] Wake42 for irq=53
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.124274] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x45:0x44:0x00
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.124357] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x45:0x44:0x00
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.124421] disp1 pclk=154700000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.124430] disp2 pclk=297000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.124440] Selecting UARTD as the debug console
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.124481] The debug console clock name is uartd
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.124906] ardbeg_modem_init: modem_id = 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.127466] Clear bootloader IO dpd settings
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.127705] Loading jetson TK1 EMC tables.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.127964] tegra: pll_m is selected as scalable EMC clock source
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.128007] Lowering emc maximum rate from 1200000000 to 924000000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.128034] tegra: validated EMC DFS table
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.128162] ardbeg_edp_init: CPU regulator 11000 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.460824] ardbeg_edp_init: GPU regulator 10500 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.461767] swapper/0 isomgr_init(): iso emc max clk=924000KHz
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.461788] swapper/0 isomgr_init(): max_iso_bw=7392000KB<6>[ 0.462142] ardbeg_touch_init init raydium touch
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.462288] Raydium - touch platform_id : 8
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.544421] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.547305] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.551677] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.554548] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.555132] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.555527] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.555556] hw-breakpoint: maximum watchpoint size is 8 bytes.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.555879] mc-err: Started MC error interface!
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.565948] bio: create slab at 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.567774] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.567808] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.567837] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.567954] vdd-ac-bat: 8400 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568086] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568118] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568145] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568239] vdd-3v3-aon: 3300 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568391] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568424] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568453] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568488] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568516] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568545] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568574] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568603] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568632] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568661] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568702] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.568788] reg-3v3-supply: 3300 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.570398] vgaarb: loaded
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.571023] SCSI subsystem initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.571210] libata version 3.00 loaded.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.571377] usbcore: registered new interface driver usbfs
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.571446] usbcore: registered new interface driver hub
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.571548] usbcore: registered new device driver usb
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.571767] of_get_named_gpio_flags exited with status 20
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.571784] of_get_named_gpio_flags exited with status 21
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.572200] of_get_named_gpio_flags exited with status 157
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.572218] of_get_named_gpio_flags exited with status 158
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.572448] of_get_named_gpio_flags exited with status 217
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.572465] of_get_named_gpio_flags exited with status 218
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.572693] of_get_named_gpio_flags exited with status 172
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.572710] of_get_named_gpio_flags exited with status 173
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.572934] of_get_named_gpio_flags exited with status 206
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.572952] of_get_named_gpio_flags exited with status 207
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.574357] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.574385] as3722 4-0040: Final OTP version 1V21
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579170] gpiochip_find_base: found new base at 1016
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579260] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579295] GPIO chip as3722-gpio: created GPIO range 0->7 ==> as3722-pinctrl PIN 0->7
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579467] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579524] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579575] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579606] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579636] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579666] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579721] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579751] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579780] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579810] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579839] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579868] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579898] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579960] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.579990] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580019] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580049] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580098] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580131] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580161] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580190] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580220] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580250] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580280] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580309] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580339] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580392] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580422] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580472] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580502] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580532] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580561] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580590] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580619] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580648] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580677] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580706] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580762] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580791] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580877] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580907] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580936] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.580988] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581036] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581066] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581112] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581166] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581195] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581249] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581301] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581331] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581401] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581430] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.581460] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.582359] vdd-cpu: 650 <–> 1300 mV at 1000 mV 3500 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.583106] vdd-core: applied init 1000000uV constraint
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.583715] vdd-core: 700 <–> 1350 mV at 1000 mV 3500 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.584901] vddio-ddr: at 1350 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.585224] as3722-sd3: no parameters
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.585797] avdd-pll-pex: 1050 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.586985] vdd-1v8: at 1800 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.587333] vdd-gpu: applied init 1000000uV constraint
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.588210] vdd-gpu: 650 <–> 1200 mV at 1000 mV 3500 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.588710] avdd-pll: at 1050 mV at 300 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.589949] vdd-cam: 1800 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.590611] avdd-dsi-csi: at 1200 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.591820] vdd-rtc: 800 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.592288] avdd-cam: 2800 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.592761] vdd-1v2-cam: 1175 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.593116] vddio-sdmmc-2: 1800 <–> 3300 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.593623] vdd-1v1-cam: 1275 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.594576] avdd-spi: 3300 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.595065] vdd-2v7-cam: 2800 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.595580] vpp-fuse: 1800 mV at 150 mA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.596146] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.596157] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.596626] Linux video capture interface: v2.00
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.597650] Advanced Linux Sound Architecture Driver Initialized.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.598115] ardbeg_wifi_power: 1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.698330] of_get_named_gpio_flags exited with status 108
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.698458] usb0-vbus: 5000 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.698638] of_get_named_gpio_flags exited with status 109
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.698752] usb1-usb2-vbus: 5000 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.698920] of_get_named_gpio_flags exited with status 86
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699050] vdd-hdmi: 5000 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699222] of_get_named_gpio_flags exited with status 63
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699323] avdd-hdmi-pll: 3300 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699370] avdd-hdmi-pll: supplied by avdd-pll-pex
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699533] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699574] of_get_named_gpio_flags exited with status 122
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699678] vdd-lcd-bl: 3300 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699828] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.699869] of_get_named_gpio_flags exited with status 58
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700002] vdd-lcd-bl-en: 5000 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700151] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700180] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700267] reg-5v0-supply: 5000 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700425] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700457] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700488] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700533] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700563] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700593] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700623] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700652] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700682] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700735] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.700821] reg-1v8-supply: 1800 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.701135] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.701177] of_get_named_gpio_flags exited with status 138
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.701287] reg-dcdc-1v2: 1200 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.701456] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.701488] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.701528] of_get_named_gpio_flags exited with status 1018
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.702045] as3722-gpio2-supply: 3300 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.702246] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.702289] of_get_named_gpio_flags exited with status 1020
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.702744] as3722-gpio4-supply: 3300 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.702918] of_get_named_gpio_flags exited with status 136
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703042] sdmmc-en-supply: 3300 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703198] of_get_named_gpio_flags exited with status 138
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703292] vdd-cdc-1v2-aud: 1200 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703443] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703476] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703507] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703535] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703631] reg-aon-1v8: 1800 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703785] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703815] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.703901] reg-aon-1v2: 1200 mV
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.706853] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.710142] tegra: started io power detection dynamic control
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.710168] tegra: NO_IO_POWER setting 0x0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.710192] Switching to clocksource arch_sys_counter
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.731169] nvmap_heap_init: nvmap_heap_init: created heap block cache
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.731377] nvmap_page_pool_init: Total MB RAM: 1891
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.731401] nvmap_page_pool_init: nvmap page pool size: 60512 pages (236 MB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.820134] nvmap_page_pool_init: highmem=25600, pool_size=60512,totalram=484345, freeram=455616, totalhigh=297727, freehigh=272057
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.820881] iram: dma coherent mem declare 0x40001000,258048
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.821688] misc nvmap: created heap iram base 0x40001000 size (252KiB)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.821836] nvmap:inner cache maint threshold=2097152
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.830919] Wake39 for irq=52
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.831020] tegra-otg tegra-otg: otg transceiver registered
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.831385] NET: Registered protocol family 2
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.832046] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.832267] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.832459] TCP: Hash tables configured (established 8192 bind 8192)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.832518] TCP: reno registered
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.832542] UDP hash table entries: 512 (order: 2, 16384 bytes)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.832597] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.832925] NET: Registered protocol family 1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.833330] RPC: Registered named UNIX socket transport module.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.833355] RPC: Registered udp transport module.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.833374] RPC: Registered tcp transport module.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.833392] RPC: Registered tcp NFSv4.1 backchannel transport module.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.833416] PCI: CLS 0 bytes, default 64
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.833665] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.838738] host1x host1x: initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.839956] CPU PMU: probing PMU on CPU 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.839990] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.840608] tegra_throttle : init passed
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.840712] Tegra cpuquiet initialized: disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.840838] cpu-tegra: init EDP limit: 2320 MHz
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.841774] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.842140] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.842394] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.842626] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.844089] bounce pool size: 64 pages
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.845440] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.845721] NTFS driver 2.1.30 [Flags: R/O].
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.845856] fuse init (API version 7.22)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.846078] msgmni has been set to 1457
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.847392] io scheduler noop registered (default)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.847699] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.847709] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.847718] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.886771] PCI host bridge to bus 0000:00
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.886799] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.886827] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.886855] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.886880] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.886936] pci 0000:00:00.0: [10de:0e12] type 01 class 0x060400
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.887030] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.887269] PCI: bus0: Fast back to back transfers disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.887297] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.887503] pci 0000:01:00.0: [8086:1521] type 00 class 0x020000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.887544] pci 0000:01:00.0: reg 10: [mem 0x00000000-0x000fffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.887608] pci 0000:01:00.0: reg 1c: [mem 0x00000000-0x00003fff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.887768] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.888004] pci 0000:01:00.1: [8086:1521] type 00 class 0x020000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.888043] pci 0000:01:00.1: reg 10: [mem 0x00000000-0x000fffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.888108] pci 0000:01:00.1: reg 1c: [mem 0x00000000-0x00003fff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.888428] pci 0000:01:00.1: PME# supported from D0 D3hot D3cold
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.890320] PCI: bus1: Fast back to back transfers disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.890350] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.890367] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.890648] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.890676] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.890699] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.890727] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.890847] aer 0000:00:00.0:pcie02: service driver aer loaded
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891023] PCI host bridge to bus 0000:02
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891049] pci_bus 0000:02: root bus resource [mem 0x32100000-0x3fffffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891076] pci_bus 0000:02: root bus resource [mem 0x12100000-0x320fffff pref]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891104] pci_bus 0000:02: root bus resource [io 0x10000-0x1ffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891128] pci_bus 0000:02: No busn resource found for root bus, will use [bus 02-ff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891181] pci 0000:02:00.0: [10de:0e13] type 01 class 0x060400
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891291] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891513] PCI: bus2: Fast back to back transfers disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891540] pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891741] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891774] pci 0000:03:00.0: reg 10: [io 0x0000-0x00ff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891822] pci 0000:03:00.0: reg 18: [mem 0x00000000-0x00000fff 64bit]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891854] pci 0000:03:00.0: reg 20: [mem 0x00000000-0x00003fff 64bit pref]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891957] pci 0000:03:00.0: supports D1 D2
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.891967] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893302] PCI: bus3: Fast back to back transfers disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893332] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893349] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 03
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893602] pcieport 0000:02:00.0: Signaling PME through PCIe PME interrupt
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893629] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893656] pcie_pme 0000:02:00.0:pcie01: service driver pcie_pme loaded
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893768] aer 0000:02:00.0:pcie02: service driver aer loaded
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893879] pcieport 0000:02:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893912] pcieport 0000:02:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff 64bit pref]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893943] pcieport 0000:02:00.0: BAR 7: assigned [io 0x10000-0x10fff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.893973] pci 0000:03:00.0: BAR 4: assigned [mem 0x12100000-0x12103fff 64bit pref]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894019] pci 0000:03:00.0: BAR 2: assigned [mem 0x32100000-0x32100fff 64bit]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894063] pci 0000:03:00.0: BAR 0: assigned [io 0x10000-0x100ff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894093] pcieport 0000:02:00.0: PCI bridge to [bus 03]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894118] pcieport 0000:02:00.0: bridge window [io 0x10000-0x10fff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894146] pcieport 0000:02:00.0: bridge window [mem 0x32100000-0x321fffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894176] pcieport 0000:02:00.0: bridge window [mem 0x12100000-0x121fffff 64bit pref]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894220] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32200000-0x324fffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894273] pci 0000:01:00.0: BAR 0: assigned [mem 0x32200000-0x322fffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894305] pci 0000:01:00.1: BAR 0: assigned [mem 0x32300000-0x323fffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894336] pci 0000:01:00.0: BAR 3: assigned [mem 0x32400000-0x32403fff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894367] pci 0000:01:00.1: BAR 3: assigned [mem 0x32404000-0x32407fff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894397] pcieport 0000:00:00.0: PCI bridge to [bus 01]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.894423] pcieport 0000:00:00.0: bridge window [mem 0x32200000-0x324fffff]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.895219] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.895344] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.896181] tsec tsec: initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.897619] isp isp.0: initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.898567] isp isp.1: initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.900070] falcon vic03.0: initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.901215] falcon msenc: initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.902014] tegradc tegradc.0: DSI: HS clock rate is 464500
Aug 19 07:39:32 tegra-ubuntu kernel: [ 0.903240] p,wuxga-10-1 panel dt support not available
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.182831] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.271415] tegradc tegradc.0: DSI pad calibration done
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.278551] tegradc tegradc.0: probed
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.279011] tegradc tegradc.0: fb registered
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.279032] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.284823] gpio wake4 for gpio=111
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.285107] tegra-i2c tegra12-i2c.3: no acknowledge from address 0x50
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.285986] tegradc tegradc.1: probed
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.290587] Console: switching to colour frame buffer device 80x30
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.295513] tegradc tegradc.1: fb registered
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.297373] hdmi_state_machine_worker (tid edb05580): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.301021] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.304223] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.304982] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.306297] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.351290] hdmi_state_machine_worker (tid edb05580): state 0 (Reset), hpd 0, pending_hpd_evt 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.351295] hdmi_disable_l: audio_switch 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.351297] hdmi_disable_l: hpd_switch 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.351302] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.362272] hdmi_state_machine_worker (tid edb05580): state 1 (Check Plug), hpd 0, pending_hpd_evt 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.362275] hdmi_disable_l: audio_switch 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.362278] hdmi_disable_l: hpd_switch 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 1.362282] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 3 (Disabled)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.747025] console [ttyS0] enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.753043] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.765160] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.777385] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.791188] (null): coherent DMA mask is unset
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.797955] gk20a gk20a.0: failed to allocate secure buffer -12
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.809353] loop: module loaded
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.815008] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.826569] gpio wake35 for gpio=70
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.832414] nct1008_nct72 0-004c: nct1008_probe: initialized
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.840954] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.855280] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.870423] tegra_profiler: Branch: Dev
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.876584] tegra_profiler: Version: 1.88
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.882842] tegra_profiler: Samples version: 31
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.889598] tegra_profiler: IO version: 16
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.895810] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.903235] tegra_profiler: power_clk: init
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.909634] tegra_profiler: auth: init
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.915748] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.924957] tegra-sata tegra-sata.0: version 1.0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.924972] of_get_named_gpio_flags: can’t parse gpios property
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.925596] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.938730] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.952302] scsi0 : tegra-sata
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.957588] scsi1 : tegra-sata
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.962650] ata1: SATA max UDMA/133 irq 55
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.968579] ata2: DUMMY
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.974640] tun: Universal TUN/TAP device driver, 1.6
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.981481] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
Aug 19 07:39:32 tegra-ubuntu kernel: [ 3.989698] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.000037] r8169 0000:03:00.0 eth0: RTL8168g/8111g at 0xf0000000, 00:04:4b:2f:59:9f, XID 0c000800 IRQ 642
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.013299] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.025496] usbcore: registered new interface driver asix
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.032721] usbcore: registered new interface driver ax88179_178a
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.040631] usbcore: registered new interface driver cdc_ether
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.048278] usbcore: registered new interface driver smsc95xx
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.055796] usbcore: registered new interface driver cdc_subset
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.063530] usbcore: registered new interface driver cdc_ncm
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.070890] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.079338] tegra USB phy - inst[1] platform info:
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.085899] port_otg: no
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.090136] has_hostpc: yes
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.094545] phy_interface: USB_PHY_INTF_UTMI
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.100403] op_mode: TEGRA_USB_OPMODE_HOST
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.106050] qc2_voltage: 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.110210] vbus_gpio: -1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.114261] hot_plug: disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.118780] remote_wakeup: enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.125091] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.132608] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.143272] Wake40 for irq=53
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.147704] Wake42 for irq=53
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.152092] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.165285] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.172642] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.180813] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.190668] usb usb1: Product: Tegra EHCI Host Controller
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.197503] usb usb1: Manufacturer: Linux 3.10.40-XFS-RPS-XPS ehci_hcd
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.205564] usb usb1: SerialNumber: tegra-ehci.1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.212163] hub 1-0:1.0: USB hub found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.217486] hub 1-0:1.0: 1 port detected
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.223227] tegra USB phy - inst[2] platform info:
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.229534] port_otg: no
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.233523] has_hostpc: yes
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.237767] phy_interface: USB_PHY_INTF_UTMI
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.243505] op_mode: TEGRA_USB_OPMODE_HOST
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.249065] qc2_voltage: 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.253260] vbus_gpio: -1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.257326] hot_plug: disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.261829] remote_wakeup: enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.268087] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.275548] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.286104] Wake41 for irq=129
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.290597] Wake43 for irq=129
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.295150] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.308284] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.315765] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.324126] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.334267] usb usb2: Product: Tegra EHCI Host Controller
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.341157] usb usb2: Manufacturer: Linux 3.10.40-XFS-RPS-XPS ehci_hcd
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.349216] usb usb2: SerialNumber: tegra-ehci.2
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.355758] hub 2-0:1.0: USB hub found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.360990] hub 2-0:1.0: 1 port detected
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.366706] ehci-pci: EHCI PCI platform driver
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.372910] tegra_xusb_read_usb_calib: usb_calib0 = 0x02040387
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.380468] usbcore: registered new interface driver usb-storage
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.388140] usbcore: registered new interface driver usbserial
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.395563] usbcore: registered new interface driver option
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.402668] usbserial: USB Serial support registered for GSM modem (1-port)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.411295] usbcore: registered new interface driver pl2303
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.418531] usbserial: USB Serial support registered for pl2303
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.426098] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.432303] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.444844] tegra USB phy - inst[0] platform info:
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.451356] port_otg: yes
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.455669] has_hostpc: yes
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.460174] phy_interface: USB_PHY_INTF_UTMI
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.460197] ata1.15: Port Multiplier 1.2, 0x197b:0x3215 r0, 5 ports, feat 0x5/0xf
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.477160] op_mode: TEGRA_USB_OPMODE_DEVICE
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.483215] qc2_voltage: 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.487624] vbus_pmu_irq: 0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.492076] vbus_gpio: -1
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.496339] ata1.00: hard resetting link
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.496343] charging: enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.496346] remote_wakeup: disabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.499134] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.526549] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.534989] as3722-rtc as3722-rtc.1: RTC interrupt 449
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.544512] i2c /dev entries driver
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.550649] virtual_init
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.556431] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.564658] tegra_dtv_probe: probing dtv.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.570436] setup_stream: bufsize = 4096, bufnum = 4
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.575534] ar0832_init: ++
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.581987] i2c-core: driver [max77387] using legacy suspend method
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.589936] i2c-core: driver [max77387] using legacy resume method
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.597750] i2c-core: driver [as364x] using legacy suspend method
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.605467] i2c-core: driver [as364x] using legacy resume method
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.613207] [IMX135] sensor driver loading
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.618939] [IMX179] sensor driver loading
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.624581] [imx132] sensor driver loading
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.630136] [AR0330] sensor driver loading
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.635686] [ar0261] sensor driver loading
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.641866] usbcore: registered new interface driver uvcvideo
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.649022] USB Video Class driver (1.1.1)
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.654568] otg state changed: SUSPEND → PERIPHERAL
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.661940] zram: Created 1 device(s) …
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.668484] sdhci: Secure Digital Host Controller Interface driver
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.676215] sdhci: Copyright(c) Pierre Ossman
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.682066] sdhci-pltfm: SDHCI platform and OF driver helper
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.689632] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.703515] sdhci-tegra sdhci-tegra.3: Speedo value 2257
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.710361] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.723082] mmc0: no vqmmc regulator found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.728744] mmc0: no vmmc regulator found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.734270] mmc0: Invalid maximum block size, assuming 512 bytes
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.741851] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.777289] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.790403] sdhci-tegra sdhci-tegra.2: Speedo value 2257
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.797628] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.810979] mmc1: no vqmmc regulator found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.817157] mmc1: no vmmc regulator found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.823234] mmc1: Invalid maximum block size, assuming 512 bytes
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.831356] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.867281] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.880879] gpio wake56 for gpio=170
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.889827] tegra-se tegra12-se: tegra_se_probe: complete
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.897841] mmc0: BKOPS_EN bit is not set
Aug 19 07:39:32 tegra-ubuntu kernel: [ 4.905679] usbcore: registered new interface dr
