TK1 ArrayFire Problem
Hello
I have tried to install ArrayFire on my Jetson board
Is ArrayFire free with TK1 ?
Thanks,
Mark Pei
Based on the quick googling it’s open source, so free. They even maintain and test Linux Tegra builds.
I guess you can just compile it from the github or register and download an binary installer. I’m assuming there is a binary installer for Jetson as have ongoing Tegra builds.
kulve, thanks your infomation
That is correct.
If you want to clone and build it on your own, the instructions are available here https://github.com/arrayfire/arrayfire/wiki/Build-Instructions-for-Linux.
To download binaries, simply register and download the Tegra K1 tar ball from http://arrayfire.com/download/ and extract it to a suitable location.
hi all,
i was finished installer ArrayFire on TK1 ubuntu, it can run ArrayFire examples
But i can not include it libary
ex:
#include <arrayfire.h>
#include <stdio.h>
int main(){
return 0;
error : #include <arrayfire.h> not found
How about it to do?
Basically you need to tell the compiler where to find the libs and the headers for your application and for all the dependencies.
I recommend that you take the Makefile here:
https://github.com/arrayfire/arrayfire_examples/tree/master/helloworld
and the common.mk in the parent directory and modify them for your app.
