TK1: Failed when building the crosstool-ng
I have installed autoconf-2.68 and configured crosstool-ng, and tried to build the crosstool.
But I meet a problem that I can’t build the crosstool successfully.
My ubuntu host version is Ubuntu 12.04 LTS
Linux ubuntu 3.2.0-23-generic-pae #36-Ubuntu SMP Tue Apr 10 22:19:09 UTC 2012 i686 i686 i386 GNU/Linux
jiangche@ubuntu:~/crosstool/depends/install/ct-ng_install/crosstool-ng-hg-install/bin$ ./ct-ng build
[INFO ] Performing some trivial sanity checks
[INFO ] Build started 20170414.235308
[INFO ] Building environment variables
[WARN ] Directory ‘/home/jiangche/crosstool/crosstool-ng/src’ does not exist.
[WARN ] Will not save downloaded tarballs to local storage.
[EXTRA] Preparing working directories
[EXTRA] Installing user-supplied crosstool-NG configuration
[EXTRA] =================================================================
[EXTRA] Dumping internal crosstool-NG configuration
[EXTRA] Building a toolchain for:
[EXTRA] build = i686-pc-linux-gnu
[EXTRA] host = i686-pc-linux-gnu
[EXTRA] target = arm-cortex_a9-linux-gnueabi
[EXTRA] Dumping internal crosstool-NG configuration: done in 0.11s (at 00:01)
[INFO ] =================================================================
[INFO ] Retrieving needed toolchain components’ tarballs
[EXTRA] Retrieving ‘linux-3.13.11’
[ERROR]
[ERROR] >>
[ERROR] >> Build failed in step ‘Retrieving needed toolchain components’ tarballs’
[ERROR] >> called in step ‘(top-level)’
[ERROR] >>
[ERROR] >> Error happened in: do_kernel_get[scripts/build/kernel/linux.sh@739]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@582]
[ERROR] >>
feiying,
just to confirm you are building this for Jetson TK1 board and r21.5 BSP?
Hi feiying,
Any further information can be shared or this issue has been clarified and fixed?
