I have a TK1 board here, and when I power it on, the usual scrolling text shows up, until it gets to “ failed to load…”
and then it displays a couple more lines of text before shutting down.
If I try to reflash it using the L4T software, even with the new 23.2 update, the board shuts off right after flashing, right before it says “Searching for IP”
If I reboot the board to try and finish installing the rest of the software, it just plain doesn’t work.
Is this a dead board, or is there a way to fix this?
