TK1 HDMI tuning registers - for FCC Class B testing
We have a TK1 based design that is failing FCC Class B limits on the HDMI output.
On googling, we came across a reference to “Tegra HDMI Tuning Guide”, but could not find the actual document.
Can we tune the HDMI output like signal drive, rise time etc?
Or can we enable spread spectrum? Does this help in lowering the emissions. The TRM does not give details on the spread spectrum, other than a single bit to enable/disable. Is there any data on this
Any feedback would be appreciated
Thank you
There are registers for drive strength, termination tuning…etc. Below are some related registers, you can check the details in TRM.
HDMI_NV_PDISP_SOR_PLL1_0
HDMI_NV_PDISP_SOR_LANE_DRIVE_CURRENT_0
HDMI_NV_PDISP_PE_CURRENT_0
HDMI_NV_PDISP_SOR_PAD_CTLS0_0
We enabled spread spectrum for PLL2 (driving HDMI) and we managed to clear Class B limits. But with spread spectrum enabled, the HDMI audio is not working.The Audio is from a different PLL.
Is this expected?Is there something else we need to do for Audio? We need to drive both Audio and Video.
Thank you
Balajis,
Could you share your modification?
Hello
This is our register configuration
CLK_RST_CONTROLLER_PLLD2_SS_CFG_0 0xF1800000
CLK_RST_CONTROLLER_PLLD2_SS_CTRL1_0 0x01001000
CLK_RST_CONTROLLER_PLLD2_SS_CTRL2_0 0x50900100
Thank you
Hi Balajis,
Sorry for late reply.
Few questions for this issue.
  1. Is HDMI video working fine with PLL_D2?
  2. Is PLL_D2 the only change for your case?
  3. What’s the orclk and pixel clock? How much will it vary when spread spectrum is enabled?
  4. What’s your raster setting? Did you try different raster?
