Hi I am making self driving car with tk1 hough transform is only fps 5 Is this a problem with Python?
Could you share more information about your algorithm?
Guess that you are using OpenCV API? Is this correct?
We have a well-tuned hough transform sample in VisionWorks library.
You can install it via JetPack directly.
More, it’s recommended to use TX2 for deep learning use case.
