TK1 processing power
We want to build an application which involves motion tracking (using a kinect-like sensor), emotion recognition from physiological parameters (using several wearable sensors) and music generation (based on user (e)motion), all in real time. We were thinking of using TK1 to process all this data and would like to have a knowledgeable opinion if TK1 has enough processing power to run the algorithms in a synchronized fashion (i.e. no noticeable delay between user movement and resulting musical phrase).
Thank you!
Hi atibo,
Maybe you could check the Jetson TK1 wiki as reference, there are many interesting projects which might provide your some insights:
http://elinux.org/Jetson_TK1#Projects_using_Jetson_TK1
