I used JetPack3.0 to install OS and other packages on TK1. The OS was successfully installed but something wrong happened when installing CUDA. Here’s the error information:
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-toolkit-6-5 : Depends: cuda-core-6-5 (= 6.5-53) but it is not going to be installed
Depends: cuda-command-line-tools-6-5 (= 6.5-53) but it is not going to be installed
Depends: cuda-samples-6-5 (= 6.5-53) but it is not going to be installed
Depends: cuda-documentation-6-5 (= 6.5-53) but it is not going to be installed
libopenmpi-dev : Depends: libhwloc-dev but it is not going to be installed
dpkg-query:package’cuda-toolkit-6-5’ is not installed and no information is available
dpkg-query:package’libfreeimage-dev’ is not installed and no information is available
dpkg-query:package’libopenmpi-dev’ is not installed and no information is available
dpkg-query:package’openmpi-bin’ is not installed and no information is available
use dpkg --info(=dpkg-deb --info)to examine archive files,and dpkg --contents(=dpkg-deb --contents)to list their contents.
error:CUDA cannot be installed on device.This may be caused by other apt-get command running on device when installing CUDA.Please use apt-get command in a terminal to make sure following packages are installed correctly on device before continueing:
cuda-toolkit-6-5 libgomp1 libfreeimage-dev libopenmpi-dev openmpi-bin
After these packages are installed on device, press Enter key to continue
The installation just stalled here and nothing happened after I pressed Enter key. I can only shut down the Xterm.
I’ve tried many times both in HOST with ubuntu 16.04 and 14.04, but they came to the same result. None of my friends met this situation.
Can anybody help me?
