FileNotFoundError: [Errno 2] No such file or directory:
When I install TLT locally,
I execute the command
tlt detectnet_v2 dataset_convert
-d /home/xiaofu/tlt-experiments/face-mask-detection-local/tlt_specs/detectnet_v2_tfrecords_kitti_trainval.txt
-o /home/xiaofu/tlt-experiments/dataset-local/tfrecords/kitti_trainval
but always prompt
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/dataset_convert.py”, line 90, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/dataset_convert.py”, line 82, in main
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/xiaofu/tlt-experiments/face-mask-detection-local/tlt_specs/detectnet_v2_tfrecords_kitti_trainval.txt’
File “/usr/local/bin/detectnet_v2”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/entrypoint/detectnet_v2.py”, line 12, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py”, line 296, in launch_job
AssertionError: Process run failed.
2021-05-24 13:59:34,196 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
in fact the path ‘/home/xiaofu/tlt-experiments/face-mask-detection-local/tlt_specs/detectnet_v2_tfrecords_kitti_trainval.txt’ is Existing
