Hi.
I have met the following core dump error when I execute tlt-export command for a trained TLT SSD model with COCO dataset (I’m using only 5 classes in COCO.). It seems that the output dimensions of my model has mismatch with the TensorRT nmsPlugin requirement. Do I need to modify nmsPlugin code for training image size if the size is different from KITTI?
Using TensorFlow backend.
2020-10-01 01:02:19.962865: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-10-01 01:02:23.119605: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2020-10-01 01:02:23.121679: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
name: Tesla V100-DGXS-32GB major: 7 minor: 0 memoryClockRate(GHz): 1.53
pciBusID: 0000:07:00.0
2020-10-01 01:02:23.121712: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-10-01 01:02:23.121758: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-10-01 01:02:23.122873: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-10-01 01:02:23.122935: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-10-01 01:02:23.124416: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-10-01 01:02:23.125536: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-10-01 01:02:23.125597: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-10-01 01:02:23.129496: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-10-01 01:02:23.129537: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-10-01 01:02:24.132005: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-10-01 01:02:24.132056: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2020-10-01 01:02:24.132070: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2020-10-01 01:02:24.138033: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 29547 MB memory) -> physical GPU (device: 0, name: Tesla V100-DGXS-32GB, pci bus id: 0000:07:00.0, compute capability: 7.0)
2020-10-01 01:02:27,362 [INFO] /usr/local/lib/python3.6/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from /workspace/11884/tlt-ssd/specs/ssd_retrain_resnet18_kitti.txt
2020-10-01 01:02:29.689845: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-10-01 01:02:29.689904: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-10-01 01:02:29.689945: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-10-01 01:02:29.689978: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-10-01 01:02:29.690004: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-10-01 01:02:29.690031: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-10-01 01:02:29.690059: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-10-01 01:02:29.690085: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-10-01 01:02:29.695753: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-10-01 01:02:29.695792: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-10-01 01:02:29.695808: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2020-10-01 01:02:29.695819: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2020-10-01 01:02:29.699648: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 29547 MB memory) -> physical GPU (device: 0, name: Tesla V100-DGXS-32GB, pci bus id: 0000:07:00.0, compute capability: 7.0)
2020-10-01 01:02:34.798170: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-10-01 01:02:34.798239: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-10-01 01:02:34.798282: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-10-01 01:02:34.798314: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-10-01 01:02:34.798339: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-10-01 01:02:34.798364: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-10-01 01:02:34.798390: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-10-01 01:02:34.798415: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-10-01 01:02:34.802217: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-10-01 01:02:34.802254: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-10-01 01:02:34.802268: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2020-10-01 01:02:34.802278: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2020-10-01 01:02:34.806342: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 29547 MB memory) -> physical GPU (device: 0, name: Tesla V100-DGXS-32GB, pci bus id: 0000:07:00.0, compute capability: 7.0)
2020-10-01 01:02:38.909293: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-10-01 01:02:38.909355: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-10-01 01:02:38.909405: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-10-01 01:02:38.909444: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-10-01 01:02:38.909472: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-10-01 01:02:38.909501: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-10-01 01:02:38.909530: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-10-01 01:02:38.909558: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-10-01 01:02:38.936612: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-10-01 01:02:38.940305: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-10-01 01:02:38.940352: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-10-01 01:02:38.940395: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-10-01 01:02:38.940439: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-10-01 01:02:38.940477: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-10-01 01:02:38.940516: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-10-01 01:02:38.940557: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-10-01 01:02:38.940594: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-10-01 01:02:38.946936: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-10-01 01:02:38.946973: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-10-01 01:02:38.946987: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2020-10-01 01:02:38.946997: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2020-10-01 01:02:38.953326: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 29547 MB memory) -> physical GPU (device: 0, name: Tesla V100-DGXS-32GB, pci bus id: 0000:07:00.0, compute capability: 7.0)
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
Warning: No conversion function registered for layer: BatchTilePlugin_TRT yet.
Converting FirstDimTile_5 as custom op: BatchTilePlugin_TRT
Converting FirstDimTile_4 as custom op: BatchTilePlugin_TRT
Converting FirstDimTile_3 as custom op: BatchTilePlugin_TRT
Converting FirstDimTile_2 as custom op: BatchTilePlugin_TRT
Converting FirstDimTile_1 as custom op: BatchTilePlugin_TRT
Converting FirstDimTile_0 as custom op: BatchTilePlugin_TRT
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking ['NMS'] as outputs
#assertion/trt_oss_src/TensorRT/plugin/nmsPlugin/nmsPlugin.cpp,249
Aborted (core dumped)
