TLT Face Mask Demo - unable to log in to the TLT container-
I am trying to build a model based on the TLT face mask demo application.
Hardware configuration: RTX-3080 Ti, Ubuntu 20.04
NVIDIA driver version - 515.76, CUDA-11.7
Docker version 20.10.21, build baeda1f
Following the instructions of TLT Face Mask Demo | NVIDIA NGC
All the prerequisites are installed and checked.
The below command is not working:
docker run --gpus all -it -v “/path/to/dir/on/host”:“/path/to/dir/in/docker”
-p 80:8888 nvcr.io/nvidia/tlt-streamanalytics:v2.0_py3 /bin/bash
Error message:
creating: /opt/ngccli/ngc-cli/frozenlist/
inflating: /opt/ngccli/ngc-cli/frozenlist/_frozenlist.cpython-39-x86_64-linux-gnu.so
extracting: /opt/ngccli/ngc-cli.md5
chmod: cannot access ‘/opt/ngccli/ngc’: No such file or directory
Please help. Thank you.
The full extract is as below:
sudo docker run --gpus all -it -v “/path/to/dir/on/host”:“/path/to/dir/in/docker” \
–2022-11-01 20:50:42-- https://ngc.nvidia.com/downloads/ngccli_reg_linux.zip
Resolving ngc.nvidia.com (ngc.nvidia.com)… 65.8.11.117, 65.8.11.54, 65.8.11.18, …
Connecting to ngc.nvidia.com (ngc.nvidia.com)|65.8.11.117|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 34067171 (32M) [application/zip]
Saving to: ‘/opt/ngccli/ngccli_reg_linux.zip’
ngccli_reg_linux.zi 100%[===================>] 32.49M 80.4MB/s in 0.4s
2022-11-01 20:50:42 (80.4 MB/s) - ‘/opt/ngccli/ngccli_reg_linux.zip’ saved [34067171/34067171]
Archive: /opt/ngccli/ngccli_reg_linux.zip
creating: /opt/ngccli/ngc-cli/multidict/
inflating: /opt/ngccli/ngc-cli/multidict/_multidict.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/libpython3.9.so.1.0
inflating: /opt/ngccli/ngc-cli/libkrb5support.so.0
inflating: /opt/ngccli/ngc-cli/libgssapi_krb5.so.2
extracting: /opt/ngccli/ngc-cli/base_library.zip
creating: /opt/ngccli/ngc-cli/certifi/
inflating: /opt/ngccli/ngc-cli/certifi/cacert.pem
inflating: /opt/ngccli/ngc-cli/libfreebl3.so
inflating: /opt/ngccli/ngc-cli/libgcc_s.so.1
inflating: /opt/ngccli/ngc-cli/libkeyutils.so.1
inflating: /opt/ngccli/ngc-cli/libcom_err.so.2
inflating: /opt/ngccli/ngc-cli/libcrypto.so.10
inflating: /opt/ngccli/ngc-cli/libffi.so.6
creating: /opt/ngccli/ngc-cli/cryptography/
creating: /opt/ngccli/ngc-cli/cryptography/hazmat/
creating: /opt/ngccli/ngc-cli/cryptography/hazmat/bindings/
inflating: /opt/ngccli/ngc-cli/cryptography/hazmat/bindings/_rust.abi3.so
inflating: /opt/ngccli/ngc-cli/cryptography/hazmat/bindings/_openssl.abi3.so
creating: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/
extracting: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/WHEEL
inflating: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/direct_url.json
extracting: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/REQUESTED
extracting: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/top_level.txt
extracting: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/INSTALLER
inflating: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/RECORD
inflating: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/METADATA
inflating: /opt/ngccli/ngc-cli/prettytable-2.0.0.dist-info/COPYING
creating: /opt/ngccli/ngc-cli/thrift/
creating: /opt/ngccli/ngc-cli/thrift/protocol/
inflating: /opt/ngccli/ngc-cli/thrift/protocol/fastbinary.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/libz.so.1
inflating: /opt/ngccli/ngc-cli/libstdc++.so.6
inflating: /opt/ngccli/ngc-cli/libk5crypto.so.3
creating: /opt/ngccli/ngc-cli/psutil/
inflating: /opt/ngccli/ngc-cli/psutil/_psutil_posix.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/psutil/_psutil_linux.cpython-39-x86_64-linux-gnu.so
creating: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/
inflating: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/WHEEL
inflating: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/LICENSE.APACHE
inflating: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/direct_url.json
extracting: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/REQUESTED
extracting: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/top_level.txt
extracting: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/INSTALLER
inflating: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/LICENSE.PSF
inflating: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/LICENSE.BSD
inflating: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/RECORD
inflating: /opt/ngccli/ngc-cli/cryptography-36.0.1.dist-info/METADATA
inflating: /opt/ngccli/ngc-cli/libselinux.so.1
inflating: /opt/ngccli/ngc-cli/libkrb5.so.3
creating: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/
inflating: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/WHEEL
inflating: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/direct_url.json
extracting: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/REQUESTED
extracting: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/top_level.txt
inflating: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/LICENSE
extracting: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/namespace_packages.txt
extracting: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/INSTALLER
inflating: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/RECORD
inflating: /opt/ngccli/ngc-cli/google_api_core-2.2.2.dist-info/METADATA
creating: /opt/ngccli/ngc-cli/aiohttp/
inflating: /opt/ngccli/ngc-cli/aiohttp/_http_writer.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/aiohttp/_websocket.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/aiohttp/_helpers.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/aiohttp/_http_parser.cpython-39-x86_64-linux-gnu.so
creating: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/
inflating: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/WHEEL
inflating: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/direct_url.json
extracting: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/REQUESTED
extracting: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/top_level.txt
inflating: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/LICENSE
extracting: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/INSTALLER
inflating: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/RECORD
inflating: /opt/ngccli/ngc-cli/jsonpickle-2.0.0.dist-info/METADATA
creating: /opt/ngccli/ngc-cli/wcwidth/
inflating: /opt/ngccli/ngc-cli/wcwidth/version.json
inflating: /opt/ngccli/ngc-cli/ngc
creating: /opt/ngccli/ngc-cli/yarl/
inflating: /opt/ngccli/ngc-cli/yarl/_quoting_c.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/_cffi_backend.cpython-39-x86_64-linux-gnu.so
creating: /opt/ngccli/ngc-cli/google/
creating: /opt/ngccli/ngc-cli/google/protobuf/
creating: /opt/ngccli/ngc-cli/google/protobuf/pyext/
inflating: /opt/ngccli/ngc-cli/google/protobuf/pyext/_message.cpython-39-x86_64-linux-gnu.so
creating: /opt/ngccli/ngc-cli/google/protobuf/internal/
inflating: /opt/ngccli/ngc-cli/google/protobuf/internal/_api_implementation.cpython-39-x86_64-linux-gnu.so
creating: /opt/ngccli/ngc-cli/lib-dynload/
inflating: /opt/ngccli/ngc-cli/lib-dynload/mmap.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_opcode.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/termios.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_codecs_jp.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_md5.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_hashlib.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_codecs_iso2022.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_socket.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/fcntl.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_elementtree.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_queue.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/select.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/resource.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_csv.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_codecs_tw.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_statistics.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_heapq.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_ssl.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_pickle.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/array.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_sha1.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/binascii.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_sha512.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/math.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_random.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_contextvars.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/zlib.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_posixsubprocess.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_datetime.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_struct.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/lib-dynload/_ctypes.cpython-39-x86_64-linux-gnu.so
extracting: /opt/ngccli/ngc-cli/botocore/data/kendra/2019-02-03/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kendra/2019-02-03/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/worklink/
creating: /opt/ngccli/ngc-cli/botocore/data/worklink/2018-09-25/
extracting: /opt/ngccli/ngc-cli/botocore/data/worklink/2018-09-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/worklink/2018-09-25/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/logs/
creating: /opt/ngccli/ngc-cli/botocore/data/logs/2014-03-28/
inflating: /opt/ngccli/ngc-cli/botocore/data/logs/2014-03-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/logs/2014-03-28/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/logs/2014-03-28/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/ce/
creating: /opt/ngccli/ngc-cli/botocore/data/ce/2017-10-25/
extracting: /opt/ngccli/ngc-cli/botocore/data/ce/2017-10-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ce/2017-10-25/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ce/2017-10-25/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/redshift/
creating: /opt/ngccli/ngc-cli/botocore/data/redshift/2012-12-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/redshift/2012-12-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/redshift/2012-12-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/redshift/2012-12-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/redshift/2012-12-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/mwaa/
creating: /opt/ngccli/ngc-cli/botocore/data/mwaa/2020-07-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/mwaa/2020-07-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mwaa/2020-07-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/importexport/
creating: /opt/ngccli/ngc-cli/botocore/data/importexport/2010-06-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/importexport/2010-06-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/importexport/2010-06-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/iot-jobs-data/
creating: /opt/ngccli/ngc-cli/botocore/data/iot-jobs-data/2017-09-29/
extracting: /opt/ngccli/ngc-cli/botocore/data/iot-jobs-data/2017-09-29/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iot-jobs-data/2017-09-29/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iot-jobs-data/2017-09-29/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/ecs/
creating: /opt/ngccli/ngc-cli/botocore/data/ecs/2014-11-13/
inflating: /opt/ngccli/ngc-cli/botocore/data/ecs/2014-11-13/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ecs/2014-11-13/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ecs/2014-11-13/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ecs/2014-11-13/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/waf/
creating: /opt/ngccli/ngc-cli/botocore/data/waf/2015-08-24/
inflating: /opt/ngccli/ngc-cli/botocore/data/waf/2015-08-24/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/waf/2015-08-24/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/waf/2015-08-24/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudhsmv2/
creating: /opt/ngccli/ngc-cli/botocore/data/cloudhsmv2/2017-04-28/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudhsmv2/2017-04-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudhsmv2/2017-04-28/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudhsmv2/2017-04-28/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/location/
creating: /opt/ngccli/ngc-cli/botocore/data/location/2020-11-19/
inflating: /opt/ngccli/ngc-cli/botocore/data/location/2020-11-19/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/location/2020-11-19/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/transfer/
creating: /opt/ngccli/ngc-cli/botocore/data/transfer/2018-11-05/
inflating: /opt/ngccli/ngc-cli/botocore/data/transfer/2018-11-05/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/transfer/2018-11-05/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/applicationcostprofiler/
creating: /opt/ngccli/ngc-cli/botocore/data/applicationcostprofiler/2020-09-10/
inflating: /opt/ngccli/ngc-cli/botocore/data/applicationcostprofiler/2020-09-10/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/applicationcostprofiler/2020-09-10/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/appstream/
creating: /opt/ngccli/ngc-cli/botocore/data/appstream/2016-12-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/appstream/2016-12-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/appstream/2016-12-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/appstream/2016-12-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/appstream/2016-12-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/signer/
creating: /opt/ngccli/ngc-cli/botocore/data/signer/2017-08-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/signer/2017-08-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/signer/2017-08-25/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/signer/2017-08-25/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/signer/2017-08-25/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/rds/
creating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-09-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-09-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-09-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-09-01/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-10-31/
inflating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-10-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-10-31/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-10-31/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-10-31/examples-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rds/2014-10-31/service-2.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/kafka/
creating: /opt/ngccli/ngc-cli/botocore/data/kafka/2018-11-14/
inflating: /opt/ngccli/ngc-cli/botocore/data/kafka/2018-11-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kafka/2018-11-14/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-control-config/
creating: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-control-config/2020-11-02/
extracting: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-control-config/2020-11-02/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-control-config/2020-11-02/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-control-config/2020-11-02/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/appintegrations/
creating: /opt/ngccli/ngc-cli/botocore/data/appintegrations/2020-07-29/
extracting: /opt/ngccli/ngc-cli/botocore/data/appintegrations/2020-07-29/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/appintegrations/2020-07-29/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/elb/
creating: /opt/ngccli/ngc-cli/botocore/data/elb/2012-06-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/elb/2012-06-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elb/2012-06-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elb/2012-06-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elb/2012-06-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/sso-oidc/
creating: /opt/ngccli/ngc-cli/botocore/data/sso-oidc/2019-06-10/
extracting: /opt/ngccli/ngc-cli/botocore/data/sso-oidc/2019-06-10/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sso-oidc/2019-06-10/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/serverlessrepo/
creating: /opt/ngccli/ngc-cli/botocore/data/serverlessrepo/2017-09-08/
inflating: /opt/ngccli/ngc-cli/botocore/data/serverlessrepo/2017-09-08/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/serverlessrepo/2017-09-08/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/kms/
creating: /opt/ngccli/ngc-cli/botocore/data/kms/2014-11-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/kms/2014-11-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kms/2014-11-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kms/2014-11-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/workdocs/
creating: /opt/ngccli/ngc-cli/botocore/data/workdocs/2016-05-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/workdocs/2016-05-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/workdocs/2016-05-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/workdocs/2016-05-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/lookoutequipment/
creating: /opt/ngccli/ngc-cli/botocore/data/lookoutequipment/2020-12-15/
extracting: /opt/ngccli/ngc-cli/botocore/data/lookoutequipment/2020-12-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lookoutequipment/2020-12-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/apprunner/
creating: /opt/ngccli/ngc-cli/botocore/data/apprunner/2020-05-15/
extracting: /opt/ngccli/ngc-cli/botocore/data/apprunner/2020-05-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/apprunner/2020-05-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/iotanalytics/
creating: /opt/ngccli/ngc-cli/botocore/data/iotanalytics/2017-11-27/
inflating: /opt/ngccli/ngc-cli/botocore/data/iotanalytics/2017-11-27/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iotanalytics/2017-11-27/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iotanalytics/2017-11-27/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/marketplace-catalog/
creating: /opt/ngccli/ngc-cli/botocore/data/marketplace-catalog/2018-09-17/
extracting: /opt/ngccli/ngc-cli/botocore/data/marketplace-catalog/2018-09-17/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/marketplace-catalog/2018-09-17/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/opsworks/
creating: /opt/ngccli/ngc-cli/botocore/data/opsworks/2013-02-18/
inflating: /opt/ngccli/ngc-cli/botocore/data/opsworks/2013-02-18/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/opsworks/2013-02-18/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/opsworks/2013-02-18/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/opsworks/2013-02-18/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/swf/
creating: /opt/ngccli/ngc-cli/botocore/data/swf/2012-01-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/swf/2012-01-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/swf/2012-01-25/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/swf/2012-01-25/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/ecr/
creating: /opt/ngccli/ngc-cli/botocore/data/ecr/2015-09-21/
inflating: /opt/ngccli/ngc-cli/botocore/data/ecr/2015-09-21/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ecr/2015-09-21/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ecr/2015-09-21/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ecr/2015-09-21/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/inspector/
creating: /opt/ngccli/ngc-cli/botocore/data/inspector/2015-08-18/
inflating: /opt/ngccli/ngc-cli/botocore/data/inspector/2015-08-18/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/inspector/2016-02-16/
inflating: /opt/ngccli/ngc-cli/botocore/data/inspector/2016-02-16/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/inspector/2016-02-16/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/inspector/2016-02-16/examples-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/endpoints.json
creating: /opt/ngccli/ngc-cli/botocore/data/connectparticipant/
creating: /opt/ngccli/ngc-cli/botocore/data/connectparticipant/2018-09-07/
extracting: /opt/ngccli/ngc-cli/botocore/data/connectparticipant/2018-09-07/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/connectparticipant/2018-09-07/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/voice-id/
creating: /opt/ngccli/ngc-cli/botocore/data/voice-id/2021-09-27/
extracting: /opt/ngccli/ngc-cli/botocore/data/voice-id/2021-09-27/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/voice-id/2021-09-27/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/workspaces/
creating: /opt/ngccli/ngc-cli/botocore/data/workspaces/2015-04-08/
inflating: /opt/ngccli/ngc-cli/botocore/data/workspaces/2015-04-08/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/workspaces/2015-04-08/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/workspaces/2015-04-08/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/s3control/
creating: /opt/ngccli/ngc-cli/botocore/data/s3control/2018-08-20/
inflating: /opt/ngccli/ngc-cli/botocore/data/s3control/2018-08-20/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/s3control/2018-08-20/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/databrew/
creating: /opt/ngccli/ngc-cli/botocore/data/databrew/2017-07-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/databrew/2017-07-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/databrew/2017-07-25/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/compute-optimizer/
creating: /opt/ngccli/ngc-cli/botocore/data/compute-optimizer/2019-11-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/compute-optimizer/2019-11-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/compute-optimizer/2019-11-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/lex-models/
creating: /opt/ngccli/ngc-cli/botocore/data/lex-models/2017-04-19/
inflating: /opt/ngccli/ngc-cli/botocore/data/lex-models/2017-04-19/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lex-models/2017-04-19/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lex-models/2017-04-19/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/codestar/
creating: /opt/ngccli/ngc-cli/botocore/data/codestar/2017-04-19/
inflating: /opt/ngccli/ngc-cli/botocore/data/codestar/2017-04-19/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codestar/2017-04-19/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codestar/2017-04-19/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudtrail/
creating: /opt/ngccli/ngc-cli/botocore/data/cloudtrail/2013-11-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudtrail/2013-11-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudtrail/2013-11-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudtrail/2013-11-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/snow-device-management/
creating: /opt/ngccli/ngc-cli/botocore/data/snow-device-management/2021-08-04/
inflating: /opt/ngccli/ngc-cli/botocore/data/snow-device-management/2021-08-04/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/snow-device-management/2021-08-04/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-signaling/
creating: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-signaling/2019-12-04/
extracting: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-signaling/2019-12-04/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-signaling/2019-12-04/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/braket/
creating: /opt/ngccli/ngc-cli/botocore/data/braket/2019-09-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/braket/2019-09-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/braket/2019-09-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/sesv2/
creating: /opt/ngccli/ngc-cli/botocore/data/sesv2/2019-09-27/
extracting: /opt/ngccli/ngc-cli/botocore/data/sesv2/2019-09-27/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sesv2/2019-09-27/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/codestar-connections/
creating: /opt/ngccli/ngc-cli/botocore/data/codestar-connections/2019-12-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/codestar-connections/2019-12-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codestar-connections/2019-12-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/honeycode/
creating: /opt/ngccli/ngc-cli/botocore/data/honeycode/2020-03-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/honeycode/2020-03-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/honeycode/2020-03-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/honeycode/2020-03-01/paginators-1.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/cognito-identity/
creating: /opt/ngccli/ngc-cli/botocore/data/cognito-identity/2014-06-30/
inflating: /opt/ngccli/ngc-cli/botocore/data/cognito-identity/2014-06-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cognito-identity/2014-06-30/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cognito-identity/2014-06-30/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/ssm-contacts/
creating: /opt/ngccli/ngc-cli/botocore/data/ssm-contacts/2021-05-03/
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm-contacts/2021-05-03/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm-contacts/2021-05-03/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/mgn/
creating: /opt/ngccli/ngc-cli/botocore/data/mgn/2020-02-26/
inflating: /opt/ngccli/ngc-cli/botocore/data/mgn/2020-02-26/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mgn/2020-02-26/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/support/
creating: /opt/ngccli/ngc-cli/botocore/data/support/2013-04-15/
inflating: /opt/ngccli/ngc-cli/botocore/data/support/2013-04-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/support/2013-04-15/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/support/2013-04-15/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/lexv2-runtime/
creating: /opt/ngccli/ngc-cli/botocore/data/lexv2-runtime/2020-08-07/
extracting: /opt/ngccli/ngc-cli/botocore/data/lexv2-runtime/2020-08-07/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lexv2-runtime/2020-08-07/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloud9/
creating: /opt/ngccli/ngc-cli/botocore/data/cloud9/2017-09-23/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloud9/2017-09-23/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloud9/2017-09-23/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloud9/2017-09-23/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/iot1click-projects/
creating: /opt/ngccli/ngc-cli/botocore/data/iot1click-projects/2018-05-14/
inflating: /opt/ngccli/ngc-cli/botocore/data/iot1click-projects/2018-05-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iot1click-projects/2018-05-14/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iot1click-projects/2018-05-14/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/codebuild/
creating: /opt/ngccli/ngc-cli/botocore/data/codebuild/2016-10-06/
inflating: /opt/ngccli/ngc-cli/botocore/data/codebuild/2016-10-06/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codebuild/2016-10-06/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codebuild/2016-10-06/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-edge/
creating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-edge/2020-09-23/
extracting: /opt/ngccli/ngc-cli/botocore/data/sagemaker-edge/2020-09-23/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-edge/2020-09-23/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/route53domains/
creating: /opt/ngccli/ngc-cli/botocore/data/route53domains/2014-05-15/
inflating: /opt/ngccli/ngc-cli/botocore/data/route53domains/2014-05-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53domains/2014-05-15/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53domains/2014-05-15/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/mobile/
creating: /opt/ngccli/ngc-cli/botocore/data/mobile/2017-07-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/mobile/2017-07-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mobile/2017-07-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mobile/2017-07-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/apigatewayv2/
creating: /opt/ngccli/ngc-cli/botocore/data/apigatewayv2/2018-11-29/
inflating: /opt/ngccli/ngc-cli/botocore/data/apigatewayv2/2018-11-29/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/apigatewayv2/2018-11-29/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/imagebuilder/
creating: /opt/ngccli/ngc-cli/botocore/data/imagebuilder/2019-12-02/
extracting: /opt/ngccli/ngc-cli/botocore/data/imagebuilder/2019-12-02/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/imagebuilder/2019-12-02/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/rekognition/
creating: /opt/ngccli/ngc-cli/botocore/data/rekognition/2016-06-27/
inflating: /opt/ngccli/ngc-cli/botocore/data/rekognition/2016-06-27/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rekognition/2016-06-27/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rekognition/2016-06-27/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rekognition/2016-06-27/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/dax/
creating: /opt/ngccli/ngc-cli/botocore/data/dax/2017-04-19/
inflating: /opt/ngccli/ngc-cli/botocore/data/dax/2017-04-19/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dax/2017-04-19/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dax/2017-04-19/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/savingsplans/
creating: /opt/ngccli/ngc-cli/botocore/data/savingsplans/2019-06-28/
extracting: /opt/ngccli/ngc-cli/botocore/data/savingsplans/2019-06-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/savingsplans/2019-06-28/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/ssm-incidents/
creating: /opt/ngccli/ngc-cli/botocore/data/ssm-incidents/2018-05-10/
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm-incidents/2018-05-10/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm-incidents/2018-05-10/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm-incidents/2018-05-10/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/lex-runtime/
creating: /opt/ngccli/ngc-cli/botocore/data/lex-runtime/2016-11-28/
extracting: /opt/ngccli/ngc-cli/botocore/data/lex-runtime/2016-11-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lex-runtime/2016-11-28/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lex-runtime/2016-11-28/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/es/
creating: /opt/ngccli/ngc-cli/botocore/data/es/2015-01-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/es/2015-01-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/es/2015-01-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/es/2015-01-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/glue/
creating: /opt/ngccli/ngc-cli/botocore/data/glue/2017-03-31/
inflating: /opt/ngccli/ngc-cli/botocore/data/glue/2017-03-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/glue/2017-03-31/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/glue/2017-03-31/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/customer-profiles/
creating: /opt/ngccli/ngc-cli/botocore/data/customer-profiles/2020-08-15/
extracting: /opt/ngccli/ngc-cli/botocore/data/customer-profiles/2020-08-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/customer-profiles/2020-08-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog/
creating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog/2015-12-10/
inflating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog/2015-12-10/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog/2015-12-10/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog/2015-12-10/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/mq/
creating: /opt/ngccli/ngc-cli/botocore/data/mq/2017-11-27/
inflating: /opt/ngccli/ngc-cli/botocore/data/mq/2017-11-27/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mq/2017-11-27/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/codedeploy/
creating: /opt/ngccli/ngc-cli/botocore/data/codedeploy/2014-10-06/
inflating: /opt/ngccli/ngc-cli/botocore/data/codedeploy/2014-10-06/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codedeploy/2014-10-06/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codedeploy/2014-10-06/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codedeploy/2014-10-06/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/sdb/
creating: /opt/ngccli/ngc-cli/botocore/data/sdb/2009-04-15/
inflating: /opt/ngccli/ngc-cli/botocore/data/sdb/2009-04-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sdb/2009-04-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/outposts/
creating: /opt/ngccli/ngc-cli/botocore/data/outposts/2019-12-03/
extracting: /opt/ngccli/ngc-cli/botocore/data/outposts/2019-12-03/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/outposts/2019-12-03/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/qldb-session/
creating: /opt/ngccli/ngc-cli/botocore/data/qldb-session/2019-07-11/
extracting: /opt/ngccli/ngc-cli/botocore/data/qldb-session/2019-07-11/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/qldb-session/2019-07-11/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/chime-sdk-messaging/
creating: /opt/ngccli/ngc-cli/botocore/data/chime-sdk-messaging/2021-05-15/
extracting: /opt/ngccli/ngc-cli/botocore/data/chime-sdk-messaging/2021-05-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/chime-sdk-messaging/2021-05-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/lightsail/
creating: /opt/ngccli/ngc-cli/botocore/data/lightsail/2016-11-28/
inflating: /opt/ngccli/ngc-cli/botocore/data/lightsail/2016-11-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lightsail/2016-11-28/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lightsail/2016-11-28/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-archived-media/
creating: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-archived-media/2017-09-30/
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-archived-media/2017-09-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-archived-media/2017-09-30/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesis-video-archived-media/2017-09-30/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/opensearch/
creating: /opt/ngccli/ngc-cli/botocore/data/opensearch/2021-01-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/opensearch/2021-01-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/opensearch/2021-01-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/elastictranscoder/
creating: /opt/ngccli/ngc-cli/botocore/data/elastictranscoder/2012-09-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/elastictranscoder/2012-09-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elastictranscoder/2012-09-25/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elastictranscoder/2012-09-25/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elastictranscoder/2012-09-25/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/stepfunctions/
creating: /opt/ngccli/ngc-cli/botocore/data/stepfunctions/2016-11-23/
inflating: /opt/ngccli/ngc-cli/botocore/data/stepfunctions/2016-11-23/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/stepfunctions/2016-11-23/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/stepfunctions/2016-11-23/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/chime-sdk-meetings/
creating: /opt/ngccli/ngc-cli/botocore/data/chime-sdk-meetings/2021-07-15/
extracting: /opt/ngccli/ngc-cli/botocore/data/chime-sdk-meetings/2021-07-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/chime-sdk-meetings/2021-07-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/datapipeline/
creating: /opt/ngccli/ngc-cli/botocore/data/datapipeline/2012-10-29/
inflating: /opt/ngccli/ngc-cli/botocore/data/datapipeline/2012-10-29/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/datapipeline/2012-10-29/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/discovery/
creating: /opt/ngccli/ngc-cli/botocore/data/discovery/2015-11-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/discovery/2015-11-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/discovery/2015-11-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/discovery/2015-11-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/ebs/
creating: /opt/ngccli/ngc-cli/botocore/data/ebs/2019-11-02/
extracting: /opt/ngccli/ngc-cli/botocore/data/ebs/2019-11-02/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ebs/2019-11-02/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/fsx/
creating: /opt/ngccli/ngc-cli/botocore/data/fsx/2018-03-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/fsx/2018-03-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/fsx/2018-03-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/pinpoint-email/
creating: /opt/ngccli/ngc-cli/botocore/data/pinpoint-email/2018-07-26/
inflating: /opt/ngccli/ngc-cli/botocore/data/pinpoint-email/2018-07-26/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/pinpoint-email/2018-07-26/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/finspace-data/
creating: /opt/ngccli/ngc-cli/botocore/data/finspace-data/2020-07-13/
extracting: /opt/ngccli/ngc-cli/botocore/data/finspace-data/2020-07-13/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/finspace-data/2020-07-13/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/devicefarm/
creating: /opt/ngccli/ngc-cli/botocore/data/devicefarm/2015-06-23/
inflating: /opt/ngccli/ngc-cli/botocore/data/devicefarm/2015-06-23/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/devicefarm/2015-06-23/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/devicefarm/2015-06-23/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/neptune/
creating: /opt/ngccli/ngc-cli/botocore/data/neptune/2014-10-31/
inflating: /opt/ngccli/ngc-cli/botocore/data/neptune/2014-10-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/neptune/2014-10-31/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/neptune/2014-10-31/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/neptune/2014-10-31/examples-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/neptune/2014-10-31/service-2.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/identitystore/
creating: /opt/ngccli/ngc-cli/botocore/data/identitystore/2020-06-15/
extracting: /opt/ngccli/ngc-cli/botocore/data/identitystore/2020-06-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/identitystore/2020-06-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/iotsecuretunneling/
creating: /opt/ngccli/ngc-cli/botocore/data/iotsecuretunneling/2018-10-05/
extracting: /opt/ngccli/ngc-cli/botocore/data/iotsecuretunneling/2018-10-05/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iotsecuretunneling/2018-10-05/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/directconnect/
creating: /opt/ngccli/ngc-cli/botocore/data/directconnect/2012-10-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/directconnect/2012-10-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/directconnect/2012-10-25/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/directconnect/2012-10-25/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/pi/
creating: /opt/ngccli/ngc-cli/botocore/data/pi/2018-02-27/
extracting: /opt/ngccli/ngc-cli/botocore/data/pi/2018-02-27/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/pi/2018-02-27/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/pi/2018-02-27/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/application-insights/
creating: /opt/ngccli/ngc-cli/botocore/data/application-insights/2018-11-25/
extracting: /opt/ngccli/ngc-cli/botocore/data/application-insights/2018-11-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/application-insights/2018-11-25/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudwatch/
creating: /opt/ngccli/ngc-cli/botocore/data/cloudwatch/2010-08-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudwatch/2010-08-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudwatch/2010-08-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudwatch/2010-08-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudwatch/2010-08-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/account/
creating: /opt/ngccli/ngc-cli/botocore/data/account/2021-02-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/account/2021-02-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/account/2021-02-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/grafana/
creating: /opt/ngccli/ngc-cli/botocore/data/grafana/2020-08-18/
inflating: /opt/ngccli/ngc-cli/botocore/data/grafana/2020-08-18/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/grafana/2020-08-18/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/kinesisanalytics/
creating: /opt/ngccli/ngc-cli/botocore/data/kinesisanalytics/2015-08-14/
extracting: /opt/ngccli/ngc-cli/botocore/data/kinesisanalytics/2015-08-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesisanalytics/2015-08-14/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesisanalytics/2015-08-14/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/quicksight/
creating: /opt/ngccli/ngc-cli/botocore/data/quicksight/2018-04-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/quicksight/2018-04-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/quicksight/2018-04-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/quicksight/2018-04-01/paginators-1.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/config/
creating: /opt/ngccli/ngc-cli/botocore/data/config/2014-11-12/
inflating: /opt/ngccli/ngc-cli/botocore/data/config/2014-11-12/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/config/2014-11-12/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/config/2014-11-12/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/mgh/
creating: /opt/ngccli/ngc-cli/botocore/data/mgh/2017-05-31/
inflating: /opt/ngccli/ngc-cli/botocore/data/mgh/2017-05-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mgh/2017-05-31/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mgh/2017-05-31/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/managedblockchain/
creating: /opt/ngccli/ngc-cli/botocore/data/managedblockchain/2018-09-24/
extracting: /opt/ngccli/ngc-cli/botocore/data/managedblockchain/2018-09-24/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/managedblockchain/2018-09-24/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/iotevents-data/
creating: /opt/ngccli/ngc-cli/botocore/data/iotevents-data/2018-10-23/
extracting: /opt/ngccli/ngc-cli/botocore/data/iotevents-data/2018-10-23/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iotevents-data/2018-10-23/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/firehose/
creating: /opt/ngccli/ngc-cli/botocore/data/firehose/2015-08-04/
extracting: /opt/ngccli/ngc-cli/botocore/data/firehose/2015-08-04/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/firehose/2015-08-04/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/firehose/2015-08-04/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/qldb/
creating: /opt/ngccli/ngc-cli/botocore/data/qldb/2019-01-02/
extracting: /opt/ngccli/ngc-cli/botocore/data/qldb/2019-01-02/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/qldb/2019-01-02/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/healthlake/
creating: /opt/ngccli/ngc-cli/botocore/data/healthlake/2017-07-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/healthlake/2017-07-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/healthlake/2017-07-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/mediatailor/
creating: /opt/ngccli/ngc-cli/botocore/data/mediatailor/2018-04-23/
inflating: /opt/ngccli/ngc-cli/botocore/data/mediatailor/2018-04-23/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mediatailor/2018-04-23/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/wafv2/
creating: /opt/ngccli/ngc-cli/botocore/data/wafv2/2019-07-29/
extracting: /opt/ngccli/ngc-cli/botocore/data/wafv2/2019-07-29/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/wafv2/2019-07-29/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/elbv2/
creating: /opt/ngccli/ngc-cli/botocore/data/elbv2/2015-12-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/elbv2/2015-12-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elbv2/2015-12-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elbv2/2015-12-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/elbv2/2015-12-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/xray/
creating: /opt/ngccli/ngc-cli/botocore/data/xray/2016-04-12/
inflating: /opt/ngccli/ngc-cli/botocore/data/xray/2016-04-12/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/xray/2016-04-12/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/xray/2016-04-12/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/clouddirectory/
creating: /opt/ngccli/ngc-cli/botocore/data/clouddirectory/2016-05-10/
inflating: /opt/ngccli/ngc-cli/botocore/data/clouddirectory/2016-05-10/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/clouddirectory/2016-05-10/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/clouddirectory/2017-01-11/
inflating: /opt/ngccli/ngc-cli/botocore/data/clouddirectory/2017-01-11/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/clouddirectory/2017-01-11/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/clouddirectory/2017-01-11/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudformation/
creating: /opt/ngccli/ngc-cli/botocore/data/cloudformation/2010-05-15/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudformation/2010-05-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudformation/2010-05-15/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudformation/2010-05-15/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudformation/2010-05-15/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/ses/
creating: /opt/ngccli/ngc-cli/botocore/data/ses/2010-12-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/ses/2010-12-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ses/2010-12-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ses/2010-12-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ses/2010-12-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/globalaccelerator/
creating: /opt/ngccli/ngc-cli/botocore/data/globalaccelerator/2018-08-08/
inflating: /opt/ngccli/ngc-cli/botocore/data/globalaccelerator/2018-08-08/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/globalaccelerator/2018-08-08/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/chime/
creating: /opt/ngccli/ngc-cli/botocore/data/chime/2018-05-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/chime/2018-05-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/chime/2018-05-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/dynamodb/
creating: /opt/ngccli/ngc-cli/botocore/data/dynamodb/2012-08-10/
inflating: /opt/ngccli/ngc-cli/botocore/data/dynamodb/2012-08-10/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dynamodb/2012-08-10/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dynamodb/2012-08-10/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dynamodb/2012-08-10/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/transcribe/
creating: /opt/ngccli/ngc-cli/botocore/data/transcribe/2017-10-26/
extracting: /opt/ngccli/ngc-cli/botocore/data/transcribe/2017-10-26/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/transcribe/2017-10-26/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/transcribe/2017-10-26/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/acm-pca/
creating: /opt/ngccli/ngc-cli/botocore/data/acm-pca/2017-08-22/
inflating: /opt/ngccli/ngc-cli/botocore/data/acm-pca/2017-08-22/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/acm-pca/2017-08-22/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/acm-pca/2017-08-22/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/acm-pca/2017-08-22/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/waf-regional/
creating: /opt/ngccli/ngc-cli/botocore/data/waf-regional/2016-11-28/
extracting: /opt/ngccli/ngc-cli/botocore/data/waf-regional/2016-11-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/waf-regional/2016-11-28/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/waf-regional/2016-11-28/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/resourcegroupstaggingapi/
creating: /opt/ngccli/ngc-cli/botocore/data/resourcegroupstaggingapi/2017-01-26/
inflating: /opt/ngccli/ngc-cli/botocore/data/resourcegroupstaggingapi/2017-01-26/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/resourcegroupstaggingapi/2017-01-26/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/resourcegroupstaggingapi/2017-01-26/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/marketplacecommerceanalytics/
creating: /opt/ngccli/ngc-cli/botocore/data/marketplacecommerceanalytics/2015-07-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/marketplacecommerceanalytics/2015-07-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/marketplacecommerceanalytics/2015-07-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/marketplacecommerceanalytics/2015-07-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-featurestore-runtime/
creating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-featurestore-runtime/2020-07-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/sagemaker-featurestore-runtime/2020-07-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-featurestore-runtime/2020-07-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-a2i-runtime/
creating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-a2i-runtime/2019-11-07/
inflating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-a2i-runtime/2019-11-07/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-a2i-runtime/2019-11-07/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/mediaconnect/
creating: /opt/ngccli/ngc-cli/botocore/data/mediaconnect/2018-11-14/
inflating: /opt/ngccli/ngc-cli/botocore/data/mediaconnect/2018-11-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mediaconnect/2018-11-14/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mediaconnect/2018-11-14/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/codepipeline/
creating: /opt/ngccli/ngc-cli/botocore/data/codepipeline/2015-07-09/
inflating: /opt/ngccli/ngc-cli/botocore/data/codepipeline/2015-07-09/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codepipeline/2015-07-09/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codepipeline/2015-07-09/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/gamelift/
creating: /opt/ngccli/ngc-cli/botocore/data/gamelift/2015-10-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/gamelift/2015-10-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/gamelift/2015-10-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/gamelift/2015-10-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/iot1click-devices/
creating: /opt/ngccli/ngc-cli/botocore/data/iot1click-devices/2018-05-14/
inflating: /opt/ngccli/ngc-cli/botocore/data/iot1click-devices/2018-05-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iot1click-devices/2018-05-14/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/ecr-public/
creating: /opt/ngccli/ngc-cli/botocore/data/ecr-public/2020-10-30/
inflating: /opt/ngccli/ngc-cli/botocore/data/ecr-public/2020-10-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ecr-public/2020-10-30/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/ivs/
creating: /opt/ngccli/ngc-cli/botocore/data/ivs/2020-07-14/
inflating: /opt/ngccli/ngc-cli/botocore/data/ivs/2020-07-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ivs/2020-07-14/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/dataexchange/
creating: /opt/ngccli/ngc-cli/botocore/data/dataexchange/2017-07-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/dataexchange/2017-07-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dataexchange/2017-07-25/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-readiness/
creating: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-readiness/2019-12-02/
inflating: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-readiness/2019-12-02/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53-recovery-readiness/2019-12-02/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/ec2-instance-connect/
creating: /opt/ngccli/ngc-cli/botocore/data/ec2-instance-connect/2018-04-02/
extracting: /opt/ngccli/ngc-cli/botocore/data/ec2-instance-connect/2018-04-02/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ec2-instance-connect/2018-04-02/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/sms/
creating: /opt/ngccli/ngc-cli/botocore/data/sms/2016-10-24/
inflating: /opt/ngccli/ngc-cli/botocore/data/sms/2016-10-24/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sms/2016-10-24/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sms/2016-10-24/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/lookoutvision/
creating: /opt/ngccli/ngc-cli/botocore/data/lookoutvision/2020-11-20/
inflating: /opt/ngccli/ngc-cli/botocore/data/lookoutvision/2020-11-20/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lookoutvision/2020-11-20/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/fms/
creating: /opt/ngccli/ngc-cli/botocore/data/fms/2018-01-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/fms/2018-01-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/fms/2018-01-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/fms/2018-01-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cur/
creating: /opt/ngccli/ngc-cli/botocore/data/cur/2017-01-06/
inflating: /opt/ngccli/ngc-cli/botocore/data/cur/2017-01-06/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cur/2017-01-06/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cur/2017-01-06/examples-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/_retry.json
creating: /opt/ngccli/ngc-cli/botocore/data/dms/
creating: /opt/ngccli/ngc-cli/botocore/data/dms/2016-01-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/dms/2016-01-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dms/2016-01-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dms/2016-01-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/dms/2016-01-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/sqs/
creating: /opt/ngccli/ngc-cli/botocore/data/sqs/2012-11-05/
inflating: /opt/ngccli/ngc-cli/botocore/data/sqs/2012-11-05/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sqs/2012-11-05/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sqs/2012-11-05/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/eks/
creating: /opt/ngccli/ngc-cli/botocore/data/eks/2017-11-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/eks/2017-11-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/eks/2017-11-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/eks/2017-11-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/eks/2017-11-01/examples-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/eks/2017-11-01/service-2.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/emr-containers/
creating: /opt/ngccli/ngc-cli/botocore/data/emr-containers/2020-10-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/emr-containers/2020-10-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/emr-containers/2020-10-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/memorydb/
creating: /opt/ngccli/ngc-cli/botocore/data/memorydb/2021-01-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/memorydb/2021-01-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/memorydb/2021-01-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/codeguruprofiler/
creating: /opt/ngccli/ngc-cli/botocore/data/codeguruprofiler/2019-07-18/
inflating: /opt/ngccli/ngc-cli/botocore/data/codeguruprofiler/2019-07-18/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codeguruprofiler/2019-07-18/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudcontrol/
creating: /opt/ngccli/ngc-cli/botocore/data/cloudcontrol/2021-09-30/
extracting: /opt/ngccli/ngc-cli/botocore/data/cloudcontrol/2021-09-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudcontrol/2021-09-30/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudcontrol/2021-09-30/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/timestream-query/
creating: /opt/ngccli/ngc-cli/botocore/data/timestream-query/2018-11-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/timestream-query/2018-11-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/timestream-query/2018-11-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/resiliencehub/
creating: /opt/ngccli/ngc-cli/botocore/data/resiliencehub/2020-04-30/
extracting: /opt/ngccli/ngc-cli/botocore/data/resiliencehub/2020-04-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/resiliencehub/2020-04-30/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog-appregistry/
creating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog-appregistry/2020-06-24/
inflating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog-appregistry/2020-06-24/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/servicecatalog-appregistry/2020-06-24/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/iot/
creating: /opt/ngccli/ngc-cli/botocore/data/iot/2015-05-28/
inflating: /opt/ngccli/ngc-cli/botocore/data/iot/2015-05-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iot/2015-05-28/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iot/2015-05-28/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/apigatewaymanagementapi/
creating: /opt/ngccli/ngc-cli/botocore/data/apigatewaymanagementapi/2018-11-29/
extracting: /opt/ngccli/ngc-cli/botocore/data/apigatewaymanagementapi/2018-11-29/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/apigatewaymanagementapi/2018-11-29/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/meteringmarketplace/
creating: /opt/ngccli/ngc-cli/botocore/data/meteringmarketplace/2016-01-14/
extracting: /opt/ngccli/ngc-cli/botocore/data/meteringmarketplace/2016-01-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/meteringmarketplace/2016-01-14/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/meteringmarketplace/2016-01-14/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/personalize-runtime/
creating: /opt/ngccli/ngc-cli/botocore/data/personalize-runtime/2018-05-22/
extracting: /opt/ngccli/ngc-cli/botocore/data/personalize-runtime/2018-05-22/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/personalize-runtime/2018-05-22/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/kafkaconnect/
creating: /opt/ngccli/ngc-cli/botocore/data/kafkaconnect/2021-09-14/
inflating: /opt/ngccli/ngc-cli/botocore/data/kafkaconnect/2021-09-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kafkaconnect/2021-09-14/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-runtime/
creating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-runtime/2017-05-13/
extracting: /opt/ngccli/ngc-cli/botocore/data/sagemaker-runtime/2017-05-13/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-runtime/2017-05-13/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/sagemaker-runtime/2017-05-13/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/mediapackage/
creating: /opt/ngccli/ngc-cli/botocore/data/mediapackage/2017-10-12/
inflating: /opt/ngccli/ngc-cli/botocore/data/mediapackage/2017-10-12/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mediapackage/2017-10-12/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/kinesis/
creating: /opt/ngccli/ngc-cli/botocore/data/kinesis/2013-12-02/
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesis/2013-12-02/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesis/2013-12-02/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesis/2013-12-02/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesis/2013-12-02/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/autoscaling-plans/
creating: /opt/ngccli/ngc-cli/botocore/data/autoscaling-plans/2018-01-06/
inflating: /opt/ngccli/ngc-cli/botocore/data/autoscaling-plans/2018-01-06/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/autoscaling-plans/2018-01-06/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/autoscaling-plans/2018-01-06/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/efs/
creating: /opt/ngccli/ngc-cli/botocore/data/efs/2015-02-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/efs/2015-02-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/efs/2015-02-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/efs/2015-02-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/route53/
creating: /opt/ngccli/ngc-cli/botocore/data/route53/2013-04-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/route53/2013-04-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53/2013-04-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53/2013-04-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53/2013-04-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/synthetics/
creating: /opt/ngccli/ngc-cli/botocore/data/synthetics/2017-10-11/
extracting: /opt/ngccli/ngc-cli/botocore/data/synthetics/2017-10-11/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/synthetics/2017-10-11/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/codeartifact/
creating: /opt/ngccli/ngc-cli/botocore/data/codeartifact/2018-09-22/
inflating: /opt/ngccli/ngc-cli/botocore/data/codeartifact/2018-09-22/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codeartifact/2018-09-22/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/codeartifact/2018-09-22/paginators-1.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/cognito-sync/
creating: /opt/ngccli/ngc-cli/botocore/data/cognito-sync/2014-06-30/
extracting: /opt/ngccli/ngc-cli/botocore/data/cognito-sync/2014-06-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cognito-sync/2014-06-30/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/panorama/
creating: /opt/ngccli/ngc-cli/botocore/data/panorama/2019-07-24/
extracting: /opt/ngccli/ngc-cli/botocore/data/panorama/2019-07-24/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/panorama/2019-07-24/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/backup/
creating: /opt/ngccli/ngc-cli/botocore/data/backup/2018-11-15/
extracting: /opt/ngccli/ngc-cli/botocore/data/backup/2018-11-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/backup/2018-11-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/alexaforbusiness/
creating: /opt/ngccli/ngc-cli/botocore/data/alexaforbusiness/2017-11-09/
inflating: /opt/ngccli/ngc-cli/botocore/data/alexaforbusiness/2017-11-09/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/alexaforbusiness/2017-11-09/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/alexaforbusiness/2017-11-09/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/appmesh/
creating: /opt/ngccli/ngc-cli/botocore/data/appmesh/2019-01-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/appmesh/2019-01-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/appmesh/2019-01-25/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/appmesh/2018-10-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/appmesh/2018-10-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/appmesh/2018-10-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/greengrassv2/
creating: /opt/ngccli/ngc-cli/botocore/data/greengrassv2/2020-11-30/
inflating: /opt/ngccli/ngc-cli/botocore/data/greengrassv2/2020-11-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/greengrassv2/2020-11-30/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/medialive/
creating: /opt/ngccli/ngc-cli/botocore/data/medialive/2017-10-14/
inflating: /opt/ngccli/ngc-cli/botocore/data/medialive/2017-10-14/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/medialive/2017-10-14/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/medialive/2017-10-14/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/timestream-write/
creating: /opt/ngccli/ngc-cli/botocore/data/timestream-write/2018-11-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/timestream-write/2018-11-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/timestream-write/2018-11-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/autoscaling/
creating: /opt/ngccli/ngc-cli/botocore/data/autoscaling/2011-01-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/autoscaling/2011-01-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/autoscaling/2011-01-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/autoscaling/2011-01-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/kinesisanalyticsv2/
creating: /opt/ngccli/ngc-cli/botocore/data/kinesisanalyticsv2/2018-05-23/
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesisanalyticsv2/2018-05-23/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/kinesisanalyticsv2/2018-05-23/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/migrationhubstrategy/
creating: /opt/ngccli/ngc-cli/botocore/data/migrationhubstrategy/2020-02-19/
inflating: /opt/ngccli/ngc-cli/botocore/data/migrationhubstrategy/2020-02-19/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/migrationhubstrategy/2020-02-19/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/migrationhubstrategy/2020-02-19/paginators-1.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/mediastore/
creating: /opt/ngccli/ngc-cli/botocore/data/mediastore/2017-09-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/mediastore/2017-09-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mediastore/2017-09-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/mediastore/2017-09-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/iot-data/
creating: /opt/ngccli/ngc-cli/botocore/data/iot-data/2015-05-28/
inflating: /opt/ngccli/ngc-cli/botocore/data/iot-data/2015-05-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iot-data/2015-05-28/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/lakeformation/
creating: /opt/ngccli/ngc-cli/botocore/data/lakeformation/2017-03-31/
extracting: /opt/ngccli/ngc-cli/botocore/data/lakeformation/2017-03-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/lakeformation/2017-03-31/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/accessanalyzer/
creating: /opt/ngccli/ngc-cli/botocore/data/accessanalyzer/2019-11-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/accessanalyzer/2019-11-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/accessanalyzer/2019-11-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/auditmanager/
creating: /opt/ngccli/ngc-cli/botocore/data/auditmanager/2017-07-25/
extracting: /opt/ngccli/ngc-cli/botocore/data/auditmanager/2017-07-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/auditmanager/2017-07-25/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/docdb/
creating: /opt/ngccli/ngc-cli/botocore/data/docdb/2014-10-31/
inflating: /opt/ngccli/ngc-cli/botocore/data/docdb/2014-10-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/docdb/2014-10-31/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/docdb/2014-10-31/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/docdb/2014-10-31/service-2.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/athena/
creating: /opt/ngccli/ngc-cli/botocore/data/athena/2017-05-18/
inflating: /opt/ngccli/ngc-cli/botocore/data/athena/2017-05-18/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/athena/2017-05-18/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/athena/2017-05-18/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/sms-voice/
creating: /opt/ngccli/ngc-cli/botocore/data/sms-voice/2018-09-05/
inflating: /opt/ngccli/ngc-cli/botocore/data/sms-voice/2018-09-05/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/rds-data/
creating: /opt/ngccli/ngc-cli/botocore/data/rds-data/2018-08-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/rds-data/2018-08-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/rds-data/2018-08-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/route53resolver/
creating: /opt/ngccli/ngc-cli/botocore/data/route53resolver/2018-04-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/route53resolver/2018-04-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53resolver/2018-04-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/route53resolver/2018-04-01/paginators-1.sdk-extras.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-09-29/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-09-29/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-09-29/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-09-29/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-06-18/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-06-18/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-06-18/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-06-18/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-06-18/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-03-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-03-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-03-25/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-03-25/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-03-25/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-09-07/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-09-07/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-09-07/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-09-07/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-01-28/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-01-28/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-01-28/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-01-28/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2019-03-26/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2019-03-26/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2019-03-26/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2019-03-26/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2019-03-26/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-10-21/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-10-21/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-10-21/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-10-21/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2020-05-31/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2020-05-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2020-05-31/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2020-05-31/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2020-05-31/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-11-25/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-11-25/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-11-25/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-11-25/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-11-25/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-11-05/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-11-05/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-11-05/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-11-05/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2018-11-05/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-09-17/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-09-17/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-09-17/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-09-17/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-04-17/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-04-17/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-04-17/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-04-17/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-08-20/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-08-20/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-08-20/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-08-20/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-01-13/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-01-13/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-01-13/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-01-13/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-08-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-08-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-08-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2016-08-01/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-10-30/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-10-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-10-30/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-10-30/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2017-10-30/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-11-06/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-11-06/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-11-06/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-11-06/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-07-27/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-07-27/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-07-27/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2015-07-27/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-05-31/
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-05-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-05-31/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cloudfront/2014-05-31/waiters-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/fis/
creating: /opt/ngccli/ngc-cli/botocore/data/fis/2020-12-01/
extracting: /opt/ngccli/ngc-cli/botocore/data/fis/2020-12-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/fis/2020-12-01/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/frauddetector/
creating: /opt/ngccli/ngc-cli/botocore/data/frauddetector/2019-11-15/
extracting: /opt/ngccli/ngc-cli/botocore/data/frauddetector/2019-11-15/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/frauddetector/2019-11-15/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/ram/
creating: /opt/ngccli/ngc-cli/botocore/data/ram/2018-01-04/
inflating: /opt/ngccli/ngc-cli/botocore/data/ram/2018-01-04/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ram/2018-01-04/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/cognito-idp/
creating: /opt/ngccli/ngc-cli/botocore/data/cognito-idp/2016-04-18/
inflating: /opt/ngccli/ngc-cli/botocore/data/cognito-idp/2016-04-18/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cognito-idp/2016-04-18/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/cognito-idp/2016-04-18/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/ssm/
creating: /opt/ngccli/ngc-cli/botocore/data/ssm/2014-11-06/
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm/2014-11-06/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm/2014-11-06/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm/2014-11-06/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/ssm/2014-11-06/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/personalize-events/
creating: /opt/ngccli/ngc-cli/botocore/data/personalize-events/2018-03-22/
extracting: /opt/ngccli/ngc-cli/botocore/data/personalize-events/2018-03-22/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/personalize-events/2018-03-22/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/datasync/
creating: /opt/ngccli/ngc-cli/botocore/data/datasync/2018-11-09/
inflating: /opt/ngccli/ngc-cli/botocore/data/datasync/2018-11-09/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/datasync/2018-11-09/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/emr/
creating: /opt/ngccli/ngc-cli/botocore/data/emr/2009-03-31/
inflating: /opt/ngccli/ngc-cli/botocore/data/emr/2009-03-31/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/emr/2009-03-31/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/emr/2009-03-31/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/emr/2009-03-31/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/polly/
creating: /opt/ngccli/ngc-cli/botocore/data/polly/2016-06-10/
inflating: /opt/ngccli/ngc-cli/botocore/data/polly/2016-06-10/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/polly/2016-06-10/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/polly/2016-06-10/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/iotevents/
creating: /opt/ngccli/ngc-cli/botocore/data/iotevents/2018-07-27/
extracting: /opt/ngccli/ngc-cli/botocore/data/iotevents/2018-07-27/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iotevents/2018-07-27/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/s3/
creating: /opt/ngccli/ngc-cli/botocore/data/s3/2006-03-01/
inflating: /opt/ngccli/ngc-cli/botocore/data/s3/2006-03-01/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/s3/2006-03-01/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/s3/2006-03-01/waiters-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/s3/2006-03-01/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/iotwireless/
creating: /opt/ngccli/ngc-cli/botocore/data/iotwireless/2020-11-22/
extracting: /opt/ngccli/ngc-cli/botocore/data/iotwireless/2020-11-22/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/iotwireless/2020-11-22/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/batch/
creating: /opt/ngccli/ngc-cli/botocore/data/batch/2016-08-10/
inflating: /opt/ngccli/ngc-cli/botocore/data/batch/2016-08-10/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/batch/2016-08-10/service-2.json
inflating: /opt/ngccli/ngc-cli/botocore/data/batch/2016-08-10/examples-1.json
creating: /opt/ngccli/ngc-cli/botocore/data/networkmanager/
creating: /opt/ngccli/ngc-cli/botocore/data/networkmanager/2019-07-05/
inflating: /opt/ngccli/ngc-cli/botocore/data/networkmanager/2019-07-05/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/networkmanager/2019-07-05/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/migrationhub-config/
creating: /opt/ngccli/ngc-cli/botocore/data/migrationhub-config/2019-06-30/
extracting: /opt/ngccli/ngc-cli/botocore/data/migrationhub-config/2019-06-30/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/migrationhub-config/2019-06-30/service-2.json
creating: /opt/ngccli/ngc-cli/botocore/data/personalize/
creating: /opt/ngccli/ngc-cli/botocore/data/personalize/2018-05-22/
inflating: /opt/ngccli/ngc-cli/botocore/data/personalize/2018-05-22/paginators-1.json
inflating: /opt/ngccli/ngc-cli/botocore/data/personalize/2018-05-22/service-2.json
inflating: /opt/ngccli/ngc-cli/libpcre.so.1
creating: /opt/ngccli/ngc-cli/grpc/
creating: /opt/ngccli/ngc-cli/grpc/_cython/
creating: /opt/ngccli/ngc-cli/grpc/_cython/_credentials/
inflating: /opt/ngccli/ngc-cli/grpc/_cython/_credentials/roots.pem
inflating: /opt/ngccli/ngc-cli/grpc/_cython/cygrpc.cpython-39-x86_64-linux-gnu.so
inflating: /opt/ngccli/ngc-cli/libffi-9c61262e.so.8.1.0
creating: /opt/ngccli/ngc-cli/boto3/
creating: /opt/ngccli/ngc-cli/boto3/examples/
inflating: /opt/ngccli/ngc-cli/boto3/examples/s3.rst
inflating: /opt/ngccli/ngc-cli/boto3/examples/cloudfront.rst
creating: /opt/ngccli/ngc-cli/boto3/data/
creating: /opt/ngccli/ngc-cli/boto3/data/iam/
creating: /opt/ngccli/ngc-cli/boto3/data/iam/2010-05-08/
inflating: /opt/ngccli/ngc-cli/boto3/data/iam/2010-05-08/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/sns/
creating: /opt/ngccli/ngc-cli/boto3/data/sns/2010-03-31/
inflating: /opt/ngccli/ngc-cli/boto3/data/sns/2010-03-31/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/glacier/
creating: /opt/ngccli/ngc-cli/boto3/data/glacier/2012-06-01/
inflating: /opt/ngccli/ngc-cli/boto3/data/glacier/2012-06-01/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/ec2/
creating: /opt/ngccli/ngc-cli/boto3/data/ec2/2014-10-01/
inflating: /opt/ngccli/ngc-cli/boto3/data/ec2/2014-10-01/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/ec2/2016-11-15/
inflating: /opt/ngccli/ngc-cli/boto3/data/ec2/2016-11-15/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/ec2/2015-03-01/
inflating: /opt/ngccli/ngc-cli/boto3/data/ec2/2015-03-01/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/ec2/2015-10-01/
inflating: /opt/ngccli/ngc-cli/boto3/data/ec2/2015-10-01/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/ec2/2015-04-15/
inflating: /opt/ngccli/ngc-cli/boto3/data/ec2/2015-04-15/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/ec2/2016-04-01/
inflating: /opt/ngccli/ngc-cli/boto3/data/ec2/2016-04-01/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/ec2/2016-09-15/
inflating: /opt/ngccli/ngc-cli/boto3/data/ec2/2016-09-15/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/opsworks/
creating: /opt/ngccli/ngc-cli/boto3/data/opsworks/2013-02-18/
inflating: /opt/ngccli/ngc-cli/boto3/data/opsworks/2013-02-18/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/cloudwatch/
creating: /opt/ngccli/ngc-cli/boto3/data/cloudwatch/2010-08-01/
inflating: /opt/ngccli/ngc-cli/boto3/data/cloudwatch/2010-08-01/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/cloudformation/
creating: /opt/ngccli/ngc-cli/boto3/data/cloudformation/2010-05-15/
inflating: /opt/ngccli/ngc-cli/boto3/data/cloudformation/2010-05-15/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/dynamodb/
creating: /opt/ngccli/ngc-cli/boto3/data/dynamodb/2012-08-10/
inflating: /opt/ngccli/ngc-cli/boto3/data/dynamodb/2012-08-10/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/sqs/
creating: /opt/ngccli/ngc-cli/boto3/data/sqs/2012-11-05/
inflating: /opt/ngccli/ngc-cli/boto3/data/sqs/2012-11-05/resources-1.json
creating: /opt/ngccli/ngc-cli/boto3/data/s3/
creating: /opt/ngccli/ngc-cli/boto3/data/s3/2006-03-01/
inflating: /opt/ngccli/ngc-cli/boto3/data/s3/2006-03-01/resources-1.json
inflating: /opt/ngccli/ngc-cli/libssl.so.10
creating: /opt/ngccli/ngc-cli/frozenlist/
inflating: /opt/ngccli/ngc-cli/frozenlist/_frozenlist.cpython-39-x86_64-linux-gnu.so
extracting: /opt/ngccli/ngc-cli.md5
chmod: cannot access ‘/opt/ngccli/ngc’: No such file or directory
me****@me****-rtx3080:~$ nvidia-smi
Wed Nov 2 05:01:20 2022
| NVIDIA-SMI 515.76 Driver Version: 515.76 CUDA Version: 11.7 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 On | N/A |
| 0% 38C P8 19W / 350W | 387MiB / 12288MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 900 G /usr/lib/xorg/Xorg 35MiB |
| 0 N/A N/A 1565 G /usr/lib/xorg/Xorg 78MiB |
| 0 N/A N/A 1689 G /usr/bin/gnome-shell 75MiB |
| 0 N/A N/A 1999 G /usr/lib/firefox/firefox 182MiB |
