I am interested to know how the TLT evaluation step works in comparison with other accuracy calculations from different training platforms. I am trying to do a comparison of a TLT model against others and just need some context to better interpret the results. When running the evaluation step, I notice that there is a check for all ground-truth against the predictions. Is this the only check in accuracy? There are no results for recall or false positives, so is the accuracy only calculated based on the ground-truth against the predictions? Or are false positives taken into account?
Matching predictions to ground truth, class 1/5.: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████| 21236/21236 [00:01<00:00, 16191.39it/s]
Matching predictions to ground truth, class 2/5.: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████| 3792/3792 [00:00<00:00, 39779.90it/s]
Matching predictions to ground truth, class 3/5.: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████| 2870/2870 [00:00<00:00, 18457.39it/s]
Matching predictions to ground truth, class 4/5.: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████| 71006/71006 [00:04<00:00, 14740.07it/s]
Matching predictions to ground truth, class 5/5.: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████████| 1212/1212 [00:00<00:00, 17172.99it/s]
