I’m using Detectnet V2, human head detection. Got my dataset, I isolated 100 images for this to find the cause of the error, made the tfrecord folds using tlt-dataset-convert. All images resized (960x544) to match the network input and bounding boxes adjusted. Upon running tlt-train, I can see that graph.pbtxt is produced, but I don’t have any checkpoints being made, and the train process errors with:
2020-05-06 13:33:46,120 [INFO] iva.detectnet_v2.scripts.train: Found 95 samples in training set
target/truncation is not updated to match the crop areaif the dataset contains target/truncation.
2020-05-06 13:34:05,899 [INFO] iva.detectnet_v2.scripts.train: Found 5 samples in validation set
File "/usr/local/bin/tlt-train-g1", line 8, in <module>
sys.exit(main())
File "./common/magnet_train.py", line 47, in main
File "<decorator-gen-2>", line 2, in main
File "./detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
File "./detectnet_v2/scripts/train.py", line 667, in main
File "./detectnet_v2/scripts/train.py", line 591, in run_experiment
File "./detectnet_v2/scripts/train.py", line 525, in train_gridbox
File "./detectnet_v2/scripts/train.py", line 142, in run_training_loop
File "./detectnet_v2/training/utilities.py", line 143, in get_singular_monitored_session
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 1021, in __init__
stop_grace_period_secs=stop_grace_period_secs)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 650, in __init__
self._sess = self._coordinated_creator.create_session()
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/monitored_session.py", line 812, in create_session
hook.after_create_session(self.tf_sess, self.coord)
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/training/basic_session_run_hooks.py", line 568, in after_create_session
self._save(session, global_step)
File "./detectnet_v2/tfhooks/checkpoint_saver_hook.py", line 77, in _save
File "./detectnet_v2/tfhooks/checkpoint_saver_hook.py", line 110, in _save_encrypted_checkpoint
IOError: [Errno 2] No such file or directory: 'trained/model.step-0.ckzip'
Shouldn’t the training process create these checkpoints? In training_config the checkpoint_interval is set to 10. I am using docker with mounted volume from the host PC, if that is of any help. Using this to launch the training:
root@351b316abd94:/usr/src/headcount# tlt-train detectnet_v2 -e detectnet_v2_train_resnet18_kitti.txt -r trained -k tlt_encode -n resnet18_detector --gpus 1
Spec file:
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/usr/src/headcount/tfrecords/*"
image_directory_path: "/usr/src/headcount/tinyset"
image_extension: "jpeg"
target_class_mapping {
key: "head"
value: "head"
validation_fold: 0
model_config {
arch: "resnet"
pretrained_model_file: "/usr/src/headcount/pretrained/tlt_pretrained_detectnet_v2_vresnet18/resnet18.hdf5"
freeze_blocks: 0
freeze_blocks: 1
all_projections: True
num_layers: 18
use_pooling: False
use_batch_norm: True
dropout_rate: 0.0
training_precision {
backend_floatx: FLOAT32
objective_set {
cov { }
bbox {
scale: 35.0
offset: 0.5
bbox_rasterizer_config {
target_class_config {
key: "head"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
bbox_min_radius: 1.0
deadzone_radius: 0.67
postprocessing_config {
key: "head"
value {
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.15
dbscan_min_samples: 0.05
minimum_bounding_box_height: 20
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
enable_autoweighting: True
min_objective_weight: 0.0001
max_objective_weight: 0.9999
training_config {
batch_size_per_gpu: 26
num_epochs: 80
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
epsilon: 1e-08
beta1: 0.9
beta2: 0.999
cost_scaling {
enabled: False
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 1
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 544
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
evaluation_config {
average_precision_mode: INTEGRATE
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "head"
value: 0.5
evaluation_box_config {
key: "head"
value {
minimum_height: 4
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
Couldn’t find anything related to this error, what is the problem here? Any help appreciated.
