Converting Tfrecords for kitti trainval dataset
2022-10-26 06:29:12.620037: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Using TensorFlow backend.
2022-10-26 06:29:24,381 - iva.detectnet_v2.dataio.build_converter - INFO - Instantiating a kitti converter
2022-10-26 06:29:24,393 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Num images in
Train: 1836 Val: 203
2022-10-26 06:29:24,393 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Validation data in partition 0. Hence, while choosing the validationset during training choose validation_fold 0.
2022-10-26 06:29:24,395 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 0
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py:142: The name tf.python_io.TFRecordWriter is deprecated. Please use tf.io.TFRecordWriter instead.
2022-10-26 06:29:24,395 - tensorflow - WARNING - From /home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py:142: The name tf.python_io.TFRecordWriter is deprecated. Please use tf.io.TFRecordWriter instead.
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: VisibleDeprecationWarning: Reading unicode strings without specifying the encoding argument is deprecated. Set the encoding, use None for the system default.
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66592.txt"
2022-10-26 06:29:24,830 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 1
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66500.txt"
2022-10-26 06:29:25,173 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 2
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame7970.txt"
2022-10-26 06:29:25,420 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 3
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame8000.txt"
2022-10-26 06:29:25,780 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 4
2022-10-26 06:29:26,062 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 5
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame11960.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66400.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65084.txt"
2022-10-26 06:29:26,312 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 6
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65040.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame122.txt"
2022-10-26 06:29:26,522 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 7
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame24022.txt"
2022-10-26 06:29:26,769 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 8
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame3628.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame23666.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame7606.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame19482.txt"
2022-10-26 06:29:27,067 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 9
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame23676.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1764.txt"
2022-10-26 06:29:27,399 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO -
Wrote the following numbers of objects:
b'target': 187
2022-10-26 06:29:27,399 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 0
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame18276.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame23686.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame12630.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66394.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1628.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame112.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame2688.txt"
2022-10-26 06:29:30,221 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 1
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66572.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66612.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66602.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame126.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame7990.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame4086.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65500.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66510.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame116.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66610.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1766.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame2716.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame11930.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame74940.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame74960.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65050.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame2690.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame26282.txt"
2022-10-26 06:29:32,734 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 2
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame24012.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame55490.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame26272.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66404.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66530.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame7596.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame13316.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame7960.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65104.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame15326.txt"
2022-10-26 06:29:35,448 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 3
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame7824.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame15306.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame3832.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame118.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame11940.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame2718.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66580.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame18256.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame394.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame74932.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame6688.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame19492.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66582.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame13306.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame3626.txt"
2022-10-26 06:29:38,279 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 4
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65124.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame3622.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66590.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1632.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65020.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame6128.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame7980.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame56182.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame6690.txt"
2022-10-26 06:29:40,840 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 5
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame12640.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66490.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65510.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame74942.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66390.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1762.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65030.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66402.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65094.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame3834.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66600.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1626.txt"
2022-10-26 06:29:43,449 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 6
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame56180.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame13336.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame13346.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66520.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame3624.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame6698.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame4084.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame4088.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65520.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame7816.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame74950.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame23656.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1624.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66570.txt"
2022-10-26 06:29:46,430 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 7
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1748.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame55480.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame6700.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame114.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame3862.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame124.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame74962.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame120.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame56178.txt"
2022-10-26 06:29:49,496 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 8
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame19502.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame15336.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame11950.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame55470.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame74930.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame12620.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame66392.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65530.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame6100.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame19472.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame1630.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame26292.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame21594.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame65114.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame3860.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame6072.txt"
2022-10-26 06:29:52,304 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 9
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame15316.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame130.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame55500.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame13326.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame74952.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame18266.txt"
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: UserWarning: genfromtxt: Empty input file: "/workspace/tlt-experiments/data/training/label_2/frame128.txt"
2022-10-26 06:29:55,340 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO -
b'target': 1719
2022-10-26 06:29:55,340 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Cumulative object statistics
b'target': 1906
2022-10-26 06:29:55,340 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Class map.
Label in GT: Label in tfrecords file
b'target': b'target'
For the dataset_config in the experiment_spec, please use labels in the tfrecords file, while writing the classmap.
2022-10-26 06:29:55,341 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Tfrecords generation complete.
