Yes, I did run with 3gpus.
The Mapillary dataset has images with high resolution, such as 4000 x 3000. Could you try to offline resize the original images and the json files before training?
In the json file, please resize the bbox and segmentation to a smaller value.
For example, resizing to 1/4 width or height.
import json
import shutiltarget_json = “./new.json”
JSON file
f = open (‘old.json’, “r”)
Reading from file
data = json.loads(f.read())for i in data[‘annotations’]:
i['bbox'] = [ b/4 for b in i['bbox']]
for num in range(len(i['segmentation'])): i['segmentation'][num] = [ b/4 for b in i['segmentation'][num] ] i['width'] = int(i['width'] /4) i['height'] = int(i['height'] /4)
for i in data[‘images’]:
with open(target_json, “w”) as j:
json.dump(data, j)
Closing file
f.close()
OK. I’ll have try. Thanks.
But what the bigest size of image W&H is supported? What’s the relationship between images size and GPUs? What’s the basic requirement of GPUs if I do need to train with such kind of high resolution images?
I resized both train and val images to 1/4 width and height, and also resize the bbox and segmentation to 1/4 in the json files following your script. But there’s some OOM related errors?
[MaskRCNN] INFO : # ============================================= #
[MaskRCNN] INFO : Start Training
[MaskRCNN] INFO : # %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% #
[GPU 00] Restoring pretrained weights (265 Tensors) from: /tmp/tmpkjzp4kam
[MaskRCNN] INFO : Pretrained weights loaded with success...
2021-05-24 06:19:06.296446: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 06:19:06.478044: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 06:19:09.491509: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -12 must be >= 0
2021-05-24 06:19:09.491511: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -3 must be >= 0
2021-05-24 06:19:09.491528: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -4 must be >= 0
2021-05-24 06:19:09.491545: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -60 must be >= 0
2021-05-24 06:19:09.491523: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -10 must be >= 0
2021-05-24 06:19:09.622707: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -33 must be >= 0
2021-05-24 06:19:15.574655: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
[MaskRCNN] INFO : Saving checkpoints for 0 into /workspace/tlt-experiments/maskrcnn/experiment_dir_unpruned/model.step-0.tlt.
2021-05-24 06:19:20.785157: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-05-24 06:19:22.581639: W tensorflow/core/common_runtime/bfc_allocator.cc:239] Allocator (GPU_0_bfc) ran out of memory trying to allocate 3.40GiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-05-24 06:19:23.237281: W tensorflow/core/common_runtime/bfc_allocator.cc:239] Allocator (GPU_0_bfc) ran out of memory trying to allocate 3.40GiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-05-24 06:19:23.266958: W tensorflow/core/common_runtime/bfc_allocator.cc:239] Allocator (GPU_0_bfc) ran out of memory trying to allocate 3.40GiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-05-24 06:19:23.780393: W tensorflow/core/common_runtime/bfc_allocator.cc:239] Allocator (GPU_0_bfc) ran out of memory trying to allocate 3.40GiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
2021-05-24 06:19:30.714398: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 06:19:31.167231: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -2 must be >= 0
2021-05-24 06:19:31.168759: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -13 must be >= 0
2021-05-24 06:19:31.176579: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -1 must be >= 0
2021-05-24 06:19:31.182869: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -18 must be >= 0
2021-05-24 06:19:31.486122: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -162 must be >= 0
[MaskRCNN] INFO : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
[MaskRCNN] INFO : Training Performance Summary
DLL 2021-05-24 06:19:38.026495 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-05-24 06:19:38.026872 - : Training Performance Summary
DLL 2021-05-24 06:19:38.026945 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-05-24 06:19:38.027059 - Average_throughput : -1.0 samples/sec
DLL 2021-05-24 06:19:38.027154 - Total processed steps : 1
DLL 2021-05-24 06:19:38.027253 - Total_processing_time : 0h 00m 00s
[MaskRCNN] INFO : Average throughput: -1.0 samples/sec
[MaskRCNN] INFO : Total processed steps: 1
[MaskRCNN] INFO : Total processing time: 0h 00m 00s
DLL 2021-05-24 06:19:38.027699 - : ==================== Metrics ====================
[MaskRCNN] INFO : ==================== Metrics ====================
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1365, in _do_call
return fn(*args)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1350, in _run_fn
target_list, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InvalidArgumentError: 2 root error(s) found.
(0) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_15584}} Dimension -13 must be >= 0
[[{{node parser/ones_5}}]]
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
[[DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_box_head_class_predict_BiasAdd_grad_tuple_control_dependency_1_0/_5793]]
(1) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_15584}} Dimension -13 must be >= 0
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
File "/usr/local/bin/tlt-train-g1", line 8, in <module>
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/magnet_train.py", line 58, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 187, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 90, in run_executer
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/distributed_executer.py", line 393, in train_and_eval
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 370, in train
loss = self._train_model(input_fn, hooks, saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1161, in _train_model
return self._train_model_default(input_fn, hooks, saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1195, in _train_model_default
saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1494, in _train_with_estimator_spec
_, loss = mon_sess.run([estimator_spec.train_op, estimator_spec.loss])
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 754, in run
run_metadata=run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1259, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1360, in run
raise six.reraise(*original_exc_info)
File "/usr/local/lib/python3.6/dist-packages/six.py", line 693, in reraise
raise value
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1345, in run
return self._sess.run(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1418, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1176, in run
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 956, in run
run_metadata_ptr)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1180, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1359, in _do_run
run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1384, in _do_call
raise type(e)(node_def, op, message)
(0) Invalid argument: Dimension -13 must be >= 0
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
(1) Invalid argument: Dimension -13 must be >= 0
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
[MaskRCNN] ERROR : Job finished with an uncaught exception: `FAILURE`
Using TensorFlow backend.
return fn(*args)
run_metadata)
tensorflow.python.framework.errors_impl.UnknownError: 2 root error(s) found.
(0) Unknown: Horovod has been shut down. This was caused by an exception on one of the ranks or an attempt to allreduce, allgather or broadcast a tensor after one of the ranks finished execution. If the shutdown was caused by an exception, you should see the exception in the log before the first shutdown message.
[[{{node DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_AddN_178_0}}]]
[[DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_box_head_class_predict_BiasAdd_grad_tuple_control_dependency_1_0/_4253]]
(1) Unknown: Horovod has been shut down. This was caused by an exception on one of the ranks or an attempt to allreduce, allgather or broadcast a tensor after one of the ranks finished execution. If the shutdown was caused by an exception, you should see the exception in the log before the first shutdown message.
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
[[node DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_AddN_178_0 (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
Original stack trace for 'DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_AddN_178_0':
sys.exit(main())
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1191, in _train_model_default
features, labels, ModeKeys.TRAIN, self.config)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1149, in _call_model_fn
model_fn_results = self._model_fn(features=features, **kwargs)
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/models/mask_rcnn_model.py", line 548, in mask_rcnn_model_fn
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/models/mask_rcnn_model.py", line 493, in _model_fn
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 256, in compute_gradients
avg_grads = self._allreduce_grads(grads)
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 210, in allreduce_grads
for grad in grads]
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 210, in <listcomp>
for grad in grads]
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py", line 80, in allreduce
summed_tensor_compressed = _allreduce(tensor_compressed)
File "/usr/local/lib/python3.6/dist-packages/horovod/tensorflow/mpi_ops.py", line 86, in _allreduce
return MPI_LIB.horovod_allreduce(tensor, name=name)
File "<string>", line 80, in horovod_allreduce
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/op_def_library.py", line 794, in _apply_op_helper
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 507, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3357, in create_op
attrs, op_def, compute_device)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3426, in _create_op_internal
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1748, in __init__
self._traceback = tf_stack.extract_stack()
return fn(*args)
run_metadata)
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
sys.exit(main())
for grad in grads]
for grad in grads]
op_def=op_def)
op_def=op_def)
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun.real detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[37734,1],0]
Exit code: 1
What is the image_size
in your training spec? Can it run (128,128) successfully?
Currently, some of the parameters (prefetching size, shuffle_buffer, block_length, etc) in current dataloader is optimized for COCO style training, which means the original images are 500 x 500ish or even smaller. The Mapillary dataset has images of 4500 x 5000. So when GPU tries to load those original size images into memory, OOM occurs.
TLT team will implement a feature to config DL parameters in next release.
I was using “(768, 1024)”, change to “(128, 128)” still doesn’t help.
[GPU 00] Restoring pretrained weights (265 Tensors) from: /tmp/tmpcb1rpu8y
2021-05-24 06:58:22.138885: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 06:58:22.352817: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 06:58:22.479998: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -60 must be >= 0
2021-05-24 06:58:22.762021: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -10 must be >= 0
2021-05-24 06:58:22.767027: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -3 must be >= 0
2021-05-24 06:58:22.767148: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -4 must be >= 0
2021-05-24 06:58:22.770139: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -12 must be >= 0
2021-05-24 06:58:22.820162: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -33 must be >= 0
2021-05-24 06:58:25.048537: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-05-24 06:58:26.628053: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-05-24 06:58:43.097873: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 06:58:43.442445: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -13 must be >= 0
2021-05-24 06:58:43.448116: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -2 must be >= 0
2021-05-24 06:58:43.449753: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -1 must be >= 0
2021-05-24 06:58:43.450463: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -18 must be >= 0
2021-05-24 06:58:43.789648: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -162 must be >= 0
DLL 2021-05-24 06:58:48.191844 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-05-24 06:58:48.192109 - : Training Performance Summary
DLL 2021-05-24 06:58:48.192176 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-05-24 06:58:48.192257 - Average_throughput : -1.0 samples/sec
DLL 2021-05-24 06:58:48.192314 - Total processed steps : 1
DLL 2021-05-24 06:58:48.192382 - Total_processing_time : 0h 00m 00s
DLL 2021-05-24 06:58:48.192726 - : ==================== Metrics ====================
return fn(*args)
run_metadata)
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
[[DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_AddN_70_0/_5961]]
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
return fn(*args)
run_metadata)
[[DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_AddN_70_0/_4421]]
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
sys.exit(main())
for grad in grads]
for grad in grads]
op_def=op_def)
op_def=op_def)
return fn(*args)
run_metadata)
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
sys.exit(main())
for grad in grads]
for grad in grads]
op_def=op_def)
op_def=op_def)
Process name: [[36151,1],0]
Exit code: 1
So which means there’s no walk around solution for training those kind of high resolution images until your next release?
Currently, the workaround is that resizing images to smaller ones and also resizing the bbox/segmentaion of json file accordingly.
Now I even resize images to their 1/8 size (like 400x300) and also resize bbox/segmentation of json file accrodingly. image_size set to (128, 128). The training process was still terminated as below.
[GPU 00] Restoring pretrained weights (265 Tensors) from: /tmp/tmpflhi4tpr
2021-05-24 08:29:58.526693: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 08:29:58.784876: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 08:29:58.864883: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -60 must be >= 0
2021-05-24 08:29:59.167635: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -3 must be >= 0
2021-05-24 08:29:59.170133: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -10 must be >= 0
2021-05-24 08:29:59.171645: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -12 must be >= 0
2021-05-24 08:29:59.172364: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -4 must be >= 0
2021-05-24 08:29:59.204109: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -33 must be >= 0
2021-05-24 08:29:59.394731: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-05-24 08:29:59.662386: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2021-05-24 08:30:19.027425: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2021-05-24 08:30:19.394698: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -2 must be >= 0
2021-05-24 08:30:19.396985: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -18 must be >= 0
2021-05-24 08:30:19.400412: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -13 must be >= 0
2021-05-24 08:30:19.401842: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -1 must be >= 0
2021-05-24 08:30:19.443373: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at constant_op.cc:170 : Invalid argument: Dimension -162 must be >= 0
DLL 2021-05-24 08:30:20.345885 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-05-24 08:30:20.346254 - : Training Performance Summary
DLL 2021-05-24 08:30:20.346321 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-05-24 08:30:20.346396 - Average_throughput : -1.0 samples/sec
DLL 2021-05-24 08:30:20.346459 - Total processed steps : 1
DLL 2021-05-24 08:30:20.346554 - Total_processing_time : 0h 00m 00s
DLL 2021-05-24 08:30:20.346949 - : ==================== Metrics ====================
return fn(*args)
run_metadata)
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
[[IteratorGetNext]]
[[RemoteCall]]
[[IteratorGetNext]]
return fn(*args)
run_metadata)
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
sys.exit(main())
for grad in grads]
for grad in grads]
op_def=op_def)
op_def=op_def)
return fn(*args)
run_metadata)
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
sys.exit(main())
for grad in grads]
for grad in grads]
op_def=op_def)
op_def=op_def)
Process name: [[33836,1],0]
Exit code: 1
I verified with only one image. Resizing the images can work.
I will check more images.
BTW, can you double check if the tfrecords are generated via the resized images/json file?
Yes, I re-generated the tfrecords everytime after I resized the images and json files.
Please use TLT 3.0_dp docker.
In your random500 folder, I resize all the images to 1/8 size and also modify their bbox/segmentation in json file.
Generate tfrecords and trigger training. There is no OOM issue. BTW, I am using GeForce GTX 1080 Ti card.
Hi, I’m using TLT 3.0_dp docker now.
As above, with 1000 train and 500 val images which resized to 1/8 size and modified json file, generated to tfrecords, image_size set to (128, 128) in spec, I still got OOM error…and it seams my GPUs were not fully in use in training. Would you please share with me how you process the data? or share with me your resized data and let me have a try?
| NVIDIA-SMI 465.19.01 Driver Version: 465.19.01 CUDA Version: 11.3 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:02:00.0 Off | N/A |
| 33% 61C P2 42W / 180W | 4401MiB / 8110MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce … Off | 00000000:03:00.0 Off | N/A |
| 26% 38C P8 7W / 180W | 2MiB / 8119MiB | 0% Default |
| | | N/A |
| 2 NVIDIA GeForce … Off | 00000000:81:00.0 Off | N/A |
| 26% 33C P8 7W / 180W | 2MiB / 8119MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 5586 G /usr/lib/xorg/Xorg 49MiB |
| 0 N/A N/A 12993 C /usr/bin/python3.6 1445MiB |
| 0 N/A N/A 12994 C /usr/bin/python3.6 1445MiB |
| 0 N/A N/A 12995 C /usr/bin/python3.6 1445MiB |
2021-05-28 03:13:26.226480: I tensorflow/core/common_runtime/bfc_allocator.cc:921] Sum Total of in-use chunks: 992.46MiB
2021-05-28 03:13:26.226489: I tensorflow/core/common_runtime/bfc_allocator.cc:923] total_region_allocated_bytes_: 1074790400 memory_limit_: 7356350464 available bytes: 6281560064 curr_region_allocation_bytes_: 4294967296
2021-05-28 03:13:26.226503: I tensorflow/core/common_runtime/bfc_allocator.cc:929] Stats:
Limit: 7356350464
InUse: 1040670464
MaxInUse: 2197049344
NumAllocs: 3971
MaxAllocSize: 1162084352
2021-05-28 03:13:26.226602: W tensorflow/core/common_runtime/bfc_allocator.cc:424] ***********************************************__***********************xx**************************
2021-05-28 03:13:26.240873: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:26.241995: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:26.243222: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:26.247840: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:26.248646: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:26.249687: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:36.251831: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:36.254185: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:36.256596: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:36.258936: I tensorflow/stream_executor/cuda/cuda_driver.cc:802] failed to allocate 4.00G (4294967296 bytes) from device: CUDA_ERROR_OUT_OF_MEMORY: out of memory
2021-05-28 03:13:36.259018: W tensorflow/core/common_runtime/bfc_allocator.cc:419] Allocator (GPU_0_bfc) ran out of memory trying to allocate 64.00MiB (rounded to 67108864). Current allocation summary follows.
2021-05-28 03:13:36.259190: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (256): Total Chunks: 436, Chunks in use: 435. 109.0KiB allocated for chunks. 108.8KiB in use in bin. 22.1KiB client-requested in use in bin.
2021-05-28 03:13:36.259225: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (512): Total Chunks: 106, Chunks in use: 103. 56.5KiB allocated for chunks. 54.5KiB in use in bin. 53.6KiB client-requested in use in bin.
2021-05-28 03:13:36.259260: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (1024): Total Chunks: 209, Chunks in use: 209. 210.8KiB allocated for chunks. 210.8KiB in use in bin. 209.0KiB client-requested in use in bin.
2021-05-28 03:13:36.259291: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (2048): Total Chunks: 132, Chunks in use: 129. 282.0KiB allocated for chunks. 273.0KiB in use in bin. 270.8KiB client-requested in use in bin.
2021-05-28 03:13:36.259320: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (4096): Total Chunks: 71, Chunks in use: 68. 294.5KiB allocated for chunks. 280.0KiB in use in bin. 273.4KiB client-requested in use in bin.
2021-05-28 03:13:36.259348: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (8192): Total Chunks: 54, Chunks in use: 52. 500.0KiB allocated for chunks. 472.8KiB in use in bin. 464.0KiB client-requested in use in bin.
2021-05-28 03:13:36.259372: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (16384): Total Chunks: 8, Chunks in use: 7. 154.8KiB allocated for chunks. 138.8KiB in use in bin. 110.8KiB client-requested in use in bin.
2021-05-28 03:13:36.259393: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (32768): Total Chunks: 17, Chunks in use: 15. 588.2KiB allocated for chunks. 508.2KiB in use in bin. 505.5KiB client-requested in use in bin.
2021-05-28 03:13:36.259413: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (65536): Total Chunks: 45, Chunks in use: 42. 3.06MiB allocated for chunks. 2.86MiB in use in bin. 2.86MiB client-requested in use in bin.
2021-05-28 03:13:36.259432: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (131072): Total Chunks: 35, Chunks in use: 34. 4.52MiB allocated for chunks. 4.39MiB in use in bin. 4.34MiB client-requested in use in bin.
2021-05-28 03:13:36.259459: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (262144): Total Chunks: 86, Chunks in use: 85. 24.87MiB allocated for chunks. 24.51MiB in use in bin. 23.88MiB client-requested in use in bin.
2021-05-28 03:13:36.259508: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (524288): Total Chunks: 45, Chunks in use: 45. 24.89MiB allocated for chunks. 24.89MiB in use in bin. 24.34MiB client-requested in use in bin.
2021-05-28 03:13:36.259540: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (1048576): Total Chunks: 85, Chunks in use: 84. 93.96MiB allocated for chunks. 92.65MiB in use in bin. 88.34MiB client-requested in use in bin.
2021-05-28 03:13:36.259574: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (2097152): Total Chunks: 86, Chunks in use: 85. 194.61MiB allocated for chunks. 191.03MiB in use in bin. 187.50MiB client-requested in use in bin.
2021-05-28 03:13:36.259604: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (4194304): Total Chunks: 37, Chunks in use: 37. 157.86MiB allocated for chunks. 157.86MiB in use in bin. 138.50MiB client-requested in use in bin.
2021-05-28 03:13:36.259631: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (8388608): Total Chunks: 21, Chunks in use: 20. 191.81MiB allocated for chunks. 181.55MiB in use in bin. 175.00MiB client-requested in use in bin.
2021-05-28 03:13:36.259656: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (16777216): Total Chunks: 2, Chunks in use: 0. 48.94MiB allocated for chunks. 0B in use in bin. 0B client-requested in use in bin.
2021-05-28 03:13:36.259685: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (33554432): Total Chunks: 4, Chunks in use: 4. 196.00MiB allocated for chunks. 196.00MiB in use in bin. 196.00MiB client-requested in use in bin.
2021-05-28 03:13:36.259727: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (67108864): Total Chunks: 1, Chunks in use: 1. 82.34MiB allocated for chunks. 82.34MiB in use in bin. 49.00MiB client-requested in use in bin.
2021-05-28 03:13:36.259746: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (134217728): Total Chunks: 0, Chunks in use: 0. 0B allocated for chunks. 0B in use in bin. 0B client-requested in use in bin.
2021-05-28 03:13:36.259762: I tensorflow/core/common_runtime/bfc_allocator.cc:869] Bin (268435456): Total Chunks: 0, Chunks in use: 0. 0B allocated for chunks. 0B in use in bin. 0B client-requested in use in bin.
2021-05-28 03:13:36.259781: I tensorflow/core/common_runtime/bfc_allocator.cc:885] Bin for 64.00MiB was 64.00MiB, Chunk State:
2021-05-28 03:13:36.259793: I tensorflow/core/common_runtime/bfc_allocator.cc:898] Next region of size 536870912
2021-05-28 03:13:36.291942: I tensorflow/core/common_runtime/bfc_allocator.cc:921] Sum Total of in-use chunks: 939.08MiB
2021-05-28 03:13:36.291960: I tensorflow/core/common_runtime/bfc_allocator.cc:923] total_region_allocated_bytes_: 1074790400 memory_limit_: 7337476096 available bytes: 6262685696 curr_region_allocation_bytes_: 4294967296
2021-05-28 03:13:36.291984: I tensorflow/core/common_runtime/bfc_allocator.cc:929] Stats:
Limit: 7337476096
InUse: 984694528
MaxInUse: 2164732928
NumAllocs: 3974
2021-05-28 03:13:36.292107: W tensorflow/core/common_runtime/bfc_allocator.cc:424] *******************************************_*____***************************************************
return fn(*args)
run_metadata)
(0) Unknown: Unknown error.
[[{{node DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_AddN_41_0}}]]
[[add_25/_4225]]
(1) Unknown: Unknown error.
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/magnet_train.py", line 59, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 192, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 91, in run_executer
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py", line 394, in train_and_eval
saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/six.py", line 696, in reraise
raise value
run_metadata_ptr)
run_metadata)
[[node DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_AddN_41_0 (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
[[add_25/_4225]]
Original stack trace for 'DistributedMomentumOptimizer_Allreduce/HorovodAllreduce_gradients_AddN_41_0':
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/models/mask_rcnn_model.py", line 548, in mask_rcnn_model_fn
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/models/mask_rcnn_model.py", line 493, in _model_fn
for grad in grads]
for grad in grads]
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 513, in new_func
op_def=op_def)
return fn(*args)
run_metadata)
tensorflow.python.framework.errors_impl.ResourceExhaustedError: 2 root error(s) found.
(0) Resource exhausted: OOM when allocating tensor with shape[512,63488] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
[[{{node fast_rcnn_loss/one_hot}}]]
Hint: If you want to see a list of allocated tensors when OOM happens, add report_tensor_allocations_upon_oom to RunOptions for current allocation info.
[[add_25/_4225]]
(1) Resource exhausted: OOM when allocating tensor with shape[512,63488] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
[[node fast_rcnn_loss/one_hot (defined at usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
[[add_25/_4225]]
Original stack trace for 'fast_rcnn_loss/one_hot':
File "usr/local/bin/tlt-train-g1", line 8, in <module>
sys.exit(main())
File "home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/magnet_train.py", line 59, in main
File "home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 192, in main
File "home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 91, in run_executer
File "home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py", line 394, in train_and_eval
File "usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 370, in train
File "usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1161, in _train_model
File "usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1191, in _train_model_default
File "usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1149, in _call_model_fn
File "home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/models/mask_rcnn_model.py", line 548, in mask_rcnn_model_fn
File "home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/models/mask_rcnn_model.py", line 441, in _model_fn
File "home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/training/losses.py", line 367, in fast_rcnn_loss
File "usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/dispatch.py", line 180, in wrapper
return target(*args, **kwargs)
File "usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/array_ops.py", line 3516, in one_hot
name)
File "usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/gen_array_ops.py", line 6137, in one_hot
off_value=off_value, axis=axis, name=name)
File "usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/op_def_library.py", line 794, in _apply_op_helper
op_def=op_def)
File "usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 513, in new_func
File "usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3357, in create_op
File "usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3426, in _create_op_internal
op_def=op_def)
File "usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1748, in __init__
return fn(*args)
run_metadata)
[[add_25/_5765]]
sys.exit(main())
saving_listeners)
raise value
run_metadata_ptr)
run_metadata)
[[add_25/_5765]]
sys.exit(main())
name)
op_def=op_def)
op_def=op_def)
DLL 2021-05-28 03:13:36.890298 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-05-28 03:13:36.890599 - : Training Performance Summary
DLL 2021-05-28 03:13:36.890668 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-05-28 03:13:36.890747 - Average_throughput : -1.0 samples/sec
DLL 2021-05-28 03:13:36.890812 - Total processed steps : 1
DLL 2021-05-28 03:13:36.890884 - Total_processing_time : 0h 00m 00s
DLL 2021-05-28 03:13:36.891261 - : ==================== Metrics ====================
Process name: [[23439,1],2]
Exit code: 1
Please try to train with these tfrecords result0525_images_500_resize.zip - Google Drive
Attach json file too.
instances_random500_shape_validation2020_resize.json (11.2 MB)
Hi. I tried with your tfrecords and json file with command as below:
tlt-train mask_rcnn -e /workspace/examples/maskrcnn/specs/maskrcnn_train_resnet50_vistas.txt \ -d /workspace/tlt-experiments/maskrcnn/experiment_dir_unpruned\ -k XXX \ --gpus 3
Unfortunately I still got the same OOM issue and with nvidia-smi my GPUs were still not fully in used when the OOM error messages came out.
As you mentioned you are using GeForce GTX 1080 Ti card. So I changed my --gpus to 1:
-k XXX
–gpus 1
The OOMs were gone!!! So it seems that the training process were not allocated properly on my 3 gpus and caused the OOM. What can I fix that?
Thanks for the info. I will check with 3 gpus too.
I’ve figured out why the training process were not allocated properly on 3 gpus. That was my mistake. I installed tlt-v3.0-dp docker the same steps as tlt-v2.0, and trained with the same command tlt-train as it’s in tlt-v2.0 which is deprecated in tlt-v3.0.
I reinstalled the tlt-v3.0 with launcher and ran command tlt mask_rcnn train to train with your tfrecords and json on 3 gpus. There’s no OOM issue any more.
But I still met some uncaught exception: FAILURE
when I trained with my own tfrecords. May I know how you resize the tfrecords?
I generate the tfrecords with below steps.
- resize the images to 1/8 size.
resize_image.txt (548 Bytes) - resize the bbox/segmentation of json file
resize_bbox_segmentation.txt (763 Bytes) - generate tfrecords
PYTHONPATH=“tf-models:tf-models/research” python create_coco_tf_record.py --include_masks --train_image_dir=random_500_resize --train_object_annotations_file=instances_random500_shape_validation2020_resize.json -output_dir=./result0525_images_500_resize --train_caption_annotations_file=./captions_val2017.json
Is the captions_val2017.json from COCO dataset? Is it neccessary? Since there’s no captions in Mapillary Vistas dataset, I commented the code related with captions in create_coco_tf_record.py.
