Please have a look at my result training my dataset on YOLOv3 using Transfer Learning Toolkit. I could achieve a reasonably good map when trained the dataset with detectnetv2 and able to transfer it to deepstream but it does not do with YOLOv3.
tlt-streamanalytics:v2.0_py3
Ubuntu 18.04
GPU Geforce 1650 4GB
Dataset :
Image : JPG ( 480*288)
Label : KITTI.
car 0.0 0 0.0 65.8 103.8 146.8 152.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 person 0.0 0 0.0 70.7 80.3 81.3 102.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
TF record config file
kitti_config {
root_directory_path: “/workspace/dataset/training”
image_dir_name: “image_2”
label_dir_name: “label_2”
image_extension: “.jpg”
partition_mode: “random”
num_partitions:2
val_split: 20
num_shards: 10
image_directory_path: “/workspace/dataset/training”
Train config file
random_seed: 42
yolo_config {
big_anchor_shape: “[(84.60, 40.60), (97.70, 61.50), (131.90, 102.10)]”
mid_anchor_shape: “[(63.00, 25.80), (44.20, 39.30), (69.00, 31.50)]”
small_anchor_shape: “[(10.60, 21.00), (15.70, 28.30), (36.00, 26.70)]”
matching_neutral_box_iou: 0.5
arch: “resnet”
nlayers: 18
arch_conv_blocks: 0
loss_loc_weight: 5.0
loss_neg_obj_weights: 50.0
loss_class_weights: 1.0
freeze_bn: True
freeze_blocks: 0
freeze_blocks: 1}
training_config {
batch_size_per_gpu: 5
num_epochs: 10
enable_qat: false
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-5
max_learning_rate: 2e-2
soft_start: 0.15
annealing: 0.8
regularizer {
type: L1
weight: 3e-5
eval_config {
validation_period_during_training: 1
average_precision_mode: INTEGRATE
batch_size: 5
matching_iou_threshold: 0.3
nms_config {
confidence_threshold: 0.01
clustering_iou_threshold: 0.6
top_k: 200
augmentation_config {
preprocessing {
output_image_width: 480
output_image_height: 288
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 0.7
zoom_max: 1.8
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
dataset_config {
data_sources: {
tfrecords_path: “/workspace/tf_records/*”
image_extension: “jpg”
target_class_mapping {
key: “person”
value: “person”
key: “car”
value: “car”
key: “bus”
value: “bus”
key: “truck”
value: “truck”
key: “motorcycle”
value: “motorcycle”
key: “bicycle”
value: “bicycle”
validation_fold: 0
TF records results:
2020-09-27 22:53:39.245952: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Using TensorFlow backend.
2020-09-27 22:53:41,037 - iva.detectnet_v2.dataio.build_converter - INFO - Instantiating a kitti converter
2020-09-27 22:53:41,037 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Creating output directory /workspace/tf_records
2020-09-27 22:53:41,040 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Num images in
Train: 1039 Val: 259
2020-09-27 22:53:41,040 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Validation data in partition 0. Hence, while choosing the validationset during training choose validation_fold 0.
2020-09-27 22:53:41,041 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 0
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py:142: The name tf.python_io.TFRecordWriter is deprecated. Please use tf.io.TFRecordWriter instead.
2020-09-27 22:53:41,041 - tensorflow - WARNING - From /home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py:142: The name tf.python_io.TFRecordWriter is deprecated. Please use tf.io.TFRecordWriter instead.
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: VisibleDeprecationWarning: Reading unicode strings without specifying the encoding argument is deprecated. Set the encoding, use None for the system default.
2020-09-27 22:53:41,063 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 1
2020-09-27 22:53:41,082 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 2
2020-09-27 22:53:41,101 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 3
2020-09-27 22:53:41,119 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 4
2020-09-27 22:53:41,137 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 5
2020-09-27 22:53:41,155 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 6
2020-09-27 22:53:41,172 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 7
2020-09-27 22:53:41,191 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 8
2020-09-27 22:53:41,209 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 9
2020-09-27 22:53:41,234 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO -
Wrote the following numbers of objects:
b’car’: 266
b’person’: 250
b’bus’: 53
b’motorcycle’: 3
b’truck’: 14
b’bicycle’: 7
2020-09-27 22:53:41,234 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 0
2020-09-27 22:53:41,306 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 1
2020-09-27 22:53:41,379 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 2
2020-09-27 22:53:41,451 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 3
2020-09-27 22:53:41,525 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 4
2020-09-27 22:53:41,599 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 5
2020-09-27 22:53:41,673 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 6
2020-09-27 22:53:41,752 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 7
2020-09-27 22:53:41,838 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 8
2020-09-27 22:53:41,922 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 9
2020-09-27 22:53:42,014 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO -
b’person’: 1037
b’car’: 935
b’truck’: 46
b’bus’: 206
b’motorcycle’: 12
b’bicycle’: 13
2020-09-27 22:53:42,014 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Cumulative object statistics
b’car’: 1201
b’person’: 1287
b’bus’: 259
b’motorcycle’: 15
b’truck’: 60
b’bicycle’: 20
2020-09-27 22:53:42,014 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Class map.
Label in GT: Label in tfrecords file
b’car’: b’car’
b’person’: b’person’
b’bus’: b’bus’
b’motorcycle’: b’motorcycle’
b’truck’: b’truck’
b’bicycle’: b’bicycle’
For the dataset_config in the experiment_spec, please use labels in the tfrecords file, while writing the classmap.
2020-09-27 22:53:42,014 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Tfrecords generation complete.
Train result
Epoch 8/10
208/208 [==============================] - 46s 220ms/step - loss: 10.3667
Epoch 00008: saving model to /workspace/trained_model_yolo/weights/yolo_resnet18_epoch_008.tlt
Number of images in the evaluation dataset: 259
Producing predictions: 100%|████████████████████| 52/52 [00:06<00:00, 7.55it/s]
Start multi-thread per-image matching
Start to calculate AP for each class
bicycle AP 0.0
bus AP 0.0
car AP 0.0
motorcycle AP 0.0
person AP 0.0
truck AP 0.0
mAP 0.0
Epoch 9/10
208/208 [==============================] - 45s 215ms/step - loss: 9.3539
Epoch 00009: saving model to /workspace/trained_model_yolo/weights/yolo_resnet18_epoch_009.tlt
Producing predictions: 100%|████████████████████| 52/52 [00:06<00:00, 7.63it/s]
bicycle AP 0.0
bus AP 0.0
car AP 0.0
motorcycle AP 0.0
person AP 0.0
truck AP 0.0
mAP 0.0
Epoch 10/10
208/208 [==============================] - 46s 220ms/step - loss: 8.7018
Epoch 00010: saving model to /workspace/trained_model_yolo/weights/yolo_resnet18_epoch_010.tlt
Producing predictions: 100%|████████████████████| 52/52 [00:06<00:00, 7.52it/s]
bicycle AP 0.0
bus AP 0.0
car AP 0.0
motorcycle AP 0.0
person AP 0.0
truck AP 0.0
mAP 0.0
I tried to reduce the Iou threshold to 0.5,0.3, and 0.2 and also using kmeans.py to obtain anchor shapes but still achieved 0 mAp.
The training shows a similar result (0 mAp) for 10 epochs, 50 epoch, and 120 epochs.
Are there any wrongs in my config file?
cheers!
