• Hardware (940MX)
• Network Type (Detectnet_v2/Yolo_4/any)
Configuration of the TLT Instance
docker:
nvidia/tlt-streamanalytics:
docker_registry: nvcr.io
docker_tag: v3.0-py3
tasks:
- augment
- bpnet
- classification
- detectnet_v2
- dssd
- emotionnet
- faster_rcnn
- fpenet
- gazenet
- gesturenet
- heartratenet
- lprnet
- mask_rcnn
- multitask_classification
- retinanet
- ssd
- unet
- yolo_v3
- yolo_v4
- tlt-converter
nvidia/tlt-pytorch:
tasks: - speech_to_text
- speech_to_text_citrinet
- text_classification
- question_answering
- token_classification
- intent_slot_classification
- punctuation_and_capitalization
format_version: 1.0
tlt_version: 3.0
published_date: 04/16/2021
docker_tag: nvcr.io/nvidia/tlt-streamanalytics:v3.0-py3
Error Log:
Epoch 1/80
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 221, in
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 494, in return_func
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 482, in return_func
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 217, in main
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 173, in run_experiment
File “/usr/local/lib/python3.6/dist-packages/keras/legacy/interfaces.py”, line 91, in wrapper
return func(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1418, in fit_generator
initial_epoch=initial_epoch)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training_generator.py”, line 217, in fit_generator
class_weight=class_weight)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1217, in train_on_batch
outputs = self.train_function(ins)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2715, in call
return self._call(inputs)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2671, in _call
session)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2623, in _make_callable
callable_fn = session._make_callable_from_options(callable_opts)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1505, in _make_callable_from_options
return BaseSession._Callable(self, callable_options)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1460, in init
session._session, options_ptr)
tensorflow.python.framework.errors_impl.InvalidArgumentError: Default MaxPoolingOp only supports NHWC on device type CPU
[[{{node yolo_spp_pool_1_1/MaxPool}}]]
2021-07-08 08:06:03,035 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
