• training on NGC
• Yolo_v4
• TLT Version
Configuration of the TLT Instance
dockers:
nvidia/tlt-streamanalytics:
docker_registry: nvcr.io
docker_tag: v3.0-py3
tasks:
1. augment
2. bpnet
3. classification
4. detectnet_v2
5. dssd
6. emotionnet
7. faster_rcnn
8. fpenet
9. gazenet
10. gesturenet
11. heartratenet
12. lprnet
13. mask_rcnn
14. multitask_classification
15. retinanet
16. ssd
17. unet
18. yolo_v3
19. yolo_v4
20. tlt-converter
nvidia/tlt-pytorch:
tasks:
1. speech_to_text
2. speech_to_text_citrinet
3. text_classification
4. question_answering
5. token_classification
6. intent_slot_classification
7. punctuation_and_capitalization
format_version: 1.0
tlt_version: 3.0
published_date: 04/16/2021
• Training spec file
random_seed: 42
yolov4_config {
big_anchor_shape: "[(26.00, 54.00), (47.00, 77.00), (79.00, 135.00)]"
mid_anchor_shape: "[(15.00, 26.00), (16.00, 40.00), (21.00, 34.00)]"
small_anchor_shape: "[(7.00, 14.00), (9.00, 19.00), (11.00, 29.00)]"
box_matching_iou: 0.5
# matching_neutral_box_iou: 0.5
arch: "darknet"
nlayers: 53
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 0.5
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 16
num_epochs: 200
enable_qat: true
checkpoint_interval: 50
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
# pretrain_model_path: "/workspace/yolo/pretrained_model/resnet_18.hdf5"
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 960
output_height: 544
output_channel: 3
randomize_input_shape_period: 0
mosaic_prob: 0.5
mosaic_min_ratio:0.2
image_mean {
key: 'b'
value: 103.9
image_mean {
key: 'g'
value: 116.8
image_mean {
key: 'r'
value: 123.7
dataset_config {
data_sources: {
label_directory_path: "/data/img"
image_directory_path: "/data/label"
include_difficult_in_training: false
target_class_mapping {
key: "adult"
value: "adult"
key: "child"
value: "child"
validation_data_sources: {
label_directory_path: "/data/label"
image_directory_path: "/data/img"
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
2021-06-23 07:06:06,800 [INFO] __main__: Number of images in the training dataset: 0
Image data are not loaded.
This forum is same case but it was not file extension problem.
Image files are not crashed. Also I put right path as I checked.
