Hello Jon,
Here Is a complete breakdown of the changes I have made to get TLV320AIC32X4 working with the TX2i. Hopefully, this helps some other new to audio codec figure things out.
Anyone can use these modifications hoping that NVidia will find the time to embed these modifications or others to support future uses who intend to use audio CODECs like the TLV320AIC32x4.
Environment:-
Jetpack 4.3 with The target Jetson TX2i is programmed with L4T 32.4*
Here is the Device tree changes:
File Path: /home/parashuram/Linux_for_Tegra/sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi
diff --git a/kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi b/kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi
old mode 100644
new mode 100755
index 9416a21..2fb56f5
--- a/kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi
+++ b/kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi
@@ -166,6 +166,18 @@
rom-val = /bits/ 8 <0x05>;
+ aic32x4: tlv320aic32x4.1-0018@18 {
+ compatible = "ti,tlv320aic32x4";
+ status = "okay";
+ reg = <0x18>;
+ clocks = <&tegra_car TEGRA186_CLK_AUD_MCLK>;
+ clock-names = "mclk";
+ micbias-resistor-k-ohms = <2>;
+ micbias-voltage-m-volts = <3000>;
+ dv-supply = <&battery_reg>;
+ av-supply = <&battery_reg>;
+ iov-supply = <&battery_reg>;
i2c@c240000 {
@@ -668,7 +680,8 @@
#endif
ahub {
/* I2S6 */
- i2s@2901500 {
+ i2s@2901100 {
+ status = "okay";
bclk-ratio = <4>;
@@ -695,60 +708,53 @@
tegra_sound: sound {
compatible = "nvidia,tegra-audio-t186ref-mobile-rt565x";
nvidia,model = "tegra-snd-t186ref-mobile-rt565x";
- nvidia,num-codec-link = <12>;
- clocks = <&tegra_car TEGRA186_CLK_PLLA>,
- <&tegra_car TEGRA186_CLK_PLL_A_OUT0>,
- <&tegra_car TEGRA186_CLK_AUD_MCLK>;
- clock-names = "pll_a", "pll_a_out0", "extern1";
- assigned-clocks = <&tegra_car TEGRA186_CLK_PLL_A_OUT0>,
- assigned-clock-parents = <&tegra_car TEGRA186_CLK_PLLA>,
- <&tegra_car TEGRA186_CLK_PLL_A_OUT0>;
- resets = <&tegra_car TEGRA186_RESET_AUD_MCLK>;
+ nvidia,num-codec-link = <13>;
+ clocks = <&tegra_car TEGRA186_CLK_PLLA>,
+ <&tegra_car TEGRA186_CLK_PLL_A_OUT0>,
+ <&tegra_car TEGRA186_CLK_AHUB>,
+ <&tegra_car TEGRA186_CLK_AUD_MCLK>;
+ clock-names = "pll_a", "pll_a_out0", "ahub", "extern1";
+ /*assigned-clocks = <&tegra_car TEGRA186_CLK_PLL_A_OUT0>,
+ assigned-clock-parents = <&tegra_car TEGRA186_CLK_PLLA>,
+ <&tegra_car TEGRA186_CLK_PLLP_OUT0>;
+ assigned-clock-rates = <0>, <0>, <12000000>;*/
+ assigned-clocks = <&tegra_car TEGRA186_CLK_PLL_A_OUT0>, <&tegra_car TEGRA186_CLK_AUD_MCLK>;
+ assigned-clock-parents = <&tegra_car TEGRA186_CLK_PLLA>, <&tegra_car TEGRA186_CLK_PLLP_OUT0>;
+ assigned-clock-rates = <0>, <12000000>;
+ resets = <&tegra_car TEGRA186_RESET_AUD_MCLK>;
reset-names = "extern1_rst";
status = "okay";
nvidia,audio-routing =
- "x Headphone", "x OUT",
- "x IN", "x Mic",
- "y Headphone", "y OUT",
- "y IN", "y Mic",
- "z Headphone", "z OUT",
- "z IN", "z Mic",
- "m Headphone", "m OUT",
- "m IN", "m Mic",
- "n Headphone", "n OUT",
- "n IN", "n Mic",
- "o Headphone", "o OUT",
- "o IN", "o Mic",
- "a IN", "a Mic",
- "b IN", "b Mic",
- "c IN", "c Mic",
- "d IN", "d Mic",
- "d1 Headphone", "d1 OUT",
- "d3 Headphone", "d3 OUT";
+ "z Headphone", "z LOL",
+ "z Headphone", "z LOR",
+ "z Headphone", "z HPL",
+ "z Headphone", "z HPR",
+ "z Left DAC", "z Playback",
+ "z Right DAC", "z Playback",
+ "z IN1_L", "z Mic",
+ "z IN1_R", "z Mic",
+ "z IN2_L", "z Mic",
+ "z IN2_R", "z Mic",
+ "z IN3_L", "z Mic",
+ "z IN3_R", "z Mic",
+ "z Capture", "z Left ADC",
+ "z Capture", "z Right ADC";
nvidia,xbar = <&tegra_axbar>;
- mclk-fs = <256>;
+ //mclk-fs = <256>;
rt565x_dai_link: nvidia,dai-link-1 {
link-name = "spdif-dit-0";
- cpu-dai = <&tegra_i2s1>;
- codec-dai = <&spdif_dit0>;
- cpu-dai-name = "I2S1";
- codec-dai-name = "dit-hifi";
- format = "i2s";
- bit-format = "s16_le";
- srate = <48000>;
- num-channel = <2>;
- ignore_suspend;
- name-prefix = "x";
- status = "okay";
- nvidia,dai-link-2 {
- link-name = "spdif-dit-1";
cpu-dai = <&tegra_i2s2>;
- codec-dai = <&spdif_dit1>;
+ codec-dai = <&spdif_dit0>;
cpu-dai-name = "I2S2";
format = "i2s";
@@ -756,7 +762,7 @@
srate = <48000>;
num-channel = <2>;
ignore_suspend;
- name-prefix = "y";
+ name-prefix = "x";
status = "okay";
nvidia,dai-link-3 {
@@ -770,8 +776,8 @@
srate = <48000>;
num-channel = <2>;
ignore_suspend;
- name-prefix = "z";
- status = "okay";
+ name-prefix = "a";
+ status = "disabled";
nvidia,dai-link-4 {
link-name = "spdif-dit-3";
@@ -785,7 +791,7 @@
num-channel = <2>;
ignore_suspend;
name-prefix = "m";
- status = "okay";
nvidia,dai-link-5 {
link-name = "spdif-dit-4";
@@ -799,7 +805,7 @@
num-channel = <2>;
ignore_suspend;
name-prefix = "n";
- status = "okay";
nvidia,dai-link-6 {
link-name = "spdif-dit-6";
@@ -816,7 +822,7 @@
num-channel = <1>;
ignore_suspend;
name-prefix = "o";
- status = "okay";
nvidia,dai-link-7 {
link-name = "spdif-dit-7";
@@ -830,7 +836,7 @@
ignore_suspend;
num-channel = <2>;
name-prefix = "a";
- status = "okay";
nvidia,dai-link-8 {
link-name = "spdif-dit-8";
@@ -844,7 +850,7 @@
ignore_suspend;
num-channel = <2>;
name-prefix = "b";
- status = "okay";
nvidia,dai-link-9 {
link-name = "spdif-dit-9";
@@ -858,7 +864,7 @@
ignore_suspend;
num-channel = <2>;
name-prefix = "c";
- status = "okay";
nvidia,dai-link-10 {
link-name = "spdif-dit-10";
@@ -872,7 +878,7 @@
ignore_suspend;
num-channel = <2>;
name-prefix = "d";
- status = "okay";
nvidia,dai-link-11 {
link-name = "dspk1-playback";
@@ -886,7 +892,7 @@
num-channel = <2>;
ignore_suspend;
name-prefix = "d3";
- status = "okay";
dspk_1_dai_link: nvidia,dai-link-12 {
link-name = "dspk-playback-l";
@@ -914,10 +920,31 @@
num-channel = <2>;
ignore_suspend;
name-prefix = "d2";
- status = "okay";
+ nvidia,dai-link-2 {
+ link-name = "ti-capture";
+ cpu-dai = <&tegra_i2s1>;
+ codec-dai = <&aic32x4>;
+ cpu-dai-name = "I2S1";
+ codec-dai-name = "tlv320aic32x4-hifi";
+ tx-mask = <0xFF>;
+ rx-mask = <0xFF>;
+ format = "i2s";
+ bitclock-slave;
+ frame-slave;
+ bitclock-noninversion;
+ frame-noninversion;
+ bit-format = "s16_le";
+ bclk_ratio = <1>;
+ srate = <44100>;
+ num-channel = <2>;
+ ignore_suspend;
+ name-prefix = "z";
+ status = "okay";
backlight {
status = "okay";
panel-s-wuxga-8-0-bl {
Here is the mobile driver file changes: tegra_machine_driver_mobile.c
File path : /home/parashuram/Linux_for_Tegra/sources/kernel/nvidia/sound/soc/tegra-alt/machine_drivers//home/parashuram/Linux_for_Tegra/sources/kernel/nvidia/sound/soc/tegra-alt/machine_drivers
diff --git a/sound/soc/tegra-alt/machine_drivers/tegra_machine_driver_mobile.c b/sound/soc/tegra-alt/machine_drivers/tegra_machine_driver_mobile.c
index fbca4699d..67b563cac 100644
--- a/sound/soc/tegra-alt/machine_drivers/tegra_machine_driver_mobile.c
+++ b/sound/soc/tegra-alt/machine_drivers/tegra_machine_driver_mobile.c
@@ -30,6 +30,7 @@
#include <dt-bindings/sound/tas2552.h>
#include "rt5659.h"
#include "sgtl5000.h"
+#include "tlv320aic32x4.h"
#include "tegra_asoc_machine_alt.h"
#include "tegra210_xbar_alt.h"
@@ -282,10 +283,11 @@ static int tegra_machine_set_params(struct snd_soc_card *card,
static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
- unsigned int rate, unsigned int channels,
- u64 formats)
+ int rate, unsigned int channels,
+ u64 formats, bool is_palyback)
struct snd_soc_card *card = runtime->card;
+ //struct snd_soc_card *card = rtd->card;
struct tegra_machine *machine = snd_soc_card_get_drvdata(card);
struct snd_soc_pcm_stream *dai_params;
unsigned int aud_mclk, srate;
@@ -310,7 +312,6 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
err = tegra_machine_set_params(card, machine, rate, channels, formats);
if (err < 0)
return err;
rtd = snd_soc_get_pcm_runtime(card, "rt565x-playback");
if (rtd) {
dai_params =
@@ -327,6 +328,20 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
return err;
+//Added TLV320AIC32X4
+ rtd = snd_soc_get_pcm_runtime(card, "ti-capture");
+ if (rtd) {
+ dai_params =
+ (struct snd_soc_pcm_stream *)rtd->dai_link->params;
+ dai_params->rate_min = srate;
+ dai_params->channels_min = channels;
+ dai_params->formats = formats;
+ if (err < 0) {
+ dev_err(card->dev, "codec_dai clock not parashuram set\n");
+ return err;
+//Ended
rtd = snd_soc_get_pcm_runtime(card, "rt565x-codec-sysclk-bclk1");
if (rtd) {
@@ -440,10 +455,17 @@ static int tegra_machine_pcm_hw_params(struct snd_pcm_substream *substream,
struct snd_soc_pcm_runtime *rtd = substream->private_data;
int err;
+ bool is_playback;
+ if (substream->stream == SNDRV_PCM_STREAM_PLAYBACK)
+ is_playback = true;
+ else
+ is_playback = false;
err = tegra_machine_dai_init(rtd, params_rate(params),
params_channels(params),
- 1ULL << params_format(params));
+ (1ULL << (params_format(params))),
+ is_playback);
if (err < 0) {
dev_err(card->dev, "Failed dai init\n");
return err;
@@ -593,7 +615,22 @@ static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *rtd)
return 0;
+//Added tlv320aic32x4
+static int tegra_machine_aic32x4_init(struct snd_soc_pcm_runtime *rtd)
+ struct device *dev = rtd->card->dev;
+ int err;
+ err = snd_soc_dai_set_sysclk(rtd->codec_dai, AIC32X4_FREQ_12000000, 12000000,
+ SND_SOC_CLOCK_IN);
+ if (err) {
+ dev_err(dev, "failed to set aic32x4 sysclk!\n");
+ return err;
+ return 0;
+//Ended
static int codec_init(struct tegra_machine *machine)
struct snd_soc_dai_link *dai_links = machine->asoc->dai_links;
@@ -611,6 +648,8 @@ static int codec_init(struct tegra_machine *machine)
dai_links[i].init = tegra_machine_rt565x_init;
else if (strstr(dai_links[i].name, "fe-pi-audio-z-v2"))
dai_links[i].init = tegra_machine_fepi_init;
+ else if (strstr(dai_links[i].name, "ti-capture"))
+ dai_links[i].init = tegra_machine_aic32x4_init;
return 0;
Here is the changes for audio codec tlv320aic32x4.c
File path: /home/parashuram/Linux_for_Tegra/sources/kernel/kernel-4.9/sound/soc/codecs/tlv320aic32x4.c
diff --git a/sound/soc/codecs/tlv320aic32x4.c b/sound/soc/codecs/tlv320aic32x4.c
old mode 100644
new mode 100755
index 28fdfc5ec544..644114743520
--- a/sound/soc/codecs/tlv320aic32x4.c
+++ b/sound/soc/codecs/tlv320aic32x4.c
@@ -30,6 +30,7 @@
#include <linux/pm.h>
#include <linux/gpio.h>
#include <linux/of_gpio.h>
+#include <linux/i2c.h>
#include <linux/cdev.h>
#include <linux/slab.h>
#include <linux/clk.h>
@@ -159,10 +160,7 @@ static const struct aic32x4_rate_divs aic32x4_divs[] = {
/* 48k rate */
{AIC32X4_FREQ_12000000, 48000, 1, 8, 1920, 128, 2, 8, 128, 2, 8, 4},
{AIC32X4_FREQ_24000000, 48000, 2, 8, 1920, 128, 8, 2, 64, 8, 4, 4},
- {AIC32X4_FREQ_25000000, 48000, 2, 7, 8643, 128, 8, 2, 64, 8, 4, 4},
- /* 96k rate */
- {AIC32X4_FREQ_25000000, 96000, 2, 7, 8643, 64, 4, 4, 64, 4, 4, 1},
+ {AIC32X4_FREQ_25000000, 48000, 2, 7, 8643, 128, 8, 2, 64, 8, 4, 4}
static const struct snd_kcontrol_new hpl_output_mixer_controls[] = {
@@ -183,72 +181,44 @@ static const struct snd_kcontrol_new lor_output_mixer_controls[] = {
SOC_DAPM_SINGLE("R_DAC Switch", AIC32X4_LORROUTE, 3, 1, 0),
-static const char * const resistor_text[] = {
- "Off", "10 kOhm", "20 kOhm", "40 kOhm",
+static const struct snd_kcontrol_new left_input_mixer_controls[] = {
+ SOC_DAPM_SINGLE("IN1_L P Switch", AIC32X4_LMICPGAPIN, 6, 1, 0),
+ SOC_DAPM_SINGLE("IN2_L P Switch", AIC32X4_LMICPGAPIN, 4, 1, 0),
+ SOC_DAPM_SINGLE("IN3_L P Switch", AIC32X4_LMICPGAPIN, 2, 1, 0),
-/* Left mixer pins */
-static SOC_ENUM_SINGLE_DECL(in1l_lpga_p_enum, AIC32X4_LMICPGAPIN, 6, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in2l_lpga_p_enum, AIC32X4_LMICPGAPIN, 4, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in3l_lpga_p_enum, AIC32X4_LMICPGAPIN, 2, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in1r_lpga_p_enum, AIC32X4_LMICPGAPIN, 0, resistor_text);
-static SOC_ENUM_SINGLE_DECL(cml_lpga_n_enum, AIC32X4_LMICPGANIN, 6, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in2r_lpga_n_enum, AIC32X4_LMICPGANIN, 4, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in3r_lpga_n_enum, AIC32X4_LMICPGANIN, 2, resistor_text);
-static const struct snd_kcontrol_new in1l_to_lmixer_controls[] = {
- SOC_DAPM_ENUM("IN1_L L+ Switch", in1l_lpga_p_enum),
-static const struct snd_kcontrol_new in2l_to_lmixer_controls[] = {
- SOC_DAPM_ENUM("IN2_L L+ Switch", in2l_lpga_p_enum),
-static const struct snd_kcontrol_new in3l_to_lmixer_controls[] = {
- SOC_DAPM_ENUM("IN3_L L+ Switch", in3l_lpga_p_enum),
-static const struct snd_kcontrol_new in1r_to_lmixer_controls[] = {
- SOC_DAPM_ENUM("IN1_R L+ Switch", in1r_lpga_p_enum),
-static const struct snd_kcontrol_new cml_to_lmixer_controls[] = {
- SOC_DAPM_ENUM("CM_L L- Switch", cml_lpga_n_enum),
-static const struct snd_kcontrol_new in2r_to_lmixer_controls[] = {
- SOC_DAPM_ENUM("IN2_R L- Switch", in2r_lpga_n_enum),
-static const struct snd_kcontrol_new in3r_to_lmixer_controls[] = {
- SOC_DAPM_ENUM("IN3_R L- Switch", in3r_lpga_n_enum),
+static const struct snd_kcontrol_new right_input_mixer_controls[] = {
+ SOC_DAPM_SINGLE("IN1_R P Switch", AIC32X4_RMICPGAPIN, 6, 1, 0),
+ SOC_DAPM_SINGLE("IN2_R P Switch", AIC32X4_RMICPGAPIN, 4, 1, 0),
+ SOC_DAPM_SINGLE("IN3_R P Switch", AIC32X4_RMICPGAPIN, 2, 1, 0),
-/* Right mixer pins */
-static SOC_ENUM_SINGLE_DECL(in1r_rpga_p_enum, AIC32X4_RMICPGAPIN, 6, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in2r_rpga_p_enum, AIC32X4_RMICPGAPIN, 4, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in3r_rpga_p_enum, AIC32X4_RMICPGAPIN, 2, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in2l_rpga_p_enum, AIC32X4_RMICPGAPIN, 0, resistor_text);
-static SOC_ENUM_SINGLE_DECL(cmr_rpga_n_enum, AIC32X4_RMICPGANIN, 6, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in1l_rpga_n_enum, AIC32X4_RMICPGANIN, 4, resistor_text);
-static SOC_ENUM_SINGLE_DECL(in3l_rpga_n_enum, AIC32X4_RMICPGANIN, 2, resistor_text);
-static const struct snd_kcontrol_new in1r_to_rmixer_controls[] = {
- SOC_DAPM_ENUM("IN1_R R+ Switch", in1r_rpga_p_enum),
-static const struct snd_kcontrol_new in2r_to_rmixer_controls[] = {
- SOC_DAPM_ENUM("IN2_R R+ Switch", in2r_rpga_p_enum),
-static const struct snd_kcontrol_new in3r_to_rmixer_controls[] = {
- SOC_DAPM_ENUM("IN3_R R+ Switch", in3r_rpga_p_enum),
-static const struct snd_kcontrol_new in2l_to_rmixer_controls[] = {
- SOC_DAPM_ENUM("IN2_L R+ Switch", in2l_rpga_p_enum),
-static const struct snd_kcontrol_new cmr_to_rmixer_controls[] = {
- SOC_DAPM_ENUM("CM_R R- Switch", cmr_rpga_n_enum),
-static const struct snd_kcontrol_new in1l_to_rmixer_controls[] = {
- SOC_DAPM_ENUM("IN1_L R- Switch", in1l_rpga_n_enum),
-static const struct snd_kcontrol_new in3l_to_rmixer_controls[] = {
- SOC_DAPM_ENUM("IN3_L R- Switch", in3l_rpga_n_enum),
+static int mic_bias_event(struct snd_soc_dapm_widget *w,
+ struct snd_kcontrol *kcontrol, int event)
+ struct snd_soc_component *component =
+snd_soc_dapm_to_component(w->dapm);
+ switch (event) {
+ case SND_SOC_DAPM_POST_PMU:
+ /* Change Mic Bias Registor */
+ snd_soc_component_update_bits(component, AIC32X4_MICBIAS,
+ AIC32x4_MICBIAS_MASK,
+ AIC32X4_MICBIAS_LDOIN |
+ AIC32X4_MICBIAS_2075V);
+ printk(KERN_DEBUG "%s: Mic Bias will be turned ON\n", __func__);
+ break;
+ case SND_SOC_DAPM_PRE_PMD:
+ AIC32x4_MICBIAS_MASK, 0);
+ printk(KERN_DEBUG "%s: Mic Bias will be turned OFF\n",
+ __func__);
+ break;
+ return 0;
static const struct snd_soc_dapm_widget aic32x4_dapm_widgets[] = {
SND_SOC_DAPM_DAC("Left DAC", "Left Playback", AIC32X4_DACSETUP, 7, 0),
@@ -271,40 +241,17 @@ static const struct snd_soc_dapm_widget aic32x4_dapm_widgets[] = {
&lor_output_mixer_controls[0],
ARRAY_SIZE(lor_output_mixer_controls)),
SND_SOC_DAPM_PGA("LOR Power", AIC32X4_OUTPWRCTL, 2, 0, NULL, 0),
- SND_SOC_DAPM_ADC("Right ADC", "Right Capture", AIC32X4_ADCSETUP, 6, 0),
- SND_SOC_DAPM_MUX("IN1_R to Right Mixer Positive Resistor", SND_SOC_NOPM, 0, 0,
- in1r_to_rmixer_controls),
- SND_SOC_DAPM_MUX("IN2_R to Right Mixer Positive Resistor", SND_SOC_NOPM, 0, 0,
- in2r_to_rmixer_controls),
- SND_SOC_DAPM_MUX("IN3_R to Right Mixer Positive Resistor", SND_SOC_NOPM, 0, 0,
- in3r_to_rmixer_controls),
- SND_SOC_DAPM_MUX("IN2_L to Right Mixer Positive Resistor", SND_SOC_NOPM, 0, 0,
- in2l_to_rmixer_controls),
- SND_SOC_DAPM_MUX("CM_R to Right Mixer Negative Resistor", SND_SOC_NOPM, 0, 0,
- cmr_to_rmixer_controls),
- SND_SOC_DAPM_MUX("IN1_L to Right Mixer Negative Resistor", SND_SOC_NOPM, 0, 0,
- in1l_to_rmixer_controls),
- SND_SOC_DAPM_MUX("IN3_L to Right Mixer Negative Resistor", SND_SOC_NOPM, 0, 0,
- in3l_to_rmixer_controls),
- SND_SOC_DAPM_ADC("Left ADC", "Left Capture", AIC32X4_ADCSETUP, 7, 0),
- SND_SOC_DAPM_MUX("IN1_L to Left Mixer Positive Resistor", SND_SOC_NOPM, 0, 0,
- in1l_to_lmixer_controls),
- SND_SOC_DAPM_MUX("IN2_L to Left Mixer Positive Resistor", SND_SOC_NOPM, 0, 0,
- in2l_to_lmixer_controls),
- SND_SOC_DAPM_MUX("IN3_L to Left Mixer Positive Resistor", SND_SOC_NOPM, 0, 0,
- in3l_to_lmixer_controls),
- SND_SOC_DAPM_MUX("IN1_R to Left Mixer Positive Resistor", SND_SOC_NOPM, 0, 0,
- in1r_to_lmixer_controls),
- SND_SOC_DAPM_MUX("CM_L to Left Mixer Negative Resistor", SND_SOC_NOPM, 0, 0,
- cml_to_lmixer_controls),
- SND_SOC_DAPM_MUX("IN2_R to Left Mixer Negative Resistor", SND_SOC_NOPM, 0, 0,
- in2r_to_lmixer_controls),
- SND_SOC_DAPM_MUX("IN3_R to Left Mixer Negative Resistor", SND_SOC_NOPM, 0, 0,
- in3r_to_lmixer_controls),
- SND_SOC_DAPM_MICBIAS("Mic Bias", AIC32X4_MICBIAS, 6, 0),
+ SND_SOC_DAPM_MIXER("Left Input Mixer", SND_SOC_NOPM, 0, 0,
+ &left_input_mixer_controls[0],
+ ARRAY_SIZE(left_input_mixer_controls)),
+ SND_SOC_DAPM_MIXER("Right Input Mixer", SND_SOC_NOPM, 0, 0,
+ &right_input_mixer_controls[0],
+ ARRAY_SIZE(right_input_mixer_controls)),
+ SND_SOC_DAPM_ADC( "Left ADC", "Capture", AIC32X4_ADCSETUP, 7, 0), // Jon 20.03.2018
+ SND_SOC_DAPM_ADC( "Right ADC", "Capture", AIC32X4_ADCSETUP, 6, 0), // Jon 20.03.2018
+ //SND_SOC_DAPM_MICBIAS("Mic Bias", AIC32X4_MICBIAS, 6, 0),
+ SND_SOC_DAPM_SUPPLY("Mic Bias", AIC32X4_MICBIAS, 6, 0, mic_bias_event,
+ SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_PRE_PMD),
SND_SOC_DAPM_OUTPUT("HPL"),
SND_SOC_DAPM_OUTPUT("HPR"),
@@ -343,77 +290,19 @@ static const struct snd_soc_dapm_route aic32x4_dapm_routes[] = {
{"LOR Power", NULL, "LOR Output Mixer"},
{"LOR", NULL, "LOR Power"},
+ /* Left input */
+ {"Left Input Mixer", "IN1_L P Switch", "IN1_L"},
+ {"Left Input Mixer", "IN2_L P Switch", "IN2_L"},
+ {"Left Input Mixer", "IN3_L P Switch", "IN3_L"},
+ {"Left ADC", NULL, "Left Input Mixer"},
/* Right Input */
- {"Right ADC", NULL, "IN1_R to Right Mixer Positive Resistor"},
- {"IN1_R to Right Mixer Positive Resistor", "10 kOhm", "IN1_R"},
- {"IN1_R to Right Mixer Positive Resistor", "20 kOhm", "IN1_R"},
- {"IN1_R to Right Mixer Positive Resistor", "40 kOhm", "IN1_R"},
- {"Right ADC", NULL, "IN2_R to Right Mixer Positive Resistor"},
- {"IN2_R to Right Mixer Positive Resistor", "10 kOhm", "IN2_R"},
- {"IN2_R to Right Mixer Positive Resistor", "20 kOhm", "IN2_R"},
- {"IN2_R to Right Mixer Positive Resistor", "40 kOhm", "IN2_R"},
- {"Right ADC", NULL, "IN3_R to Right Mixer Positive Resistor"},
- {"IN3_R to Right Mixer Positive Resistor", "10 kOhm", "IN3_R"},
- {"IN3_R to Right Mixer Positive Resistor", "20 kOhm", "IN3_R"},
- {"IN3_R to Right Mixer Positive Resistor", "40 kOhm", "IN3_R"},
- {"Right ADC", NULL, "IN2_L to Right Mixer Positive Resistor"},
- {"IN2_L to Right Mixer Positive Resistor", "10 kOhm", "IN2_L"},
- {"IN2_L to Right Mixer Positive Resistor", "20 kOhm", "IN2_L"},
- {"IN2_L to Right Mixer Positive Resistor", "40 kOhm", "IN2_L"},
- {"Right ADC", NULL, "CM_R to Right Mixer Negative Resistor"},
- {"CM_R to Right Mixer Negative Resistor", "10 kOhm", "CM_R"},
- {"CM_R to Right Mixer Negative Resistor", "20 kOhm", "CM_R"},
- {"CM_R to Right Mixer Negative Resistor", "40 kOhm", "CM_R"},
- {"Right ADC", NULL, "IN1_L to Right Mixer Negative Resistor"},
- {"IN1_L to Right Mixer Negative Resistor", "10 kOhm", "IN1_L"},
- {"IN1_L to Right Mixer Negative Resistor", "20 kOhm", "IN1_L"},
- {"IN1_L to Right Mixer Negative Resistor", "40 kOhm", "IN1_L"},
- {"Right ADC", NULL, "IN3_L to Right Mixer Negative Resistor"},
- {"IN3_L to Right Mixer Negative Resistor", "10 kOhm", "IN3_L"},
- {"IN3_L to Right Mixer Negative Resistor", "20 kOhm", "IN3_L"},
- {"IN3_L to Right Mixer Negative Resistor", "40 kOhm", "IN3_L"},
- /* Left Input */
- {"Left ADC", NULL, "IN1_L to Left Mixer Positive Resistor"},
- {"IN1_L to Left Mixer Positive Resistor", "10 kOhm", "IN1_L"},
- {"IN1_L to Left Mixer Positive Resistor", "20 kOhm", "IN1_L"},
- {"IN1_L to Left Mixer Positive Resistor", "40 kOhm", "IN1_L"},
- {"Left ADC", NULL, "IN2_L to Left Mixer Positive Resistor"},
- {"IN2_L to Left Mixer Positive Resistor", "10 kOhm", "IN2_L"},
- {"IN2_L to Left Mixer Positive Resistor", "20 kOhm", "IN2_L"},
- {"IN2_L to Left Mixer Positive Resistor", "40 kOhm", "IN2_L"},
- {"Left ADC", NULL, "IN3_L to Left Mixer Positive Resistor"},
- {"IN3_L to Left Mixer Positive Resistor", "10 kOhm", "IN3_L"},
- {"IN3_L to Left Mixer Positive Resistor", "20 kOhm", "IN3_L"},
- {"IN3_L to Left Mixer Positive Resistor", "40 kOhm", "IN3_L"},
- {"Left ADC", NULL, "IN1_R to Left Mixer Positive Resistor"},
- {"IN1_R to Left Mixer Positive Resistor", "10 kOhm", "IN1_R"},
- {"IN1_R to Left Mixer Positive Resistor", "20 kOhm", "IN1_R"},
- {"IN1_R to Left Mixer Positive Resistor", "40 kOhm", "IN1_R"},
- {"Left ADC", NULL, "CM_L to Left Mixer Negative Resistor"},
- {"CM_L to Left Mixer Negative Resistor", "10 kOhm", "CM_L"},
- {"CM_L to Left Mixer Negative Resistor", "20 kOhm", "CM_L"},
- {"CM_L to Left Mixer Negative Resistor", "40 kOhm", "CM_L"},
- {"Left ADC", NULL, "IN2_R to Left Mixer Negative Resistor"},
- {"IN2_R to Left Mixer Negative Resistor", "10 kOhm", "IN2_R"},
- {"IN2_R to Left Mixer Negative Resistor", "20 kOhm", "IN2_R"},
- {"IN2_R to Left Mixer Negative Resistor", "40 kOhm", "IN2_R"},
- {"Left ADC", NULL, "IN3_R to Left Mixer Negative Resistor"},
- {"IN3_R to Left Mixer Negative Resistor", "10 kOhm", "IN3_R"},
- {"IN3_R to Left Mixer Negative Resistor", "20 kOhm", "IN3_R"},
- {"IN3_R to Left Mixer Negative Resistor", "40 kOhm", "IN3_R"},
+ {"Right Input Mixer", "IN1_R P Switch", "IN1_R"},
+ {"Right Input Mixer", "IN2_R P Switch", "IN2_R"},
+ {"Right Input Mixer", "IN3_R P Switch", "IN3_R"},
+ {"Right ADC", NULL, "Right Input Mixer"},
static const struct regmap_range_cfg aic32x4_regmap_pages[] = {
@@ -423,12 +312,14 @@ static const struct regmap_range_cfg aic32x4_regmap_pages[] = {
.window_start = 0,
.window_len = 128,
.range_min = 0,
- .range_max = AIC32X4_RMICPGAVOL,
+ .range_max = 0xFB, //AIC32X4_RMICPGAVOL,
const struct regmap_config aic32x4_regmap_config = {
- .max_register = AIC32X4_RMICPGAVOL,
+ .reg_bits = 8,
+ .val_bits = 8,
+ .max_register = 0xFB, //AIC32X4_RMICPGAVOL,
.ranges = aic32x4_regmap_pages,
.num_ranges = ARRAY_SIZE(aic32x4_regmap_pages),
@@ -464,7 +355,6 @@ static int aic32x4_set_dai_sysclk(struct snd_soc_dai *codec_dai,
printk(KERN_ERR "aic32x4: invalid frequency to set DAI system clock\n");
return -EINVAL;
static int aic32x4_set_dai_fmt(struct snd_soc_dai *codec_dai, unsigned int fmt)
struct snd_soc_codec *codec = codec_dai->codec;
@@ -536,7 +426,7 @@ static int aic32x4_hw_params(struct snd_pcm_substream *substream,
printk(KERN_ERR "aic32x4: sampling rate not supported\n");
return i;
+#if 0
/* Use PLL as CODEC_CLKIN and DAC_MOD_CLK as BDIV_CLKIN */
snd_soc_write(codec, AIC32X4_CLKMUX, AIC32X4_PLLCLKIN);
snd_soc_write(codec, AIC32X4_IFACE3, AIC32X4_DACMOD2BCLK);
@@ -602,7 +492,7 @@ static int aic32x4_hw_params(struct snd_pcm_substream *substream,
break;
snd_soc_write(codec, AIC32X4_IFACE1, data);
+#endif
if (params_channels(params) == 1) {
data = AIC32X4_RDAC2LCHN | AIC32X4_LDAC2LCHN;
} else {
Here are the changes for Pinmux
File Path: /home/parashuram/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg
pinmux.0x02431040 = 0x00000400; # dap1_sclk_pj0: i2s1, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431038 = 0x00000400; # dap1_dout_pj1: i2s1, tristate-disable, input-disable, lpdr-disable
pinmux.0x02431030 = 0x00000458; # dap1_din_pj2: i2s1, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x02431028 = 0x00000440; # dap1_fs_pj3: i2s1, tristate-disable, input-enable, lpdr-disable
pinmux.0x02431020 = 0x00000400; # aud_mclk_pj4: aud, tristate-disable, input-disable, lpdr-disable
To Activate the mixers run the attached script Record.sh (1.7 KB)
Regards,
Parashuram
