To enable Show disassembly option
Hi, We use Nsight Graphics 2024.2 on NVDIA RTX 3050 GPU. I am trying view the disassembly from gpu trace (or/and in shader analyser) of full frame rendered using vulkan api. I can see the SPIRV Disassemblies but not the actual assembly. Whereas, I can see asm code for the CUDA applications on Nsight compute fine.
It seems like the option I should enable to view the disassembly is disabled. Could you please help use view the disassembly?
I tried -g option in glslangValidator tool as mentioned here but was did not help.
I also tried with JIT recompile as “NO” as mentioned here. That did not help as well. Please advice.
Hi mrprajesh1,
Thank you for using Nsight Graphics and providing us with your feedback. Are you using NDA version of Nsight Graphics? The real disassembly is only available on NDA build of Nsight Graphics.
An
Hello @ AYan,
I think No. We are using Nsight that comes with CUDA12.6 toolkit. Can you please enlighten us about what is NDA version and how to procure that version?
Thanks,
For the NDA version of Nsight Graphics it requires that your company sign an NDA (Non-Disclosure Agreement) with Nvidia. You can contact myself, Darrell Woods, dwoods@nvidia.com to discuss more.
Regards,
Darrell
