We were able to run the motor.ipynb script from Jupiter notebooks. We would like to create a python file and run the motors and link with the other part of project which involves subscribing to data. Could you tell me how to create a python script for running the motors and run it using the command python motor.py from the terminal
I can’t answer this, you can check if can gain some ideas from shared projects at Latest Jetson & Embedded Systems/Jetson Projects topics - NVIDIA Developer Forums, and may other developers help to share experiences.
