Toggle power indicator LED on Spacely carrier board with Jetson TX2
I want to be able to write a program where I can toggle the state of the power indicator LED (D32 on board). Is this possible and if so how would I go about doing it?
Which LED do you mean? D32 on P2597 board is a ESD diode not LED.
Thanks for getting back to me. I use a connect tech spacely tx2 carrier board. Perhaps since that’s not made by you you wouldn’t know but I thought I’d ask.
Got it, you need to check with vendor directly then.
