Token Generation Speed Random Drops on dual sparks
I am running Qwen3.5-122B-A10B-FP8 through eugr repo and DeepSeekV4 Flash 0731 through tony’s repo on dual sparks. Token Generation speed remains good for both of them but randomly drops to 1-2tok/s and then jumps back again. Does anyone know why this might be happening?
recipe for qwen3.5
recipe_version: “1”
description: vLLM serving Qwen3.5-122B-FP8
HuggingFace model to download (optional, for --download-model)
model: Qwen/Qwen3.5-122B-A10B-FP8
Only cluster is supported
cluster_only: true
Container image to use
container: vllm-node
No mods required
mods:
  • mods/fix-qwen3.5-chat-template
Default settings (can be overridden via CLI)
defaults:
port: 8000
host: 0.0.0.0
tensor_parallel: 2
gpu_memory_utilization: 0.86
max_model_len: 262144
max_num_batched_tokens: 8192
max_num_seqs: 5
Environment variables
env: {}
The vLLM serve command template
command: |
vllm serve Qwen/Qwen3.5-122B-A10B-FP8
–max-model-len {max_model_len}
–gpu-memory-utilization {gpu_memory_utilization}
–port {port}
–kv-cache-dtype fp8
–host {host}
–load-format instanttensor
–max-num-seqs {max_num_seqs}
–enable-prefix-caching
–enable-auto-tool-choice
–tool-call-parser qwen3_xml
–reasoning-parser qwen3
-tp {tensor_parallel} --distributed-executor-backend ray
–max-num-batched-tokens {max_num_batched_tokens}
