Hi
In the thermal design guide, the tolerance of the Jetson AGX Xavier Module’s Height is given as +/-0.6 . Is the tolerance really so high? It makes it really difficult for designing a thermal solution when the height can change 1.2 mm.
Thank you.
Kind regards
