Too many function calls breaks compute shader
I have two spirv compute shaders: one which compiles and one which causes a segfault during pipeline creation. These two compute shaders are virtually identical, except that the broken shader performs one extra function call. The extra function call does not add any cfg edges to functions that were not previously called in the program. I have tested this across both nvidia and amd gpus, and I see very similar behavior, with the main difference being the number of function calls that break the driver differ. Below is a diff of the disassembled shaders along with the full disassembly for each shader. For these two specific shaders, I have been testing against an nvidia GM204M with driver version 396.45-2 with archlinux on x86_64.
Any help is greatly appreciated. Thanks!
DIFF (LEFT = WORKING SHADER, RIGHT = BROKEN SHADER)
Note that besides some differing ids the only real difference is the extra OpFunctionCall.
4c4
< ; Bound: 654
> ; Bound: 655
9,10c9,10
<                OpEntryPoint GLCompute %639 "main" %global_invocation
<                OpExecutionMode %639 LocalSize 1 1 1
>                OpEntryPoint GLCompute %640 "main" %global_invocation
>                OpExecutionMode %640 LocalSize 1 1 1
162a163
>                OpName %fn_return_22 "fn_return_22"
178c179
<                OpName %fn_return_48 "fn_return_48"
>                OpName %fn_return_49 "fn_return_49"
388a390
> %fn_return_22 = OpFunctionCall %void %field_square_private_private_private %global_5 %global_5
398c400
<         %639 = OpFunction %void None %fn_11
>         %640 = OpFunction %void None %fn_11
412c414
< %fn_return_48 = OpFunctionCall %void %curve_double %global_2 %global_1
> %fn_return_49 = OpFunctionCall %void %curve_double %global_2 %global_1
WORKING SHADER
; SPIR-V
; Version: 1.3
; Generator: Khronos; 64222
; Bound: 654
; Schema: 0
               OpCapability Shader
               OpExtension "SPV_KHR_storage_buffer_storage_class"
               OpMemoryModel Logical Simple
               OpName %u32 "u32"
               OpName %c_u32_24 "c_u32_24"
               OpName %u32_array "u32_array"
               OpName %struct "struct"
               OpName %private_struct_ptr "private_struct_ptr"
               OpName %global "global"
               OpName %global_0 "global_0"
               OpName %vector "vector"
               OpName %input_vector_ptr "input_vector_ptr"
               OpName %global_invocation "global_invocation"
               OpName %struct_0 "struct_0"
               OpName %struct_runtime_array "struct_runtime_array"
               OpName %storage_buffer_struct_runtime_array "storage_buffer_struct_runtime_array"
               OpName %storage_buffer_storage_buffer_struct_runtime_array_ptr "storage_buffer_storage_buffer_struct_runtime_array_ptr"
               OpName %descriptor_set_0_0 "descriptor_set_0_0"
               OpName %descriptor_set_0_1 "descriptor_set_0_1"
               OpName %storage_buffer_struct "storage_buffer_struct"
               OpName %storage_buffer_storage_buffer_struct_ptr "storage_buffer_storage_buffer_struct_ptr"
               OpName %descriptor_set_0_2 "descriptor_set_0_2"
               OpName %descriptor_set_0_3 "descriptor_set_0_3"
               OpName %private_struct_ptr_0 "private_struct_ptr_0"
               OpName %global_1 "global_1"
               OpName %global_2 "global_2"
               OpName %c_u32_0 "c_u32_0"
               OpName %c_u32_1 "c_u32_1"
               OpName %bool "bool"
               OpName %function_u32_ptr "function_u32_ptr"
               OpName %private_u32_array_ptr "private_u32_array_ptr"
               OpName %private_u32_ptr "private_u32_ptr"
               OpName %struct_1 "struct_1"
               OpName %c_u32_2 "c_u32_2"
               OpName %bignum_add_private_private_private_arg_0 "bignum_add_private_private_private_arg_0"
               OpName %bignum_add_private_private_private_arg_1 "bignum_add_private_private_private_arg_1"
               OpName %bignum_add_private_private_private_arg_2 "bignum_add_private_private_private_arg_2"
               OpName %bignum_add_private_private_private_var_0 "bignum_add_private_private_private_var_0"
               OpName %bignum_add_private_private_private_var_1 "bignum_add_private_private_private_var_1"
               OpName %fn_3 "fn_3"
               OpName %bignum_add_private_private_private "bignum_add_private_private_private"
               OpName %fn_start_3 "fn_start_3"
               OpName %anonymous_143 "anonymous_143"
               OpName %anonymous_144 "anonymous_144"
               OpName %anonymous_145 "anonymous_145"
               OpName %anonymous_146 "anonymous_146"
               OpName %loop_header_2 "loop_header_2"
               OpName %loop_merge_2 "loop_merge_2"
               OpName %loop_body_2 "loop_body_2"
               OpName %loop_continue_2 "loop_continue_2"
               OpName %loop_after_2 "loop_after_2"
               OpName %var_6 "var_6"
               OpName %var_7 "var_7"
               OpName %cond_2 "cond_2"
               OpName %x_ptr "x_ptr"
               OpName %x "x"
               OpName %y_ptr "y_ptr"
               OpName %y "y"
               OpName %anonymous_147 "anonymous_147"
               OpName %anonymous_148 "anonymous_148"
               OpName %anonymous_149 "anonymous_149"
               OpName %carry "carry"
               OpName %anonymous_150 "anonymous_150"
               OpName %anonymous_151 "anonymous_151"
               OpName %anonymous_152 "anonymous_152"
               OpName %anonymous_153 "anonymous_153"
               OpName %r_ptr "r_ptr"
               OpName %return_carry "return_carry"
               OpName %bignum_sub_private_private_private_arg_0 "bignum_sub_private_private_private_arg_0"
               OpName %bignum_sub_private_private_private_arg_1 "bignum_sub_private_private_private_arg_1"
               OpName %bignum_sub_private_private_private_arg_2 "bignum_sub_private_private_private_arg_2"
               OpName %bignum_sub_private_private_private_var_0 "bignum_sub_private_private_private_var_0"
               OpName %bignum_sub_private_private_private_var_1 "bignum_sub_private_private_private_var_1"
               OpName %bignum_sub_private_private_private "bignum_sub_private_private_private"
               OpName %fn_start_4 "fn_start_4"
               OpName %anonymous_154 "anonymous_154"
               OpName %anonymous_155 "anonymous_155"
               OpName %anonymous_156 "anonymous_156"
               OpName %anonymous_157 "anonymous_157"
               OpName %loop_header_3 "loop_header_3"
               OpName %loop_merge_3 "loop_merge_3"
               OpName %loop_body_3 "loop_body_3"
               OpName %loop_continue_3 "loop_continue_3"
               OpName %loop_after_3 "loop_after_3"
               OpName %var_8 "var_8"
               OpName %var_9 "var_9"
               OpName %cond_3 "cond_3"
               OpName %x_ptr_0 "x_ptr_0"
               OpName %x_0 "x_0"
               OpName %y_ptr_0 "y_ptr_0"
               OpName %y_0 "y_0"
               OpName %anonymous_158 "anonymous_158"
               OpName %anonymous_159 "anonymous_159"
               OpName %anonymous_160 "anonymous_160"
               OpName %borrow "borrow"
               OpName %anonymous_161 "anonymous_161"
               OpName %anonymous_162 "anonymous_162"
               OpName %anonymous_163 "anonymous_163"
               OpName %anonymous_164 "anonymous_164"
               OpName %r_ptr_0 "r_ptr_0"
               OpName %return_borrow "return borrow"
               OpName %void "void"
               OpName %fn_4 "fn_4"
               OpName %field_add_private_private_private_arg_0 "field_add_private_private_private_arg_0"
               OpName %field_add_private_private_private_arg_1 "field_add_private_private_private_arg_1"
               OpName %field_add_private_private_private_arg_2 "field_add_private_private_private_arg_2"
               OpName %field_add_private_private_private "field_add_private_private_private"
               OpName %fn_start_7 "fn_start_7"
               OpName %fn_return_3 "fn_return_3"
               OpName %anonymous_219 "anonymous_219"
               OpName %if_then_5 "if_then_5"
               OpName %if_after_5 "if_after_5"
               OpName %fn_return_4 "fn_return_4"
               OpName %anonymous_220 "anonymous_220"
               OpName %if_then_6 "if_then_6"
               OpName %if_after_6 "if_after_6"
               OpName %fn_return_5 "fn_return_5"
               OpName %field_square_private_private_private_arg_0 "field_square_private_private_private_arg_0"
               OpName %field_square_private_private_private_arg_1 "field_square_private_private_private_arg_1"
               OpName %fn_6 "fn_6"
               OpName %field_square_private_private_private "field_square_private_private_private"
               OpName %fn_start_9 "fn_start_9"
               OpName %field_mul_private_private_private_arg_0 "field_mul_private_private_private_arg_0"
               OpName %field_mul_private_private_private_arg_1 "field_mul_private_private_private_arg_1"
               OpName %field_mul_private_private_private_arg_2 "field_mul_private_private_private_arg_2"
               OpName %field_mul_private_private_private "field_mul_private_private_private"
               OpName %fn_start_10 "fn_start_10"
               OpName %global_3 "global_3"
               OpName %global_4 "global_4"
               OpName %global_5 "global_5"
               OpName %global_6 "global_6"
               OpName %curve_double_arg_0 "curve_double_arg_0"
               OpName %curve_double_arg_1 "curve_double_arg_1"
               OpName %fn_8 "fn_8"
               OpName %curve_double "curve_double"
               OpName %fn_start_12 "fn_start_12"
               OpName %this_x "this_x"
               OpName %this_y "this_y"
               OpName %this_z "this_z"
               OpName %res_x "res_x"
               OpName %res_y "res_y"
               OpName %res_z "res_z"
               OpName %fn_return_9 "fn_return_9"
               OpName %fn_return_10 "fn_return_10"
               OpName %fn_return_11 "fn_return_11"
               OpName %fn_return_12 "fn_return_12"
               OpName %fn_return_13 "fn_return_13"
               OpName %fn_return_14 "fn_return_14"
               OpName %fn_return_15 "fn_return_15"
               OpName %fn_return_16 "fn_return_16"
               OpName %fn_return_17 "fn_return_17"
               OpName %fn_return_18 "fn_return_18"
               OpName %fn_return_19 "fn_return_19"
               OpName %fn_return_20 "fn_return_20"
               OpName %fn_return_21 "fn_return_21"
               OpName %main_var_0 "main_var_0"
               OpName %fn_11 "fn_11"
               OpName %fn_start_15 "fn_start_15"
               OpName %storage_buffer_struct_ptr "storage_buffer_struct_ptr"
               OpName %anonymous_232 "anonymous_232"
               OpName %anonymous_233 "anonymous_233"
               OpName %input_u32_ptr "input_u32_ptr"
               OpName %anonymous_234 "anonymous_234"
               OpName %id "id"
               OpName %storage_buffer_struct_runtime_array_ptr "storage_buffer_struct_runtime_array_ptr"
               OpName %anonymous_235 "anonymous_235"
               OpName %storage_buffer_struct_ptr_0 "storage_buffer_struct_ptr_0"
               OpName %anonymous_236 "anonymous_236"
               OpName %anonymous_237 "anonymous_237"
               OpName %anonymous_238 "anonymous_238"
               OpDecorate %u32_array ArrayStride 4
               OpMemberDecorate %struct 0 Offset 0
               OpDecorate %global_invocation BuiltIn GlobalInvocationId
               OpMemberDecorate %struct_0 0 Offset 0
               OpMemberDecorate %struct_0 1 Offset 96
               OpMemberDecorate %struct_0 2 Offset 192
               OpDecorate %struct_runtime_array ArrayStride 288
               OpDecorate %storage_buffer_struct_runtime_array BufferBlock
               OpMemberDecorate %storage_buffer_struct_runtime_array 0 Offset 0
               OpDecorate %descriptor_set_0_0 DescriptorSet 0
               OpDecorate %descriptor_set_0_0 Binding 0
               OpDecorate %descriptor_set_0_1 DescriptorSet 0
               OpDecorate %descriptor_set_0_1 Binding 1
               OpDecorate %storage_buffer_struct BufferBlock
               OpMemberDecorate %storage_buffer_struct 0 Offset 0
               OpDecorate %descriptor_set_0_2 DescriptorSet 0
               OpDecorate %descriptor_set_0_2 Binding 2
               OpDecorate %descriptor_set_0_3 DescriptorSet 0
               OpDecorate %descriptor_set_0_3 Binding 3
               OpMemberDecorate %struct_1 0 Offset 0
               OpMemberDecorate %struct_1 1 Offset 4
        %u32 = OpTypeInt 32 0
          %1 = OpSpecConstant %u32 24
          %2 = OpSpecConstant %u32 2
          %3 = OpSpecConstantOp %u32 IMul %1 %2
   %c_u32_24 = OpConstant %u32 24
    %c_u32_1 = OpConstant %u32 1
    %c_u32_0 = OpConstant %u32 0
    %c_u32_2 = OpConstant %u32 2
  %u32_array = OpTypeArray %u32 %c_u32_24
     %struct = OpTypeStruct %u32_array
%private_struct_ptr = OpTypePointer Private %struct
     %vector = OpTypeVector %u32 3
%input_vector_ptr = OpTypePointer Input %vector
   %struct_0 = OpTypeStruct %struct %struct %struct
%struct_runtime_array = OpTypeRuntimeArray %struct_0
%storage_buffer_struct_runtime_array = OpTypeStruct %struct_runtime_array
%storage_buffer_storage_buffer_struct_runtime_array_ptr = OpTypePointer StorageBuffer %storage_buffer_struct_runtime_array
%storage_buffer_struct = OpTypeStruct %struct
%storage_buffer_storage_buffer_struct_ptr = OpTypePointer StorageBuffer %storage_buffer_struct
%private_struct_ptr_0 = OpTypePointer Private %struct_0
       %bool = OpTypeBool
%function_u32_ptr = OpTypePointer Function %u32
%private_u32_array_ptr = OpTypePointer Private %u32_array
%private_u32_ptr = OpTypePointer Private %u32
   %struct_1 = OpTypeStruct %u32 %u32
       %fn_3 = OpTypeFunction %u32 %private_struct_ptr %private_struct_ptr %private_struct_ptr
       %void = OpTypeVoid
       %fn_4 = OpTypeFunction %void %private_struct_ptr %private_struct_ptr %private_struct_ptr
       %fn_6 = OpTypeFunction %void %private_struct_ptr %private_struct_ptr
       %fn_8 = OpTypeFunction %void %private_struct_ptr_0 %private_struct_ptr_0
      %fn_11 = OpTypeFunction %void
%storage_buffer_struct_ptr = OpTypePointer StorageBuffer %struct
%input_u32_ptr = OpTypePointer Input %u32
%storage_buffer_struct_runtime_array_ptr = OpTypePointer StorageBuffer %struct_runtime_array
%storage_buffer_struct_ptr_0 = OpTypePointer StorageBuffer %struct_0
   %global_6 = OpVariable %private_struct_ptr Private
   %global_5 = OpVariable %private_struct_ptr Private
   %global_4 = OpVariable %private_struct_ptr Private
   %global_3 = OpVariable %private_struct_ptr Private
   %global_2 = OpVariable %private_struct_ptr_0 Private
   %global_1 = OpVariable %private_struct_ptr_0 Private
%descriptor_set_0_3 = OpVariable %storage_buffer_storage_buffer_struct_ptr StorageBuffer
%descriptor_set_0_2 = OpVariable %storage_buffer_storage_buffer_struct_ptr StorageBuffer
%descriptor_set_0_1 = OpVariable %storage_buffer_storage_buffer_struct_runtime_array_ptr StorageBuffer
%descriptor_set_0_0 = OpVariable %storage_buffer_storage_buffer_struct_runtime_array_ptr StorageBuffer
%global_invocation = OpVariable %input_vector_ptr Input
   %global_0 = OpVariable %private_struct_ptr Private
     %global = OpVariable %private_struct_ptr Private
%field_square_private_private_private = OpFunction %void None %fn_6
%field_square_private_private_private_arg_0 = OpFunctionParameter %private_struct_ptr
%field_square_private_private_private_arg_1 = OpFunctionParameter %private_struct_ptr
 %fn_start_9 = OpLabel
               OpReturn
               OpFunctionEnd
%field_add_private_private_private = OpFunction %void None %fn_4
%field_add_private_private_private_arg_0 = OpFunctionParameter %private_struct_ptr
%field_add_private_private_private_arg_1 = OpFunctionParameter %private_struct_ptr
%field_add_private_private_private_arg_2 = OpFunctionParameter %private_struct_ptr
 %fn_start_7 = OpLabel
%fn_return_3 = OpFunctionCall %u32 %bignum_add_private_private_private %field_add_private_private_private_arg_0 %field_add_private_private_private_arg_1 %field_add_private_private_private_arg_2
%anonymous_219 = OpIEqual %bool %fn_return_3 %c_u32_1
               OpBranchConditional %anonymous_219 %if_then_5 %if_after_5
  %if_then_5 = OpLabel
%fn_return_4 = OpFunctionCall %u32 %bignum_sub_private_private_private %field_add_private_private_private_arg_0 %field_add_private_private_private_arg_0 %global
%anonymous_220 = OpIEqual %bool %fn_return_4 %c_u32_0
               OpBranchConditional %anonymous_220 %if_then_6 %if_after_6
  %if_then_6 = OpLabel
%fn_return_5 = OpFunctionCall %u32 %bignum_sub_private_private_private %field_add_private_private_private_arg_0 %field_add_private_private_private_arg_0 %global
               OpBranch %if_after_6
 %if_after_6 = OpLabel
               OpBranch %if_after_5
 %if_after_5 = OpLabel
               OpReturn
               OpFunctionEnd
%bignum_sub_private_private_private = OpFunction %u32 None %fn_3
%bignum_sub_private_private_private_arg_0 = OpFunctionParameter %private_struct_ptr
%bignum_sub_private_private_private_arg_1 = OpFunctionParameter %private_struct_ptr
%bignum_sub_private_private_private_arg_2 = OpFunctionParameter %private_struct_ptr
 %fn_start_4 = OpLabel
%bignum_sub_private_private_private_var_0 = OpVariable %function_u32_ptr Function
%bignum_sub_private_private_private_var_1 = OpVariable %function_u32_ptr Function
               OpStore %bignum_sub_private_private_private_var_1 %c_u32_0
%anonymous_154 = OpAccessChain %private_u32_array_ptr %bignum_sub_private_private_private_arg_1 %c_u32_0
%anonymous_155 = OpAccessChain %private_u32_array_ptr %bignum_sub_private_private_private_arg_2 %c_u32_0
%anonymous_156 = OpAccessChain %private_u32_array_ptr %bignum_sub_private_private_private_arg_0 %c_u32_0
%anonymous_157 = OpISub %u32 %1 %c_u32_1
               OpStore %bignum_sub_private_private_private_var_0 %c_u32_0
               OpBranch %loop_header_3
%loop_header_3 = OpLabel
               OpLoopMerge %loop_merge_3 %loop_continue_3 None
               OpBranch %loop_merge_3
%loop_merge_3 = OpLabel
      %var_8 = OpLoad %u32 %bignum_sub_private_private_private_var_0
     %cond_3 = OpULessThanEqual %bool %var_8 %anonymous_157
               OpBranchConditional %cond_3 %loop_body_3 %loop_after_3
%loop_body_3 = OpLabel
    %x_ptr_0 = OpAccessChain %private_u32_ptr %anonymous_154 %var_8
        %x_0 = OpLoad %u32 %x_ptr_0
    %y_ptr_0 = OpAccessChain %private_u32_ptr %anonymous_155 %var_8
        %y_0 = OpLoad %u32 %y_ptr_0
%anonymous_158 = OpISubBorrow %struct_1 %x_0 %y_0
%anonymous_159 = OpCompositeExtract %u32 %anonymous_158 0
%anonymous_160 = OpCompositeExtract %u32 %anonymous_158 1
     %borrow = OpLoad %u32 %bignum_sub_private_private_private_var_1
%anonymous_161 = OpISubBorrow %struct_1 %anonymous_159 %borrow
%anonymous_162 = OpCompositeExtract %u32 %anonymous_161 0
%anonymous_163 = OpCompositeExtract %u32 %anonymous_161 1
%anonymous_164 = OpIAdd %u32 %anonymous_160 %anonymous_163
               OpStore %bignum_sub_private_private_private_var_1 %anonymous_164
    %r_ptr_0 = OpAccessChain %private_u32_ptr %anonymous_156 %var_8
               OpStore %r_ptr_0 %anonymous_162
               OpBranch %loop_continue_3
%loop_continue_3 = OpLabel
      %var_9 = OpIAdd %u32 %var_8 %c_u32_1
               OpStore %bignum_sub_private_private_private_var_0 %var_9
%loop_after_3 = OpLabel
%return_borrow = OpLoad %u32 %bignum_sub_private_private_private_var_1
               OpReturnValue %return_borrow
               OpFunctionEnd
%bignum_add_private_private_private = OpFunction %u32 None %fn_3
%bignum_add_private_private_private_arg_0 = OpFunctionParameter %private_struct_ptr
%bignum_add_private_private_private_arg_1 = OpFunctionParameter %private_struct_ptr
%bignum_add_private_private_private_arg_2 = OpFunctionParameter %private_struct_ptr
 %fn_start_3 = OpLabel
%bignum_add_private_private_private_var_0 = OpVariable %function_u32_ptr Function
%bignum_add_private_private_private_var_1 = OpVariable %function_u32_ptr Function
               OpStore %bignum_add_private_private_private_var_1 %c_u32_0
%anonymous_143 = OpAccessChain %private_u32_array_ptr %bignum_add_private_private_private_arg_1 %c_u32_0
%anonymous_144 = OpAccessChain %private_u32_array_ptr %bignum_add_private_private_private_arg_2 %c_u32_0
%anonymous_145 = OpAccessChain %private_u32_array_ptr %bignum_add_private_private_private_arg_0 %c_u32_0
%anonymous_146 = OpISub %u32 %1 %c_u32_1
               OpStore %bignum_add_private_private_private_var_0 %c_u32_0
               OpBranch %loop_header_2
%loop_header_2 = OpLabel
               OpLoopMerge %loop_merge_2 %loop_continue_2 None
               OpBranch %loop_merge_2
%loop_merge_2 = OpLabel
      %var_6 = OpLoad %u32 %bignum_add_private_private_private_var_0
     %cond_2 = OpULessThanEqual %bool %var_6 %anonymous_146
               OpBranchConditional %cond_2 %loop_body_2 %loop_after_2
%loop_body_2 = OpLabel
      %x_ptr = OpAccessChain %private_u32_ptr %anonymous_143 %var_6
          %x = OpLoad %u32 %x_ptr
      %y_ptr = OpAccessChain %private_u32_ptr %anonymous_144 %var_6
          %y = OpLoad %u32 %y_ptr
%anonymous_147 = OpIAddCarry %struct_1 %x %y
%anonymous_148 = OpCompositeExtract %u32 %anonymous_147 0
%anonymous_149 = OpCompositeExtract %u32 %anonymous_147 1
      %carry = OpLoad %u32 %bignum_add_private_private_private_var_1
%anonymous_150 = OpIAddCarry %struct_1 %anonymous_148 %carry
%anonymous_151 = OpCompositeExtract %u32 %anonymous_150 0
%anonymous_152 = OpCompositeExtract %u32 %anonymous_150 1
%anonymous_153 = OpIAdd %u32 %anonymous_149 %anonymous_152
               OpStore %bignum_add_private_private_private_var_1 %anonymous_153
      %r_ptr = OpAccessChain %private_u32_ptr %anonymous_145 %var_6
               OpStore %r_ptr %anonymous_151
               OpBranch %loop_continue_2
%loop_continue_2 = OpLabel
      %var_7 = OpIAdd %u32 %var_6 %c_u32_1
               OpStore %bignum_add_private_private_private_var_0 %var_7
%loop_after_2 = OpLabel
%return_carry = OpLoad %u32 %bignum_add_private_private_private_var_1
               OpReturnValue %return_carry
               OpFunctionEnd
%curve_double = OpFunction %void None %fn_8
%curve_double_arg_0 = OpFunctionParameter %private_struct_ptr_0
%curve_double_arg_1 = OpFunctionParameter %private_struct_ptr_0
%fn_start_12 = OpLabel
     %this_x = OpAccessChain %private_struct_ptr %curve_double_arg_1 %c_u32_0
     %this_y = OpAccessChain %private_struct_ptr %curve_double_arg_1 %c_u32_1
     %this_z = OpAccessChain %private_struct_ptr %curve_double_arg_1 %c_u32_2
      %res_x = OpAccessChain %private_struct_ptr %curve_double_arg_0 %c_u32_0
      %res_y = OpAccessChain %private_struct_ptr %curve_double_arg_0 %c_u32_1
      %res_z = OpAccessChain %private_struct_ptr %curve_double_arg_0 %c_u32_2
%fn_return_9 = OpFunctionCall %void %field_square_private_private_private %res_x %this_x
%fn_return_10 = OpFunctionCall %void %field_square_private_private_private %res_z %this_z
%fn_return_11 = OpFunctionCall %void %field_add_private_private_private %global_3 %res_x %res_x
%fn_return_12 = OpFunctionCall %void %field_mul_private_private_private %res_z %global_0 %res_z
%fn_return_13 = OpFunctionCall %void %field_add_private_private_private %res_x %global_3 %res_x
%fn_return_14 = OpFunctionCall %void %field_add_private_private_private %global_3 %res_z %res_x
%fn_return_15 = OpFunctionCall %void %field_mul_private_private_private %global_4 %this_z %this_y
%fn_return_16 = OpFunctionCall %void %field_add_private_private_private %global_4 %global_4 %global_4
%fn_return_17 = OpFunctionCall %void %field_square_private_private_private %res_z %global_4
%fn_return_18 = OpFunctionCall %void %field_mul_private_private_private %res_z %res_z %global_4
%fn_return_19 = OpFunctionCall %void %field_mul_private_private_private %global_5 %this_y %global_4
%fn_return_20 = OpFunctionCall %void %field_square_private_private_private %global_6 %global_5
%fn_return_21 = OpFunctionCall %void %field_add_private_private_private %global_5 %this_x %global_5
               OpReturn
               OpFunctionEnd
%field_mul_private_private_private = OpFunction %void None %fn_4
%field_mul_private_private_private_arg_0 = OpFunctionParameter %private_struct_ptr
%field_mul_private_private_private_arg_1 = OpFunctionParameter %private_struct_ptr
%field_mul_private_private_private_arg_2 = OpFunctionParameter %private_struct_ptr
%fn_start_10 = OpLabel
               OpReturn
               OpFunctionEnd
%fn_start_15 = OpLabel
 %main_var_0 = OpVariable %function_u32_ptr Function
%anonymous_232 = OpAccessChain %storage_buffer_struct_ptr %descriptor_set_0_2 %c_u32_0
               OpCopyMemory %global %anonymous_232
%anonymous_233 = OpAccessChain %storage_buffer_struct_ptr %descriptor_set_0_3 %c_u32_0
               OpCopyMemory %global_0 %anonymous_233
%anonymous_234 = OpAccessChain %input_u32_ptr %global_invocation %c_u32_0
         %id = OpLoad %u32 %anonymous_234
%anonymous_235 = OpAccessChain %storage_buffer_struct_runtime_array_ptr %descriptor_set_0_0 %c_u32_0
%anonymous_236 = OpAccessChain %storage_buffer_struct_ptr_0 %anonymous_235 %id
%anonymous_237 = OpAccessChain %storage_buffer_struct_runtime_array_ptr %descriptor_set_0_1 %c_u32_0
%anonymous_238 = OpAccessChain %storage_buffer_struct_ptr_0 %anonymous_237 %id
               OpCopyMemory %global_1 %anonymous_236
               OpCopyMemory %anonymous_238 %global_2
               OpReturn
               OpFunctionEnd
BROKEN SHADER
; SPIR-V
; Version: 1.3
; Bound: 655
; Schema: 0
               OpCapability Shader
               OpName %u32 "u32"
               OpName %bool "bool"
               OpName %fn_3 "fn_3"
               OpName %x "x"
               OpName %y "y"
               OpName %x_0 "x_0"
               OpName %y_0 "y_0"
               OpName %void "void"
               OpName %fn_4 "fn_4"
               OpName %fn_6 "fn_6"
               OpName %fn_8 "fn_8"
               OpName %id "id"
       %bool = OpTypeBool
       %void = OpTypeVoid
               OpReturn
               OpFunctionEnd
               OpReturn
               OpFunctionEnd
               OpFunctionEnd
               OpFunctionEnd
               OpReturn
               OpFunctionEnd
               OpReturn
               OpFunctionEnd
               OpReturn
               OpFunctionEnd
