I get the following error.
cutilCheckMsg() CUTIL CUDA error: Kernel execution failed in file <…/…/…/…/grid/gplacer/pswap.cu>, line 1023 : too many resources requested for launch
I checked the amount of resourced consumed and it is. It uses 256 threads.
[codebox]ptxas info : Compiling entry function ‘Z11netCoreTestPiS_S_S_S’
ptxas info :Used 16 registers, 5696+3648 bytes smem, 36 bytes cmem[1] [/codebox]
I’m running on a GTX280 (compute capability 1.3).
My machine is: 2493.76MHz Intel® Core™2 Quad CPU Q9300
uname -a gives:
Linux hagrid.eecg 2.6.24-etchnhalf.1-amd64 #1 SMP Tue Oct 14 03:11:45 UTC 2008 x86_64 GNU/Linux
I’ve been playing around to get it to work. If the kernel uses instead
ptxas info : Used 16 registers, 3648+2624 bytes smem, 36 bytes cmem[1][/codebox]
Then it has no error. Unfortunately, I need to use a lot more shared memory than this.
I’m using this driver: NVIDIA Driver for Linux (SLED) 185.18.14.
If anyone has any ideas, thanks in advance!
