I’m trying to build a custom kernel image for a custom carrier board using an Ubuntu host. I did it successfully with the 32.4.4 L4T but now with the latest Jetpack (34.1.1/34.1.0 L4Ts) I face some problems regarding the toolchain:
- The developer guide states two different env variables regarding the toolchain:
1.1. export CROSS_COMPILE_AARCH64_PATH=/aarch64–glibc–stable-2020.08-1 (from building kernel section)
1.2. tar xf aarch64–glibc–stable-2020.08-1.tar.bz2
export CROSS_COMPILE=$HOME/l4t-gcc/bin/aarch64-buildroot-linux-gnu-
Which one to use?
- I tried to export both of them/one of them and faced the following problems:
2.1. the nvbuild.sh and nvcommonbuild.sh didn’t recognize the exported env variables.
2.2. I added the export command to the nvbuild.sh itself and it complained that it couldn’t find the required toolchain path with a path composed of both env variables attached together to one string.
I need some help with this issues.
