I’m dealing with a 640x480 two images, I do overlapping Tiling on ImageC of size 38x100 and 20x20 on ImageR.
Then for each Tile 20x20 (from ImageR) I slide it (one pixel step) on one 38x100 tile and do dot product and save the result. and return until finish all Image.
I have thought of two top level design options doing that:
- divide the Image space between the blocks (each block responsible doing loading from global then do some calculation and save results back to global). or…
- divide the calculations between the blocks (each block responsible for part of the calculation for every pixel tile of the Image)
what is the best option ?
Or there is another option which I dont know?
Miki
