软件的安装
新买的开发板,下面这些软件都需要安装吗
No, what you bought is jetson, so you only need to install Jetson Software.
(if you are sure what you bought is jetson TX2)
这里的不都是针对TX2的吗?我在看SDK的安装时打开了这个网页,里面并没有指明是不是TX的啊,
比如Install DRIVE with SDK Manager这一项,应该是和驱动有关的吧,TX2不需要吗?
再比如Clara Holoscan好像是和计算有关的,我用TX2做一些算法的学习,难道不需要吗?等等
I have no idea which SDK page you opened, for Jetson TX2, you may start from JetPack SDK 4.6.3 | NVIDIA Developer
SD Card Image Method里不支持 TX2吗 ?
Please refer to Jetson TX2 - eLinux.org to get more understanding of what TX2 HW spec has, also can find some guides and toturials for developing you projecct.
Drive是給車用平台使用的software. TX2 cannot use it.
您给的这个( Please refer to Jetson TX2 - eLinux.org)网页里写的Tx2支持jetpack4.2.2,上面写的( you may start from JetPack SDK 4.6.3 | NVIDIA Developer),请问一下,TX2支持4.6.3吗?
另外此处给的网页里写的jetpack4.2.2包含的tensorflow是1.14.0的版本而不是tensorflow2.x版本,tensorflow2.x需要单独安装吗?如果需要单独安装,tensorflow2.x与jetpack4.2.2里的opencv3.3,tensorrt5.1等版本是否兼容?
3P_SY5LB2M7V7~%454T0YV
Yes, TX2 can work with JetPack 4.6.3.
Regarding the TensorFlow for JetPack 4.6.3, please check TensorFlow for Jetson TX2! - Jetson & Embedded Systems / Jetson TX2 - NVIDIA Developer Forums
