# 串口收发问题
**URL:** <https://forums.developer.nvidia.com/t/topic/294160>\
**Category:** Jetson Orin Nano\
**Tags:** chinese, uart\
**Created:** [May 27, 2024, 2:46am UTC](https://forums.developer.nvidia.com/t/topic/294160 "2024-05-27T02:46:06Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![KevinFFF](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/kevinfff/32/15508_2.png) [@KevinFFF](https://forums.developer.nvidia.com/u/KevinFFF)\
**Post date:** [May 27, 2024, 2:19pm UTC](https://forums.developer.nvidia.com/t/topic/294160/5 "2024-05-27T14:19:37Z")
</div>
It seems you are using Jetpack6.0GA(R36.3).
```auto
[3.624163] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
It is UART1 from 40-pin expansion header.
> [@qiaowei](#):
> 我使用 Loopback test ，不能正常收发，是需要外部TX和RX也接线吗？
Yes, you need to short TX/RX externally for loopback test.
(i.e. PIN8(UART1\_TX) and PIN10(UART1\_RX) on 40-pin expansion header)
> [@qiaowei](#):
> `UART0_RTS，UART0_CTS，UART1_RTS，UART1_CTS` 在设备树中改成普通IO了，有影响吗？
Do you mean the pinmux spreadsheet? If so, you should configure them as UART instead of GPIO.
You can refer to the following:
 ![image](https://global.discourse-cdn.com/nvidia/original/4X/0/4/b/04b021127dc5381259b1c77f20359020a61c4f28.png)
_[View the full topic](https://forums.developer.nvidia.com/t/topic/294160)._
