我根据这个链接,下载了.7z,想升级firmware
但是烧录过程中一直报错
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -k A_rce-fw --flash-only --showlogs
/home/zl/2023year/nvidia_jetson/nvidia/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh -k A_rce-fw --usb-instance 1-2 --device-instance 0 --flash-only --external-device nvme0n1p1 -c “tools/kernel_flash/flash_l4t_external.xml” --network usb0 jetson-orin-nano-devkit internal
- Step 1: Build the flashing environment *
Create flash environment 0
~/2023year/nvidia_jetson/nvidia/Linux_for_Tegra/bootloader ~/2023year/nvidia_jetson/nvidia/Linux_for_Tegra
Finish creating flash environment 0.
- Step 2: Boot the device with flash initrd image *
~/2023year/nvidia_jetson/nvidia/Linux_for_Tegra/temp_initrdflash/bootloader0 ~/2023year/nvidia_jetson/nvidia/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0003-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd “rcmboot” --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0003-p3768-0000-a0.dtb” --secondary_gpt_backup --bct_backup --instance 1-2
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0938 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0938 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0938 ] rcm boot with presigned binaries
[ 0.0960 ] tegrarcm_v2 --instance 1-2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0979 ] BR_CID: 0x80012344705DD8995C0000000CFD80C0
[ 0.1227 ] Sending bct_br
[ 0.1434 ] Sending mb1
[ 0.1441 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --instance 1-2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Cleaning up…
我该怎么解决
