- uefi 有AB两个分区镜像。 内核也是有两个分区镜像, 设备树 也是。
我怎么确认我启动的是哪个分区, 每个镜像使用的是哪个分区?
hello 550399056,
please refer to developer guide for Rootfs Selection.
you may also note that, the Bootloader slot and rootfs slot are configured together.
for instance, Bootloader A always boots with rootfs A, and Bootloader B always boots with rootfs B.
here’s nvbootctrl
utility to dump the slot information. i.e. nvbootctrl dump-slots-info
please see-also To show the current boot slot for the details.
iking@iking:/root$ sudo nvbootctrl is-rootfs-ab-enabled
is-rootfs-ab-enabled is not implemented.
这是什么意思? 没有实现?
hello 550399056,
RootfsA/B is default disabled, you must re-flash target to enable RootfsA/B.
please see-also Flashing the Target Board with a Redundant Root File Systems.
BTW,
may I also know which Jetpack release version you’re working with,
please check release tag, $ cat /etc/nv_tegra_release
for verification.
iking@iking:/root$ cat /etc/nv_tegra_release
please re-flash target to enable RootfsA/B.
