jetson技术支持团队,你好,请问有没有数据手册给出每类电源需要的功率,e.g
SYS_VIN_HV、SYS_VIN_MV、SYS_VIN_SV for JAO、PMIC_BBATT。
Based on the provided context, I will provide a comprehensive answer to the question.
The question appears to be asking about the power modes and configuration of the Jetson AGX Orin module, specifically the jetsoneg SYSVINHVSYSVINMVSYSVINSV values for the JAOPMICBBATT configuration.
However, the provided context does not explicitly mention the jetsoneg SYSVINHVSYSVINMVSYSVINSV values or the JAOPMICBBATT configuration. Therefore, I will provide a general overview of the power modes and configuration of the Jetson AGX Orin module.
The Jetson AGX Orin module has different power modes that can be configured using the nvpmodel command. The power modes determine which CPU cores are used and the maximum frequency of the CPU and GPU.
The Jetson AGX Orin module also has a System-on-Module (SOM) and a carrier board, each with an EEPROM that stores the board ID. The SOM can be used without any software configuration modifications.
The context also mentions that the Jetson AGX Orin module has a Thermal Transfer Plate (TTP) that is ready to accept a customer-provided thermal solution.
In terms of camera compatibility, the context provides links to resources that help select the right camera for the Jetson module, including a technical blog post and a list of partner-supported cameras.
To answer the question, I would need more information about the jetsoneg SYSVINHVSYSVINMVSYSVINSV values and the JAOPMICBBATT configuration. However, based on the provided context, I can suggest that the power modes and configuration of the Jetson AGX Orin module can be configured using the nvpmodel command, and the module has a SOM and carrier board with EEPROMs that store the board ID.
If you have any further questions or would like more information, please let me know.
Here is a comparison of the Jetson AGX Orin module with other Jetson modules:
In terms of power modes, all Jetson modules have different power modes that can be configured using the nvpmodel command. However, the specific power modes and configurations may vary depending on the module.
I hope this information is helpful. Let me know if you have any further questions.
你好,可能是我没有表达清楚,我想咨询的是jetson AGX oring核心板按照最高性能工作需要提供多大功率,比如SYS_VIN_HV、SYS_VIN_MV,采用12V和5V供电,需要设计多大的电流。
Hi meil.qqemail,
Please refer to Section 7-1 Electrical Specifications in the Jetson AGX Orin Series Data Sheet for the voltages and current requirements of the power rails. Log in | NVIDIA Developer
thank you
