设备偶发性的突然重启
您好,
现在我们使用的orin nx16G模组,jetpack 使用的5.1.4版本。
重启后的log显示:
Jun 4 15:27:40 iking kernel: [ 0.611558] tegradccommon module_init failed
Jun 4 15:27:40 iking kernel: [ 0.615827] tegradc module_init failed
Jun 4 15:27:40 iking kernel: [ 0.619819] EINJ: ACPI disabled.
Jun 4 15:27:40 iking kernel: [ 0.621410] tegra-pmc c360000.pmc: scratch reg offset dts data not present
Jun 4 15:27:40 iking kernel: [ 0.621417] tegra-pmc: ### PMC reset source: SYS_RESET_N
Jun 4 15:27:40 iking kernel: [ 0.621419] tegra-pmc: ### PMC reset level: L0
Jun 4 15:27:40 iking kernel: [ 0.621421] tegra-pmc: ### PMC reset status reg: 0x0
The provided log output appears to be from a Jetson Orin NX device, specifically the 16GB model, running JetPack 5.1.4. The log messages indicate several kernel-level errors and warnings related to the device’s boot process and hardware initialization.
Here’s a breakdown of the log messages:
  1. tegradccommon module init failed: This message suggests that the tegradccommon kernel module, which is responsible for managing the device’s display controller, failed to initialize.
  2. tegradc module init failed: This message indicates that the tegradc kernel module, which is responsible for managing the device’s display controller, also failed to initialize.
  3. EINJ ACPI disabled: This message suggests that the ACPI (Advanced Configuration and Power Interface) functionality is disabled on the device.
  4. tegrapmc c360000.pmc scratch reg offset dts data not present: This message indicates that the tegrapmc kernel module, which is responsible for managing the device’s power management controller, encountered an error while trying to access the device tree data.
  5. tegrapmc PMC reset source SYSRESETN: This message suggests that the power management controller (PMC) reset source is set to SYSRESETN, which is a system reset signal.
  6. tegrapmc PMC reset level L0: This message indicates that the PMC reset level is set to L0, which is the lowest reset level.
  7. tegrapmc PMC reset status reg 0x0: This message suggests that the PMC reset status register is set to 0x0, which indicates that the PMC is in a reset state.
Comparing these log messages to the provided documentation, it appears that the device is experiencing issues with its display controller and power management controller. The tegradccommon and tegradc kernel modules are failing to initialize, which may be related to the device’s display configuration.
Additionally, the tegrapmc kernel module is encountering errors while trying to access the device tree data, which may be related to the device’s power management configuration.
To troubleshoot these issues, it may be helpful to:
  • Verify the device’s display configuration and ensure that it is properly set up.
  • Check the device’s power management configuration and ensure that it is properly set up.
  • Review the device’s kernel logs to see if there are any other error messages that may be related to these issues.
  • Consider updating the device’s kernel and firmware to the latest versions.
It’s also worth noting that the Jetson Orin NX device has a known issue with its thermal management system, as mentioned in the provided documentation. This issue may be related to the device’s power management configuration and could potentially be contributing to the errors seen in the log output.
This is a very common reset source which could not lead to the cause of reboot.
Please check the UART log and see what is the last log before reboot happened.
我们设备在工作时,偶发性的重启,重启后的内核部分日志如上图。 这个不是必现的。不太好复现。并且我们的设备是飞行设备,一直在天上工作,不太好接串口进行log日志的抓取。
我看了内核kern.log没有异常的log。直接重启,重启后的log显示
Is this node existed in your device?
root@tegra-ubuntu:/sys/fs/pstore# ls
console-ramoops-0
If so, cat it after the reboot issue happened.
no,
please run this first to trigger reboot on purpose.
echo c > /proc/sysrq-trigger
In next reboot, please help check if pstore has the console-ramoops-0 node or not.
After triggering the reboot with
echo c > /proc/sysrq-trigger,
I checked /sys/fs/pstore/.
​The following nodes are present:
​• console-ramoops-0 ​• dmesg-ramoops-0
​So it looks like pstore/ramoops is working correctly and the panic log was successfully preserved across reboot.
Then you could try to reproduce the issue first and check the ramoops log here.
Otherwise you need to use the UART log.
好的 谢谢
1.log (145.3 KB)
拿到的console-ramoops-0 如附件所示,尽快帮忙看下
There is no obvious error in the log that leads to the problem.
The timestamp in log indicates only about 228 sec after boot.
Is the system really crashed after about 4 mins after boot? Do you have any syslog to confirm that?
kern.log (3.8 MB) 最后的两次启动log。
This log actually reboots 5 times.
Are all the reboot on your purpose? or not under your expectation?
你可以看到这个地方就是异常启动,也就是我们的飞行设备还在天上的时候,自己就reboot了。
So the system reboots 5 times and all of them is related to the sudden reboot you are talking about?
我们只手动上电三次,那么有三次是突然自动重启的,这个复现概率感觉挺高的。
Could you help check what is the thermal situation before the issue happened?
我们测试过这个没有过热,不到70摄氏度
If there is no obvious kernel panic that triggers the error, then most likely to due to voltage or thermal problem.
Have you checked about the voltage?
And if possible, still try to get a emulation with UART set might be helpful.
