- python -m venv ENV
- source ENV/bin/activate
- wget https://nvidia.box.com/shared/static/i8pukc49h3lhak4kkn67tg9j4goqm0m7.whl -O torch-2.0.0+nv23.05-cp38-cp38-linux_aarch64.whl
- sudo apt-get install python3-pip libopenblas-base libopenmpi-dev libomp-dev
- pip3 install Cython
- pip3 install numpy torch-2.0.0+nv23.05-cp38-cp38-linux_aarch64.whl
- sudo apt-get install libjpeg-dev zlib1g-dev libpython3-dev libopenblas-dev libavcodec-dev libavformat-dev libswscale-dev
- git clone --branch v0.15.1 GitHub - pytorch/vision: Datasets, Transforms and Models specific to Computer Vision torchvision
- cd torchvision
- export BUILD_VERSION=0.15.1
- python3 setup.py install --user
When I try to run python3 setup.py install --user it show
Building wheel torchvision-0.15.1
Compiling extensions with following flags:
FORCE_CUDA: False
DEBUG: False
TORCHVISION_USE_PNG: True
TORCHVISION_USE_JPEG: True
TORCHVISION_USE_NVJPEG: True
TORCHVISION_USE_FFMPEG: True
TORCHVISION_USE_VIDEO_CODEC: True
NVCC_FLAGS:
Found PNG library
Building torchvision with PNG image support
libpng version: 1.6.37
libpng include path: /usr/include/libpng16
Running build on conda-build: False
Running build on conda: False
Building torchvision with JPEG image support
Building torchvision without NVJPEG image support
Building torchvision without ffmpeg support
Building torchvision without video codec support
running install
Checking .pth file support in /home/mic-733ao/.local/lib/python3.8/site-packages/
/home/mic-733ao/data/verilyvision/VV_Por/lpr-exat-exit/ENV/bin/python3 -E -c pass
TEST FAILED: /home/mic-733ao/.local/lib/python3.8/site-packages/ does NOT support .pth files
error: bad install directory or PYTHONPATH
You are attempting to install a package to a directory that is not
on PYTHONPATH and which Python does not read β.pthβ files from. The
installation directory you specified (via --install-dir, --prefix, or
the distutils default setting) was:
and your PYTHONPATH environment variable currently contains:
ββ
Here are some of your options for correcting the problem:
- You can choose a different installation directory, i.e., one that is
on PYTHONPATH or supports .pth files - You can add the installation directory to the PYTHONPATH environment
variable. (It must then also be on PYTHONPATH whenever you run
Python and want to use the package(s) you are installing.) - You can set up the installation directory to support β.pthβ files by
using one of the approaches described here:
https://setuptools.readthedocs.io/en/latest/easy_install.html#custom-installation-locations
Please make the appropriate changes for your system and try again.
