I uses Jetson Orin Nano on Jetpack 6.2, when I executed yolo export model=“best.pt” data=“path/to/dataset” format=“engine” and it returns back
Ultralytics 8.3.75 🚀 Python-3.10.12 torch-2.6.0+cu126 CUDA:0 (Orin, 7620MiB)
File “/home/jetson/Desktop/venv/bin/yolo”, line 8, in
sys.exit(entrypoint())
File “/home/jetson/Desktop/venv/lib/python3.10/site-packages/ultralytics/cfg/init.py”, line 986, in entrypoint
getattr(model, mode)(**overrides) # default args from model
File “/home/jetson/Desktop/venv/lib/python3.10/site-packages/ultralytics/engine/model.py”, line 741, in export
return Exporter(overrides=args, _callbacks=self.callbacks)(model=self.model)
File “/home/jetson/Desktop/venv/lib/python3.10/site-packages/ultralytics/engine/exporter.py”, line 330, in call
model = model.fuse()
File “/home/jetson/Desktop/venv/lib/python3.10/site-packages/ultralytics/nn/tasks.py”, line 201, in fuse
m.conv = fuse_conv_and_bn(m.conv, m.bn) # update conv
File “/home/jetson/Desktop/venv/lib/python3.10/site-packages/ultralytics/utils/torch_utils.py”, line 257, in fuse_conv_and_bn
w_bn = torch.diag(bn.weight.div(torch.sqrt(bn.eps + bn.running_var)))
RuntimeError: CUDA error: no kernel image is available for execution on the device
Compile with TORCH_USE_CUDA_DSA
to enable device-side assertions.
my cuda version is 12.6 which same as torch cuda version, can anyone help me solve the problem?
Could you share which PyTorch package do you install?
this version
I install it by pip3 install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cu126
Because there might be a lot of problem i need to solve, so i downgrade it to jp6.1, hope it will execute successfully
It’s recommended to install our PyTorch as the package from PyTorch’s official website might not be built with Jetson forum support.
YOu can find the step-by-step tutorial for YOLO in the below link:
https://elinux.org/Jetson/L4T/TRT_Customized_Example#YoloV11_using_Pytorch
thank you very much!
