@dusty_nv I installed the torchvision 0.15+cuda as you mentioned above.
But still facing some runtime issues.
File “/usr/local/lib/python3.8/dist-packages/torch/nn/modules/module.py”, line 1501, in _call_impl
return forward_call(*args, **kwargs)
File “/usr/local/lib/python3.8/dist-packages/torch/utils/_contextlib.py”, line 115, in decorate_context
return func(*args, **kwargs)
File “/data/models/torch/hub/ultralytics_yolov5_master/models/common.py”, line 721, in forward
y = non_max_suppression(y if self.dmb else y[0],
File “/data/models/torch/hub/ultralytics_yolov5_master/utils/general.py”, line 959, in non_max_suppression
i = torchvision.ops.nms(boxes, scores, iou_thres) # NMS
File “/usr/local/lib/python3.8/dist-packages/torchvision/ops/boxes.py”, line 41, in nms
return torch.ops.torchvision.nms(boxes, scores, iou_threshold)
File “/usr/local/lib/python3.8/dist-packages/torch/_ops.py”, line 502, in call
return self._op(*args, **kwargs or {})
NotImplementedError: Could not run ‘torchvision::nms’ with arguments from the ‘CUDA’ backend. This could be because the operator doesn’t exist for this backend, or was omitted during the selective/custom build process (if using custom build). If you are a Facebook employee using PyTorch on mobile, please visit Internal Login for possible resolutions. ‘torchvision::nms’ is only available for these backends: [CPU, QuantizedCPU, BackendSelect, Python, FuncTorchDynamicLayerBackMode, Functionalize, Named, Conjugate, Negative, ZeroTensor, ADInplaceOrView, AutogradOther, AutogradCPU, AutogradCUDA, AutogradXLA, AutogradMPS, AutogradXPU, AutogradHPU, AutogradLazy, AutogradMeta, Tracer, AutocastCPU, AutocastCUDA, FuncTorchBatched, FuncTorchVmapMode, Batched, VmapMode, FuncTorchGradWrapper, PythonTLSSnapshot, FuncTorchDynamicLayerFrontMode, PythonDispatcher].
CPU: registered at /app/torchvision/torchvision/csrc/ops/cpu/nms_kernel.cpp:112 [kernel]
QuantizedCPU: registered at /app/torchvision/torchvision/csrc/ops/quantized/cpu/qnms_kernel.cpp:124 [kernel]
BackendSelect: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/BackendSelectFallbackKernel.cpp:3 [backend fallback]
Python: registered at /opt/pytorch/pytorch/aten/src/ATen/core/PythonFallbackKernel.cpp:144 [backend fallback]
FuncTorchDynamicLayerBackMode: registered at /opt/pytorch/pytorch/aten/src/ATen/functorch/DynamicLayer.cpp:491 [backend fallback]
Functionalize: registered at /opt/pytorch/pytorch/aten/src/ATen/FunctionalizeFallbackKernel.cpp:280 [backend fallback]
Named: registered at /opt/pytorch/pytorch/aten/src/ATen/core/NamedRegistrations.cpp:7 [backend fallback]
Conjugate: registered at /opt/pytorch/pytorch/aten/src/ATen/ConjugateFallback.cpp:17 [backend fallback]
Negative: registered at /opt/pytorch/pytorch/aten/src/ATen/native/NegateFallback.cpp:19 [backend fallback]
ZeroTensor: registered at /opt/pytorch/pytorch/aten/src/ATen/ZeroTensorFallback.cpp:86 [backend fallback]
ADInplaceOrView: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:63 [backend fallback]
AutogradOther: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:30 [backend fallback]
AutogradCPU: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:34 [backend fallback]
AutogradCUDA: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:42 [backend fallback]
AutogradXLA: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:46 [backend fallback]
AutogradMPS: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:54 [backend fallback]
AutogradXPU: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:38 [backend fallback]
AutogradHPU: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:67 [backend fallback]
AutogradLazy: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:50 [backend fallback]
AutogradMeta: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/core/VariableFallbackKernel.cpp:58 [backend fallback]
Tracer: registered at /opt/pytorch/pytorch/torch/csrc/autograd/TraceTypeManual.cpp:294 [backend fallback]
AutocastCPU: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/autocast_mode.cpp:487 [backend fallback]
AutocastCUDA: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/autocast_mode.cpp:354 [backend fallback]
FuncTorchBatched: registered at /opt/pytorch/pytorch/aten/src/ATen/functorch/LegacyBatchingRegistrations.cpp:815 [backend fallback]
FuncTorchVmapMode: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/functorch/VmapModeRegistrations.cpp:28 [backend fallback]
Batched: registered at /opt/pytorch/pytorch/aten/src/ATen/LegacyBatchingRegistrations.cpp:1073 [backend fallback]
VmapMode: fallthrough registered at /opt/pytorch/pytorch/aten/src/ATen/VmapModeRegistrations.cpp:33 [backend fallback]
FuncTorchGradWrapper: registered at /opt/pytorch/pytorch/aten/src/ATen/functorch/TensorWrapper.cpp:210 [backend fallback]
PythonTLSSnapshot: registered at /opt/pytorch/pytorch/aten/src/ATen/core/PythonFallbackKernel.cpp:152 [backend fallback]
FuncTorchDynamicLayerFrontMode: registered at /opt/pytorch/pytorch/aten/src/ATen/functorch/DynamicLayer.cpp:487 [backend fallback]
PythonDispatcher: registered at /opt/pytorch/pytorch/aten/src/ATen/core/PythonFallbackKernel.cpp:148 [backend fallback]
