Hi there, I’m working on Jetson Orin NX and PyTorch, I followed instructions here (Installing PyTorch for Jetson Platform - NVIDIA Docs) to install PyTorch and found that “torch.distributed.is_available()” is “False”. If I directly install PyTorch using conda (conda install pytorch -c pytorch -c nvidia) I will have “torch.distributed.is_available()” to be “True” but “torch.cuda.is_available()” to be “False”.
@zergzzlun if you prefer installing the wheel as opposed to using the container, I believe this was the last PyTorch wheel built with USE_DISTRIBUTED enabled:
For newer versions, you would need to build PyTorch from source to enable distributed mode (see this post for build instructions: PyTorch for Jetson)
Also, the reason that you get torch.cuda.is_available = False when you install it with conda, is because those upstream wheels from PyPi/conda/pip were not built for JetPack or with CUDA enabled.
