Torch model
Hi!
I have used this code:
while True:
    start = time()
    frame = cam.capture()
    frame = transforms.ToTensor()(frame)
    frame = frame.unsqueeze(0)
    frame = frame.to(DEVICE)
    print(frame.shape)
    out = net(frame)
    print(time() - start)
And have this time:
0.009600400924682617
torch.Size([1, 3, 224, 224])
0.010586738586425781
0.011191129684448242
0.3026876449584961
0.4999411106109619
0.5003457069396973
0.49947404861450195
Why model began to work slower?
Have you released the memory you uploaded to the GPU?
Using torch.cuda.empty_cache()?
It looks like you submit a bunch of cudaMemcpy in a short time.
If the jobs number is over than the computing channel, it’s possible the task needs to wait for the free channel.
Would you mind increasing the channel number to see if it helps?
https://elinux.org/Jetson/L4T/TRT_Customized_Example#Long_delays_when_submitting_several_cudaMemcpy
