Torch7 in TX2 cuda num_thread
i met a problem that “cuda time error ,too many resources requested for launch” when i run a ENet moedl in TX2 with torch7.
could you help me? when i run this model, the useage of GPU reached 99% at a short time.
There is relevant topic about torch7:
https://devtalk.nvidia.com/default/topic/1039501/
Also we have PyTorch releases:
https://devtalk.nvidia.com/default/topic/1049071/jetson-nano/pytorch-for-jetson-nano-version-1-3-0-now-available/
Please check above links and see if it helps your usecase.
I have met the same issue “too many resources requested for launch”, have you solved this issue?
