Could you dump dmesg log right after the error happens?
Boot up the device with touch connected. Use command dmesg > kernel_log.txt after the error happens and share the log with us.
Will the touch back to life if you use this method to toggle the usb hub?
I use Nano con SD card B01
The command is applicable for B01:
sudo uhubctl -l 1-2 -a off
sudo uhubctl -l 1-2 -a on
