TPG DS90UB954 Pink color
I am trying to generate test pattern using DS90UB954.
I am getting a pink color pattern.
It should be generating pattern in 8 different colors.
How to solve it ?
Thank you in advance.
Sorry that we didn’t try this test pattern generator before. What is the expected result?
Any requirement for this generator? For example, specific format or color space.
Hi @WayneWWW ,
I am using the ov5693 camera driver to generate pattern from The Deserializer(DS90UB954). I used the Exact registers given by the vendor to generate csi mipi data at RAW10 1080p 60fps.
The pattern capture was success but the pattern is only in pink color, it is expected to show 8 different colors.
Like this…
Can you identify whether this issue happens on csi side or the HDMI output side?
Hi @WayneWWW ,
The issue is at the csi side.
What’s the result without DS90UB954?
Did you check the RAW image captured by v4l2-ctl?
Hi @ShaneCCC ,
The pattern itself is being Generated by DS90UB954, I don’t know how to check the result without it.
This is what I got for “v4l2-ctl --device /dev/video0 --all”
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, ov5693 1-0030
Bus info : platform:15c10000.vi:0
Driver version: 4.9.201
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : ‘BG10’
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
                 group_hold 0x009a2003 (bool)   : default=0 value=0 flags=execute-on-write
                 hdr_enable 0x009a2004 (intmenu): min=0 max=1 default=0 value=0
                eeprom_data 0x009a2005 (str)    : min=0 max=2048 step=2 value='00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' flags=read-only, has-payload
                   otp_data 0x009a2006 (str)    : min=0 max=1024 step=2 value='0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' flags=read-only, has-payload
                    fuse_id 0x009a2007 (str)    : min=0 max=16 step=2 value='0000000000000000' flags=read-only, has-payload
                       gain 0x009a2009 (int64)  : min=0 max=0 step=0 default=0 value=160 flags=slider
                   exposure 0x009a200a (int64)  : min=0 max=0 step=0 default=0 value=29999 flags=slider
                 frame_rate 0x009a200b (int64)  : min=0 max=0 step=0 default=0 value=30000001 flags=slider
             exposure_short 0x009a200c (int64)  : min=0 max=0 step=0 default=0 value=16667 flags=slider
       sensor_configuration 0x009a2032 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
     sensor_mode_i2c_packet 0x009a2033 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
  sensor_control_i2c_packet 0x009a2034 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
                bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=1
            override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=1
               height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                 size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
           write_isp_format 0x009a2068 (int)    : min=1 max=1 step=1 default=1 value=1
   sensor_signal_properties 0x009a2069 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
    sensor_image_properties 0x009a206a (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
  sensor_control_properties 0x009a206b (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
          sensor_dv_timings 0x009a206c (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
           low_latency_mode 0x009a206d (bool)   : default=0 value=0
           preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=0
               sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=1 flags=read-only
I mean bypass DS90UB954 and enable ov5693’s test pattern to clarify it.
Also check the RAW image captured by below command.
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=BG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
When I ran the v4l2-ctl command you gave I got the following output
test.raw (4.0 MB)
I check the raw image by 7yuv and get below result by RGB565 format.
Maybe DS90UB954 output pixel format didn’t correct.
