Some good news - I am able to see/talk to/probe/etc. a Winbond W25Q64CV chip connected to SPI1 on the 40-pin GPIO connector on my Nano devkit. I can do a Read JEDEC ID, Read SFDP Register (0), etc., using sspi, and see the signals on my Saleae analyzer. ‘sf probe 1:0’ works, too.
I had to enable spi@7000d400 in the U-Boot p3450 DTS (status=“okay”, and max-spi-clock = 20MHz) and add the spi1 alias, rebuilt/reflash U-Boot, and then force the SPI1 pinmux regs (0x70003050/54/58/5c) to 0x6004/0x6044 at the U-Boot prompt, just as you’ve done for SPI2.
But that’s it - I don’t know why my Winbond SPI board wouldn’t work on SPI2 on the 40-pin GPIO connector - maybe some GPIO conflict, etc. But I can talk to a SPI chip on the 40-pin J41 with the tegra114_spi driver, so that’s good.
If I add CONFIG_SPI_FLASH_WINBOND=y to my P3450 defconfig, I can also get ‘sf probe’ to return the Winbond chip specifics, and do a ‘sf read’, etc. Note that this is all with our L4T U-Boot from R32.7.x.
I suspect you can’t move your TPM to SPI1, but if you have a proto board you can hook up to SPI1 to test out under U-Boot, that might help you compare the SPI2 mux/GPIO/etc. registers to SPI1 to see what might be blocking progress.
@TWarren
This is good news. At least we know that the driver does work in uboot on a Nano.
It sounds like you tried to connect with SPI2 on the 40 pin and it didn’t work is that correct?
We are to late in the HW design to move the TPM to SPI1, so I have to make the FW work with SPI2. So I will continue to look into it. But this does make it sounds like there is a way with the resources we have.
We haven’t worked with the devkit in quite a while, but I do still have one that I can run some tests with to reproduce your results.
Correct, I tried the SPI2 pins first this morning, w/o success. Then moved to SPI1 and it worked. If I have time next week I’ll try to compare SPI1 to SPI2 regs and see what the secret might be.
@TWarren
We are in the process of reworking one of our boards to swap the TPM from SPI2 to SPI1. We will at least be able to see if the driver and DT works for our device on SPI1. However we are already passed the point where we can make changes to the HW so we can’t just do a swap if it does work.
I tried on Friday to compare the registers if I switched to SPI1 from SPI2 and I didn’t see any difference in the registers we had already been looking at. There are a few other mentions of SPI1 and SPI2 in the TRM but they seem to have the same values as the 308 and 328 offsets.
There are no differences intrinsically between SPI1 and SPI2 in the T210 SoC that I know of, Joseph. I suspect that whatever is keeping SPI2 from working is some initial setting in GPIO, mux, pad cfg, pulls,
CAR, etc. that is impeding the signal(s) somehow. AFAIK, there’s no reason that SPI2 shouldn’t work as well as SPI1. It will be interesting to see what you see when you move the TPM to SPI1, even if temporarily. It’s piqued my interest, and I’ll look into it as time permits, but I don’t have the BW to devote to too deep an investigation, unfortunately.
@TWarren
So we reworked a board and switched out TPM from SPI2 to SPI1. I changed the Pinmux and both uboot and kernel DTs to point at SPI1 instead (no other changes).
I flashed the reworked board and the TPM2 Init call worked without changing any registers:
So this proves that we can use the drivers to comunicate with our TPM from u-boot. We still need to discover what the difference between SPI1 and SPI2 are to try and configure them the same.
Well done. Perhaps @WayneWWW can inquire with our HW folk about any external diffs in SPI1 and SPI2 on Nano CVM/CVB, while you look into any SW diffs from pinmux/GPIO DTBs, CAR, etc.
I am not an expert on these registers, but what I see when I tested on SPI1 (and changed the PINMUX) was that the 0x70003050 (SPI1) registers matched the SPI2 registers except that they had 0xe0xx instead of 0x60xx. I was looking at the TRM and it shows that this bit that is different is “E_PREEMP” and on SPI1 it is enabled and on SPI2 it is not even an option. I am not an EE so the name of the bit doesn’t mean much to me, but could this be something? Other than this bit when we have the TPM on SPI1 the other registers match what we have for SPI2 registers. I will continue to look, but so far this is the one difference I am seeing.
I captured the following registers that I can think of having to do with SPI1 and SPI2.
I captured them all on our board with the TPM on SPI1 and on our board with the TPM on SPI2. Everywhere there are differences make sense to me except for bit 15 on SPI1 being high as I said in my previous post, as well as CS1_0 being 0xe020 vs 0x6021 (I did try and set it to 0x6020 and it still didn’t work). All other changes seem are just SPI1 vs SPI2 clocks being enabled or the reset GPIO being setup as an output GPIO.
Sorry, I’m a SW guy, and I too have no idea what ‘E_PREEMP’ is used for, nor why it’s on SPI1 and not SPI2 on T210. Shane/Wayne can find out from the appropriate HW person, I’m sure.
Sometimes the TRM is incomplete - can you try setting that bit on SPI2 and see if it sticks, and if SPI2 TPM access then works? Or turn it off on SPI1 and see if TPM access then fails? All I can think of right now.
@TWarren I didn’t try turning it off for SPI1, I can try that now. I did try turning it on for SPI2 and it didn’t change. It seems like a read only bit.
I just tried changing 0x70003050-0x70003060 to have bit 15 low (now matches exactly 0x70003064-0x70003074) and “tpm2 info” still works.
So now there are no differences between the registers that I can tell, but still SPI1 works. Maybe there is a HW change that happens after the bootloaders that we need to set a GPIO or something else earlier?
@ShaneCCC
Hi Shane,
Yes we did try to change the uboot registers to match what they are in ubuntu, however we didn’t see any different.
SPI1 also changes once it boots to Ubuntu but it still works in u-boot with the same register values as the SPI2 registers have.
Any more insights as to why the 2 busses differ with the same register values? We tried matching the registers between SPI1 and SPI2 in uboot and only SPI1 works. We also tried to match the uboot registers of SPI2 to what is in the OS, also doesn’t work.
We are having to look at alternatives to secure our solution as this is blocking our progress on getting approval for release. We would like to use a measured boot though if we can get this working.
