Checking to see if there has been a fix for TPR #19725 identified in topic Debugging PVF from Mixed C#/FORTRAN solution (screen capture: http://www.pgroup.com/userforum/viewtopic.php?t=4113&start=0&postdays=0&postorder=asc&highlight=debug+application+command)
I’m trying to debug an EXE that is designated as the Startup Project (screen capture:http://screencast.com/t/b1jowYwoo) that is called from another EXE that I am not debugging. When I put the path of the calling EXE as the Application Command, I get the following command window that locks up VS and I eventually kill the process. (screen capture:http://screencast.com/t/6mOkwyOgw3cY)
Any clues out there?
TIA
Ted
