I am trying to bring up a mipi sensor, and I am getting this mistakes in the trace log.
Here is the device tree I am using:
* Copyright (c) 2015-2020, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include "dt-bindings/clock/tegra194-clock.h"
host1x {
vi@15c10000 {
num-channels = <1>;
status="okay";
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_ov5693_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_ov5693_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
status="okay";
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
rbpcv2_ov5693_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_ov5693_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
rbpcv2_ov5693_csi_out0: endpoint@1 {
remote-endpoint = <&rbpcv2_ov5693_vi_in0>;
i2c@3180000 {
udv_cam0: rbpcv2_ov5693_a@36 {
compatible = "nvidia,ov5693";
reg = <0x36>;
devnode = "video0";
physical_w = "3.680";
physical_h = "2.760";
clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
clock-frequency = <24000000>;
status = "okay";
mode0 {
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
pixel_t="yuv_yuyv";
pixel_phase="yuyv";
dynamic_pixel_bit_depth = "8";
csi_pixel_bit_depth = "8";
readout_orientation = "0";
line_length = "2048";
inherent_gain = "1";
mclk_multiplier = "9.33";
pix_clk_hz = "124416000"; //124416000
serdes_pix_clk_hz= "124416000";
gain_factor = "10";
min_gain_val = "10"; /* 1.00x */
max_gain_val = "160"; /* 10.66x */
step_gain_val = "1";
default_gain = "10"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1000000"; /* 2.0 fps */
max_framerate = "60000000"; /* 30.0 fps */
step_framerate = "1";
default_framerate = "60000000"; /* 30.0 fps */
exposure_factor = "1000000";
min_exp_time = "34"; /* us */
max_exp_time = "550385"; /* us */
step_exp_time = "1";
default_exp_time = "33334"; /* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_ov5693_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_ov5693_csi_in0>;
tcp: tegra-camera-platform {
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <16>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
cam_module0: module0 {
status="okay";
badge = "jakku_front_RBP194";
position = "front";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "ov5693 2-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/rbpcv2_ov5693_a@36";
Any clue what could be causing that issue?
The signal comes from an FPGA, and the i2c part is ommited, as it is always delivering image.
Configuration is 2 lane MIPI, YUV 422 8 bit, 1200 line rate.
I do get the node under /dev/video0 and it looks correctly configured (i register the device via Jetson IO tool)
Here is the pipeline used:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,forma=YUYV,width=1920,height=1080,framerate=60/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvoverlaysink
