• Hardware Platform (Jetson / GPU):jetson
• DeepStream Version:5.1
• JetPack Version (valid for Jetson only):4.5
• TensorRT Version:7.1.3
• Docker image:5.1-base
I use NvDCF as tracker in pipeline that have one pgie and one sgie, and I linked the tracker after pgie for tracking the objects. and I also use deepstream-5.1 base docker image.
My problem is that the all of detected boxes have delay related to real objects coordinate when I use dcf tracker, but with IOU tracker every thing is good.
Note that When the speed of objects are high this situation is occured but when the objects passing slow in scenes even with dcf tacker is works correctly. The total FPS pipeline is about 150 FPS.
pipeline is like this:
sources >> decodebin >>streammux >> pgie >> queue >> tracker >> queue >> sgie >> streamdemux >> … >> fakesink
tracker.yml (6.6 KB)
