Tracker Bounding Boxes Exceeding Frame Dimensions with bbox unclipping = 0
jetson xavier nx
• DeepStream Version
6
• TensorRT Version
We are using the provided tracker config file “/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_tracker_NvDCF_max_perf.yml”, which has disabled bbox unclipping.
We are still seeing some bounding boxes with values that slighty exceed the frame dimensions, for example a bounding box with:
left: 1300.24394989014
top: 940.227062702179
width: 55.8464348316193
height: 150.41189789772
which would put its bottom centre co-ord at ( 1328.16707611084, 1090.63892841339) for a 1920x1080 frame.
Is this expected behaviour for the tracker ? Is there a way to ensure that the tracker does not return bbox values outside the frame dims ?
Can you see BBox exceeding frame dimension without tracker? Can you share the reproduce steps? So I can reproduce it in my side.
We are not tracking the bbox dimensions in our use-case without the tracker, only bbox dimensions after the tracker.
This issue began to occur when we correctly configured the app to use the tracker yaml file - before we had been passing it a bad filepath and so it had been running at default behaviour (see log below):
stdout. gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so.
stdout. ~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvmultiobjecttracker/include/modules/NvMultiObjectTracker/NvTrackerParams.hpp, getConfigRoot() @line 54]: [NvTrackerParams::getConfigRoot()] !!![WARNING] Invalid low-level config file caused an exception, but will go ahead with the default config values.
stdout. gstnvtracker: Batch processing is ON.
stderr. 0:00:04.190235603   505   0x555f335d60 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files.
stdout. gstnvtracker: Past frame output is OFF.
Config Details:
[streammux]
gpu-id = 0
live-source = 1
batch-size = 2
batched-push-timeout = 40000
width = 1920
height = 1080
enable-padding = 0
nvbuf-memory-type = 0
attach-sys-ts-as-ntp = 1
[tracker]
enable = 1
tracker-width = 960
tracker-height = 544
ll-lib-file = /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file = /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_tracker_NvDCF_max_perf.yml
gpu-id = 0
enable-batch-process = 1
enable-past-frame = 0
display-tracking-id = 1
Seems you use DeepStream 6.0. Can you have a try with DeepStream 6.1?
Hey kesong,
We have a production application that uses Deepstream 6.0 that we cannot migrate. Is this a known issue within Deepstream 6.0 ?
Can you see the BBox exceeding video frame with osd on the screen? Can it be reproduced with DS samples?
