Tracker Configuration PTZ Camera
• Jetson Orin 64GB Dev Kit
• Deepstream 6.2
• JetPack Version 5.1
• TensorRT 8.5.2.2
• Recommended Tracker configuration for a moving(PTZ) camera.
Good Morning,
I have a particular edge case use for the NvDCF tracker that some other users might also have the issue with. We are tracking small-fast-moving targets(birds) with a PTZ Camera. Every time the camera moves the Tracker loses the Track and the Track ID changes to a new number. Does anyone have any recommended parameters we can tune in our Tracker config for a moving PTZ camera to help with this issue?
I am currently using the config_tracker_NvDCF_accuracy.yml
config_tracker_NvDCF_accuracy.yml (9.0 KB) in my custom Nvidia Deepstream application. We have the ReID turned off as the ReID network would need trained on our small-fast-moving targets. Would training a ReID network be our best bet?
Any tips or tricks with tuning the Tracker parameters would be greatly appreciated!
Can you share the video which can reproduce the issue? Does the object out of the screen when you moving the camera?
