Hi all!
I was wondering if it was possible to incorporate the tracker functionality (like the one in deepstream_test2) into the deepstream_image_multistream application. What I want to do is track the vehicles as they come into the IP camera’s (rtsp stream) field of view by having them assigned a tracking id when they are detected.
Hey,
Were you able to solve this? I’m taking a look at test_2 and multistream pipes but don’t quite understand where to connect the pipe:
DS_test_2py pipe: streammux → pgie → tracker → sgie1 → sgie2 → sgie3 → nvidconv → …
multistream pipe: streammux → pgie → nvvidconv1 → filter1 → tiler → nvidconv → …
So I want to be sure: should I put the tracker also linked directly to the pgie? Or after nvvidconv1 and filter1 that are needed to RGBA the frame and save it?
Thanks in advance,
